TR6 TR6 Door Stop
TR6oldtimer
Years, no a life time ago, the bracket on the drivers door for the stop broke. Well now I am in the process of fixing it and putting on a new skin to correct other damage on the door.
Well, I fabricated a new bracket, did some compression on the old sheet metal, and test fitted.
Now I know why the old bracket broke.
Here is a shot of how it aligned up. Notice the door bracket is lower then the check strap.
Here it is when placed on the top of the now bent bracket, if fits very well.
Oh, I only used the screw to test the strap, so please, no one get excited about it.
At first I thought it was the door, as years ago it was replaced. But no, it matches the passenger side and fits well into the door frame. Then I took some measurements, and found the check strap was actually mounted in the "A" post 1/4-3/8" higher on the driver's side then on the passenger's.
I guess I will straighten the bracket, fabricate a spacer, and mount it on top where it will not bind.
Here is a shot of the back side of that check strap bracket which I have yet to weld in.
and no, I do not plan to reposition it.
Bummer...
Have any of you noticed this little oddity?
TR6oldtimer
TR6oldtimer
Update,
I decided to fix it after all. Cut a new slot above the old, welded the lower old one close, and now everything is nice and smooth.
Onward with my first attempt at putting on a door skin...
DennisT
Hello TR6oldtimer,
thanks for posting your topic, I also have a broken door checkstrap mounting bracket, I ordered a new one from rimmer Bros but realized the door skin must come off, can you tell me how the bracket is welded inside the door? Is it just some spot welds the can be drilled out from the outside of the door frame? I couldn’t get your pictures to display.
Thanks,
Dennis
DennisT
Hello TR6oldtimer,
Thanks,
Dennis
R Wanted TR6 Interior Door panels Triumph Classifieds 0
R TR6 TR6 Door Glass Triumph 5
Sarastro TR4/4A Puzzled about TR6 door seals on a TR4A Triumph 7
sundown TR6 1973 TR6 door check straps Triumph 3
B TR6 How restore the "gold" finish of TR6 door latch? Triumph 4
B TR6 TR6 door latch challenges Triumph 0
I TR6 Help installing TR6 door pulls and fuzzy seals Triumph 14
G TR6 TR6 door rattles/weather stripping Triumph 0
G TR6 TR6 innner door release and window crank removal Triumph 5
tomshobby TR6 putting scuttle door on 76 TR6 Triumph 9
TR6oldtimer TR6 TR6 door and fender Triumph 12
hondo402000 TR6 TR6 New door switches Triumph 1
hondo402000 TR6 TR6 Door Switches Triumph 19
M TR6 tr4-tr6 door switches Triumph 3
floyd TR6 TR6 door rattles Triumph 8
hondo402000 TR6 TR6 Door Catch plate Gasket Triumph 6
Gliderman8 TR6 '73 TR6 Door Pulls Triumph 9
71tr TR6 TR4 door handles on a TR6 Triumph 4
T TR6 Let's talk TR6 door gaps! Triumph 20
bcbennett TR6 TR6 Door adjustment...possible? Triumph 1
N TR6 TR6 Passenger door and window fit ? Triumph 5
J TR6 Door gaps on a tr6 Triumph 5
2wrench TR6 Help removing an exterior door lock, '74 TR6 Triumph 1
N TR6 TR6 Door hinges Triumph 1
B TR6 TR6 door window alignment question Triumph 7
TR6oldtimer TR6 TR6 Optimum door gaps? Triumph 13
D TR6 Door Latch 1972 TR6 Triumph 1
J TR6 how do you remove the door key locks on a tr6? Triumph 2
I TR6 TR6 window door pull/window seal help Triumph 6
O TR6 '73 TR6 Left Hand Door Switch Triumph 3
Got_All_4 TR6 TEX DOOR MIRROR VS BULLET MIRROR TR6 Triumph 22
TR6oldtimer TR6 TR6 door bottom sticking out Triumph 2
D TR6 70 TR6 Vent Door Spring Triumph 1
I TR6 Removing door check arm in TR6 Triumph 6
Paulus TR6 TR6 Door Panels Triumph 5
AltaKnight TR6 TR6 door fix Triumph 5
John_Mc TR6 TR6 door jam switch Triumph 5
H TR6 TR6 Door seal Furflex Triumph 1
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
