Stop that seep
M
Member 10617
I feel sure many of you have tried this, but here goes:
I have been told repeatedly that Triumphs are just going to leak and seep, no matter what, and that we just have to accept it.
OK, I can live with that... to a degree. But if there is a way to stop some of it, I wanted to try.
I took my differential as a test. It seeps, very little, along the bottom, from the gasket. I dried it as well as possible, and then put some pipe joint compound on it. When that dried, the leak stopped, but when I drove the car the pipe joint compound either dissoved from the lubricant or melted from the heat.
Then I cleaned it and dried it very well and put a very small amount of laytex sealant along the joint (the kind you use of windows and doors). I let it dry about three days without driving the car. Then I drove about 75 miles. When I returned I checked the differential: dry as a bone. And now, about three days later, still no seep.
Has anyone else tried this?
If this works on the differential I may try it elsewhere. If it can stop a seep, can it stop a leak? I'll see.
I won't put it on any plugs, of course, or where it could get into the fluid. Nor will I try this on anything that gets really HOT. The good thing about latex is that you can strip it off if you want to remove it. Putting it on is reversable, which is always a good thing.
TR3driver
Great Pumpkin - R.I.P
It actually shouldn't be that hard to get any gasketed joint on a TR to stop leaking. The drill is pretty much the same for all of them : make sure the surfaces are flat, the threads aren't bungled, the bolts are the right length, and are torqued to spec (not just "good and tight").
Generally it's the moving joints that drive people to distraction, particularly the rear main seal on the engine. The original seal can be made to work (or so I'm told, once you know the secret); however there should shortly be a new, improved seal available that is supposedly even better than the old, improved seal currently available from Moss et al.
I use silicone latex caulk where the transmission tunnel joins the body; but haven't tried it for sealing gaskets. But I have had good luck doing temporary repairs with Permatex "Ultra Black" silicone RTV. The key with anything applied on the outside is to get the surface totally free of grease and oil, which may be impossible without draining the unit.
M
Member 10617
Randall,
Yes, I put the silicone latex caulk on the outside. I didn't take the unit apart to replace the gasket or put latex on the gasket. I don't think I would do that because if I replaced the gasket, I assume it probably would give me a good seal. What I did was a kind of band-aid solution.
You are right that the secret is to get the surface totally free of grease and oil.
Geo Hahn
Hopefully your band-aid will hold... if not then a new gasket will surely take care of that leak. FWIW -- the thin paper gasket from the usual suppliers didn't impress me much, in fact the one I bought didn't even match the bolts holes. I made my own -- one from cork and another from thick gasket paper. Both worked fine though the thicl paper one was easier to work with.
Oh, and sometimes you can just tighten the bolts a bit (not too much) for a leak there.
Lewis_McDorman
Don't let the seep worry you. I saw a sticker on a Harley on TV this evening and I want one for my car.
"MY [TRIUMPH] ISN'T LEAKING, IT'S MARKING IT'S TERRITORY"
M
Member 10617
The discouraging thing is that even some of the new gaskets leak. I am told by some experienced mechanics that that's just to be expected. "It's the way Triumphs protect themselves against rust," I am told. Hmmm!!??
RJS
Thanks guys. I was actually considering this myself. I picked up a tube of Permatex Ultra Black this summer with the idea of running a bead around the timing chain cover - after a thorough degreasing first.
Bob
Don Elliott
I use a large piece of thick cardboard (as you might get wrapped around a refrigerator) and I lay it on my garage floor under my 1958 TR3A from the fan belt all the way back to beyond the diff. It keeps my garage floor clean. I change it at least once a summer. It become toatally black and oily by then. If I don't drive the car for, say a week, there is nothing more dripping. It's always just after I park it in the garage.
I've driven "TRusty" 2450 miles so far this summer.
Deleted member 8987
Trick we have used in other applications....
Clean it well with Brakleen.
If there is a drain, drain it first into a clean container (filter through a clean rag if you want) if it's recent oil and you want to re-use it.
If there is a vent (and make sure it isn't plugged), block it.
Use a ShopVac, apply vacuum to the drain (easier than fill), and while applying suction, put your permatex black along the seam area you suspect is leaking.
