Now how do I make it stop?
doates
Hi everyone,
In trying to sort out my charging/stalling problem I decided to fix all of the electrical problems that I created from poor reassembly (turn signals, flashers, head lights, dash board lights, basically anything electrical). I would like to blame Lucas but I am sure that I played a large roll in the problems.
Anyway, the spit has been the warmest convertible that I have ever had even though the fan did not blow. While I had the dash out I decided to try to fix the fan. I think all that was wrong with it was the 40 years of crud and paint (mine) that was layered on the rheostat thing under the dash. Cleaned those two copper bars on the control panel and the motor fired right up. Problem is I can't get it to stop and there is no speed control; I assume that is what the rheostat is for? The fan control has a finger on the back side that rubs against a copper bar; there are actually two bars but my finger only touches one of them. Is it supposed to rub on both? Was there something that caused the finger to lift and break the circuit that may have disappeared?
So far, I have not found a new controller so I am looking for ideas on how to make it shut off; besides pulling a wire.
Thanks in Advance
TR3driver
Great Pumpkin - R.I.P
Yes, the rheostat is supposed to provide speed control. Generally there should be some sort of coil of resistance wire that runs between those two bars; although it may be buried in ceramic so it looks like just a bunch of stripes of metal. The finger will move along the coil to provide a variable resistance. One of the bars will be high speed (no resistance), the other will be minimum speed (maximum resistance). Frequently the finger is allowed to move beyond one of the bars, to break the connection entirely and turn the motor off.
Curiously, though, the wiring diagram I have for a Mk 3 Spit shows a simple on/off switch rather than a rheostat. You might want to try pulling a wire from your rheostat, to be sure it's the heater control.
Brosky
It would be curious if someone had a problem in the past and directly wired the heater fan to be on at all times, but then what is the rheostat for? This is interesting.
doates
doates
Hi Again,
I found this one used at Rimmer. It looks just like mine except that on mine the tip of the finger only rubs the inner copper bar. On this the finger rubs the outer. The 2nd wire attaches to the inner copper bar. If I disconnect that wire the fan stops but if I disconnect the green/yellow wire it doesn't. I should have checked for resistance between the two bars.
[image]https://i23.photobucket.com/albums/b377/dennis_oates/622236U.jpg
Thanks
HerronScott
The 1967-1968 Spitfire Mk 3's had the original center-mounted gauges and switches and did have a simple switch for the heater fan (Can't recall if it was 1 or 2-speed switch though).
The 1969-1970 Spitfire Mk 3's had the dash redesigned where the gauges are in front of the driver so the switch probably changed at this time.
Scott
doates
doates
Actually the wiring diagram that most nearly matches my car is for '71 MK IV. Though it is not perfect.
TR3driver
I'm going to go out on a limb here, and say that I don't think that is a rheostat at all. I think there should be a Bowden cable attached between that clip on the left (with the bolt head visible under the green/yellow wire) and the clevis visible to the right of the clip. And as the lever at the top of the photo moves from side to side, it moves the cable (which is likely attached at the other end to an air door somewhere) without changing the resistance to the heater motor.
Then presumably at some point in the motion (likely the full cold end), it interrupts power to the motor entirely. I don't see quite how that happens, but it's the only thing that makes sense to me. Those copper bars won't have enough resistance to affect the motor at all. The finger and bar are only so the on/off switch can be incorporated with the water control.
Here's a manual page on the Canley Classics site that shows the control and the Bowden cable
doates
doates
That is exactly how mine operates. Cable controls an air door that diverts air from the cabin to the screen. When the lever is moved all the way to the driver's right it is in the off position. I am wondering if there was a ramp or something to break the contact with the copper bars? I may try coating the end of the bar with epoxy and see if that works. I wonder why they call it a rheostat and why two wires to it?
I would order the one from Rimmer; it is cheap but shipping is 4X the cost of the part.
I am sure that this has been asked many times but how do you get a picture to post in the body of your message?
Thanks Again
Dennis
TR3driver
There are various ways. One of the reasons I like PhotoBucket is because it automagically provides the appropriate tags. You just click in the "IMG Code" box
and both the tags and URL are copied to the clipboard, so you can switch to the BCF post and paste them.
<div class="ubbcode-block"><div class="ubbcode-header">Code:</div><div class="ubbcode-body ubbcode-pre" ><pre>
</pre>[/QUOTE]
If the photo is on another site, then I usually just type the tags by hand:
</pre>[/QUOTE]
and paste the link in the middle:
</pre>[/QUOTE]
But if you prefer a "point and click" method, then click on either the "<span style="text-decoration: underline">Reply</span>" or "<span style="text-decoration: underline">Switch to Full Reply Screen</span>" links. The "Full Reply" screen has a toolbar:
where you can click on the "Enter an image" icon
and then paste (or type) the URL into the dialog.
