doughairfield
I'm changing over to a pertronix Flamethrower distributor this weekend on my positive ground TR4. The instructions indicate I need to have one wire on the new distributor connected to the negative post on the coil and the other wire on the distributor needs to goto the ignition switch.
Currently with the old distributor in place, I have the positive post on the coil going to the ignition switch and the negative post on the coil goes to the HT lead on the distributor.
Once I remove the wire going to the positive post of the coil and connect that to the new distributor, what's a good place to ground the positive post of the coil to?
Any other gotchas or tips on putting the new distributor in?