Watch the area, if and when you see the silicone starting to suck in, remove the suction source.
Let it set overnight, re-fill.
One of the big offenders was the rear intake seal on FE series Fords.
Dave
M
Member 10617
Draining and attaching vacuum sounds like just the trick. Next time I change my oil, I'll try this. Do you think permatex black does a better job than laytex sealant?
DNK
Latex is water based, so I would not be my choice
M
Member 10617
Permatex Ultra Black Maximum Oil Resistance RTV Silicone Gasket Maker, according to the advertisements, is not only oil resistant, but has a temperature range of -65 degrees F to 500 degrees F. Sounds like the just the thing for me to use.
Deleted member 8987
You won't get an air-tight vacuum, as air will come in past the seals, but enough to do the trick.
K TR2/3/3A The two wires that go to the brake light stop switch junction......... Triumph 1
K TR2/3/3A Clutch and Brake Master Cylinder push rod stop bolts? Triumph 15
Basil Drop Stop Restoration & Tools 3
D TR4/4A rebound stop clearance issue Triumph 13
edkap2002 TR6 stop light [brake light] swith Triumph 9
B Stop/Tail light wiring Austin Healey 23
O Hesitation on pulling away from stop Jaguar 25
D extra stop/brake light Austin Healey 33
steveg Wanted - easy install tool or technique for directional/stop light lenses Austin Healey 9
warwick-steve Bump stop box query Austin Healey 19
Scotsman TR4/4A Steering Stop Lock on trunnion Triumph 9
KVH TR4/4A I Can't Stop Burning Oil; Engine Missing at Take Off Triumph 5
HealeyRick Wipers Won't Stop Spridgets 6
T TR4/4A Rear Bump Stop Spacer Triumph 1
M Stop the EPA Racing 7
bugedd Rear axle bump stop Spridgets 7
K TR2/3/3A Clutch Master Cylinder "Stop" Bolt.... Triumph 4
C Bump Stop Box Color??? Austin Healey 4
maxwedge5281 braking circuit through the stop light switch Austin Healey 7
J How to put a stop on the end of a choke cable? Restoration & Tools 2
B LED bulbs as side lights/stop light/flashers Austin Healey 29
tomshobby lower window stop? Spridgets 7
Mickey Richaud MGB Rear Bump Stop - MGB MG 2
PatGalvin The fun just won't stop [engine rebuild questions] Triumph 53
drooartz Off Topic It really needs to stop snowing... MG 19
Tim Tucker TR4/4A TR4 STOP BRACKET for WINDOW REGULATOR Triumph 5
Superwrench Horns won't stop beeping ! Help ! Austin Healey 4
N Running and stop bulbs??? Spridgets 4
J POR-15 where to stop??? Spridgets 30
T She runs! She won't stop running! Triumph 2
A TR2/3/3A TR-3A door strap/stop attachment to body Triumph 10
doates Now how do I make it stop? Triumph 12
M trans leaking, any additive to stop it Austin Healey 13
Trevor Jessie Emergency Stop Spridgets 8
G Racing idle at stop lights MG 3
tr6nitjulius One Stop! In Old out New! Triumph 3
O TR2/3/3A TR3 Rear Turn lights Versus Rear Stop Tail lights? Triumph 5
DNK And he didn't even stop! Spotted 18
G FUEL PUMP WON'T STOP CLICKING Austin Healey 12
C Stop Light Switch Spridgets 17
doates Spitfire Spit Does Not Want To Stop Triumph 12
J Starter does not want to stop Triumph 11
K TR2/3/3A TR3 stop lights lens Triumph 12
TR6oldtimer TR6 TR6 Door Stop Triumph 3
jdubois TR2/3/3A What's the deal on the fuel stop tap on the TR3? Triumph 4
Basil Brake Servo Cylinder Stop Pin needed Jaguar 17
Tinkerman TR2/3/3A TR3 Gas Stop Tap Needed ! Triumph 6
J Bump Stop Box Austin Healey 3
Hooper11772 OMG stop smoking already!!!! Spridgets 75
R stop leak additive for 1500 trany with j-type OD? Spridgets 0