With all of these methods, all you will see at first are the tags and URL. But you can then click on the "Preview Post" button, and see what your post will look like to others.
Andrew Mace
I hate to suggest the obvious, but I've not seen it mentioned here. Are you pushing and pulling the knob (in and out) or just sliding it left and right? It is a two-speed fan: pulling the knob all the way out gives you the higher fan speed, and pushing it all the way in shuts it off.
tomgt6
As always Andy beats me to the answer. I was going to say that my GT6 has kind of the same switch and it was stuck in the on or off position and with some elbow grease I was able to get it unstuck so it would go in and out as well as right to left.
doates
doates
Yep, the obvious wins. The lever pulls in and out for stop and two speeds and moves left and right to divert air flow. Boy do I feel dumb.
Unfortunately, the fan is so loud I will probably never use it. Bearing squeak and the squirrel cage is cracked and out of round. Fortunately, I live in California where I don't really need heat.
Thanks Again....Dennis
K TR2/3/3A The two wires that go to the brake light stop switch junction......... Triumph 1
K TR2/3/3A Clutch and Brake Master Cylinder push rod stop bolts? Triumph 15
Basil Drop Stop Restoration & Tools 3
D TR4/4A rebound stop clearance issue Triumph 13
edkap2002 TR6 stop light [brake light] swith Triumph 9
B Stop/Tail light wiring Austin Healey 23
O Hesitation on pulling away from stop Jaguar 25
D extra stop/brake light Austin Healey 33
steveg Wanted - easy install tool or technique for directional/stop light lenses Austin Healey 9
warwick-steve Bump stop box query Austin Healey 19
Scotsman TR4/4A Steering Stop Lock on trunnion Triumph 9
KVH TR4/4A I Can't Stop Burning Oil; Engine Missing at Take Off Triumph 5
HealeyRick Wipers Won't Stop Spridgets 6
T TR4/4A Rear Bump Stop Spacer Triumph 1
M Stop the EPA Racing 7
bugedd Rear axle bump stop Spridgets 7
K TR2/3/3A Clutch Master Cylinder "Stop" Bolt.... Triumph 4
C Bump Stop Box Color??? Austin Healey 4
maxwedge5281 braking circuit through the stop light switch Austin Healey 7
J How to put a stop on the end of a choke cable? Restoration & Tools 2
B LED bulbs as side lights/stop light/flashers Austin Healey 29
tomshobby lower window stop? Spridgets 7
Mickey Richaud MGB Rear Bump Stop - MGB MG 2
PatGalvin The fun just won't stop [engine rebuild questions] Triumph 53
drooartz Off Topic It really needs to stop snowing... MG 19
Tim Tucker TR4/4A TR4 STOP BRACKET for WINDOW REGULATOR Triumph 5
Superwrench Horns won't stop beeping ! Help ! Austin Healey 4
N Running and stop bulbs??? Spridgets 4
J POR-15 where to stop??? Spridgets 30
T She runs! She won't stop running! Triumph 2
A TR2/3/3A TR-3A door strap/stop attachment to body Triumph 10
M trans leaking, any additive to stop it Austin Healey 13
Trevor Jessie Emergency Stop Spridgets 8
G Racing idle at stop lights MG 3
tr6nitjulius One Stop! In Old out New! Triumph 3
O TR2/3/3A TR3 Rear Turn lights Versus Rear Stop Tail lights? Triumph 5
DNK And he didn't even stop! Spotted 18
G FUEL PUMP WON'T STOP CLICKING Austin Healey 12
C Stop Light Switch Spridgets 17
doates Spitfire Spit Does Not Want To Stop Triumph 12
J Starter does not want to stop Triumph 11
K TR2/3/3A TR3 stop lights lens Triumph 12
TR6oldtimer TR6 TR6 Door Stop Triumph 3
M Stop that seep Triumph 14
jdubois TR2/3/3A What's the deal on the fuel stop tap on the TR3? Triumph 4
Basil Brake Servo Cylinder Stop Pin needed Jaguar 17
Tinkerman TR2/3/3A TR3 Gas Stop Tap Needed ! Triumph 6
J Bump Stop Box Austin Healey 3
Hooper11772 OMG stop smoking already!!!! Spridgets 75
R stop leak additive for 1500 trany with j-type OD? Spridgets 0
