bob hughes
Hi all
Started to work on the soft top, currently off the car, I am in the process of straightening the frame. I have sourced a new "hockey stick" metal trim for the where the soft top meets the drain channel at the rear of the car, but can not get the rubber seal - it is not made on this side of the pond. I am told it was sort of Tee shaped ( my car had double sided sticky tape holding things together. Does any one know what the section was, dimensions etc. Or, on the other hand, what did you use instead. Any photos would help too.
Bob
Bob
