How to put a stop on the end of a choke cable?
Jerry
My choke needs a lead or ?? welded on the end of the cable to actuate the choke. This is a mikuni carb so the cable goes inside the carb. No room for a screw type stop. the drawing shows a lead or something on the end. I tried solder but it only lasted for about 10 choke pulls. Any other ideas or do I need a special tool?
Jerry
JPSmit
take it to a bicycle shop and see what they can do? (or a motorcycle shop)
J
Jerry
I decided to try a screw in the choke mechanism. A #10 just fit so I cut off a piece drilled a hole in it, threaded the wire through the hole and welded the end. So far it works. We will see how long it lasts. At least it is all steel now, so it should not come loose.
Jerry
T Got the engine put together Spridgets 4
S TR6 After I put in my new oil pump.... Triumph 3
K For Sale TR4A Intake Manifold..Put one on your TR3...improves air intake....cheap like borsht. Triumph Classifieds 2
M TR2/3/3A Has anyone put in a Hi Torque Starter from Moss? Triumph 21
M TR2/3/3A Where have you guys put your stereos and speakers? Triumph 3
M TR2/3/3A Phone charger & Radio can I put these in my car??? Triumph 7
B TR4/4A Possible to put TR6 seats in a TR4A Triumph 3
R TR4/4A About to put in an OD Transmission. What else should I do while in the air Triumph 7
T TR2/3/3A Should I put flat washers on sump bolts? Triumph 3
T TR2/3/3A Has anyone put late TR4/4A upper A-arms and ball joints on TR3? Triumph 3
glemon General TR Time to Put Your Tops Up? Triumph 12
jlaird Before I put in classifieds Spridgets 36
Bob McElwee Rode Hard and Put Away Lovingly Austin Healey 6
M Who put the stick in my heater hose? Spridgets 6
BN6_2197 What to put in steering idler reservoir of BN6 Austin Healey 2
drooartz Help me put together a plan for my Bugeye Spridgets 46
PAUL161 General MG Where Would You Put This? MG , VW, Motorcycle? MG 3
R 100-4 PUT-BACK-TOGETHER ?'s Austin Healey 2
RickB Just put headrest speakers in - wow! Spridgets 8
T TR2/3/3A Has anyone put sound deadening in a TR3. Were the results worth it? Triumph 21
DrEntropy Can't put it off any longer. MG 10
M Body ready to be put on Chassis, 1 question first Triumph 9
B TR2/3/3A TR3. Would you put it back to right hand drive? Triumph 11
T Where to put the OD relay? Triumph 13
bugedd Before I put it on ebay.... Spridgets 0
K TR4/4A Can I put a TR3A Clutch in a 4A? Triumph 16
Basil Where to put that bumper sticker Spotted 1
middie Before I put engine back Spridgets 22
Jims71TR Put a new fuse box in now I have troubles Triumph 15
regularman Has anyone here put a bugeye front end on a square Spridgets 2
G GT6 Can I put a GT6 balancer [crank pulley] on a TR6? Triumph 2
BugeyeNJ58 Put on Harley Muffler--now backfires?? Spridgets 26
doughairfield Where to put the ground. Triumph 6
B Before I put the heater in my 57... Triumph 10
JPSmit Wasn't quite sure where to put this -youtube video Spotted 6
BugeyeNJ58 Radius arm came out...how to put new one in? Spridgets 6
bigjones Spare coil - put it under the hood? Spridgets 8
Marvin Gruber Put off too long Jaguar 4
T OT - what do you think, put a Rover V8 in it? Triumph 29
T Did they put TR frames under these? Triumph 8
jackq Something to put in front of your MG MG 0
Tinkerman Need to put a new hole in my dash! Triumph 20
JohnnyMead What to Put Under Carpeting? Triumph 11
I TR6 TR6 put put sounds, part 2 Triumph 74
T What do you think - put a team together for this? Triumph 2
livinginthepast Stupid Q dejour - horn push/badge won't stay put! Spridgets 14
T Largest tire size I can put on my 89 xj40 Jaguar 1
J So, I put my money where my mouth is....... Jaguar 12
