TR6 TR6 door jam switch
John_Mc
I'm still having trouble locating the proper door jam courtesy light/ignition warning light&buzzer switch for a 71 (or 70) TR6. The big three have switches listed but the right one for the job is always N/A. I wrote Rimmer Brothers in England and they said the right part, 622748, is no longer available. Has anyone in their restoration attempts found a suitable replacement? Shouldn't there be a number of cars that use a similar set-up that should work or have the rest of you just decided you don't need no stinkin' buzzers?
John
MDCanaday
I am in the depths of wiring heck on my 71 as we speak and from my wiring diagram you ,like me, dont have need or want the seat belt buzzer,lamp. There was never a provision for this untill 72.The jamp switches are just grounding switches and so anything similar should work if the prong is long enough to reach the door......
Mad dog
John_Mc
John_Mc
I would agree Mad Dog, I'm not a big fan of buzzers, but I do kinda like the idea of completing all the wiring. Unused, dangling wires always register in the back of my mind. The driver's side door-jam switch has a dual function inthat it not only grounds the courtesy light circuit but it closes the circuit to the ignition warning light/buzzer so that (as I understand it) if you open the door with the key in the ignition it buzzes. In my Haynes manual there is essentially only one wiring diagram for the TR6, and it isn't accurate for every year model. Check out Dan Masters' beautiful color diagrams (if you haven't already) for the specifics of each model year. You are right about the seatbelt buzzers not coming until after '71.
https://www.advanceautowire.com/tr2506.pdf
John
LastDeadLast
I've gone through this too and John is right, I tried to install a regulalar ground switch on my drivers side and it just blew a fuse. If you want the buzzer and everything connected then you need the "special" switch as described in the post above. I have not been able to find one either. I tried to rebuild my old one, but it was trash. I ended up bypassing the buzzer and installing my own courtesy light system with ground switches on both doors.
Mark_Gibson
My car has been through the entire ground up rebuilding process, and the one wiring problem I can't solve is similar to yours. I have the correct door jamb switches, but my key buzzer goes off every time I open the drivers side door, regardless of whether the key is in the ignition or not! It's the only squirrely electrical gremlin on the car (but of course I haven't had it out on the road yet!) I'll take a look at those diagrams you provided, maybe the answer is in there! As for your switch, I can find you an original one if you want one. My friend Mark at British Auto has a bunch of TR-6 wrecks and I've seen that switch on several of them. Let me know if you want me to pursue this. My email is gibber1956@frontiernet.net
Mark
John_Mc
John_Mc
Dan Masters also has a legend explaining some of the symbols on the wiring diagrams. Unfortunately, it's not included with the color diagrams, but I found it with the black and white version at a site called BritishV8.org.
https://www.britishv8.org/tech.htm The last page of the PDF document has wiring color and symbol information. It helped me sort out a lot of wiring questions I had.
R Wanted TR6 Interior Door panels Triumph Classifieds 0
R TR6 TR6 Door Glass Triumph 5
Sarastro TR4/4A Puzzled about TR6 door seals on a TR4A Triumph 7
sundown TR6 1973 TR6 door check straps Triumph 3
B TR6 How restore the "gold" finish of TR6 door latch? Triumph 4
B TR6 TR6 door latch challenges Triumph 0
I TR6 Help installing TR6 door pulls and fuzzy seals Triumph 14
G TR6 TR6 door rattles/weather stripping Triumph 0
G TR6 TR6 innner door release and window crank removal Triumph 5
tomshobby TR6 putting scuttle door on 76 TR6 Triumph 9
TR6oldtimer TR6 TR6 door and fender Triumph 12
TR6oldtimer TR6 TR6 Door Stop Triumph 3
hondo402000 TR6 TR6 New door switches Triumph 1
hondo402000 TR6 TR6 Door Switches Triumph 19
M TR6 tr4-tr6 door switches Triumph 3
floyd TR6 TR6 door rattles Triumph 8
hondo402000 TR6 TR6 Door Catch plate Gasket Triumph 6
Gliderman8 TR6 '73 TR6 Door Pulls Triumph 9
71tr TR6 TR4 door handles on a TR6 Triumph 4
T TR6 Let's talk TR6 door gaps! Triumph 20
bcbennett TR6 TR6 Door adjustment...possible? Triumph 1
N TR6 TR6 Passenger door and window fit ? Triumph 5
J TR6 Door gaps on a tr6 Triumph 5
2wrench TR6 Help removing an exterior door lock, '74 TR6 Triumph 1
N TR6 TR6 Door hinges Triumph 1
B TR6 TR6 door window alignment question Triumph 7
TR6oldtimer TR6 TR6 Optimum door gaps? Triumph 13
D TR6 Door Latch 1972 TR6 Triumph 1
J TR6 how do you remove the door key locks on a tr6? Triumph 2
I TR6 TR6 window door pull/window seal help Triumph 6
O TR6 '73 TR6 Left Hand Door Switch Triumph 3
Got_All_4 TR6 TEX DOOR MIRROR VS BULLET MIRROR TR6 Triumph 22
TR6oldtimer TR6 TR6 door bottom sticking out Triumph 2
D TR6 70 TR6 Vent Door Spring Triumph 1
I TR6 Removing door check arm in TR6 Triumph 6
Paulus TR6 TR6 Door Panels Triumph 5
AltaKnight TR6 TR6 door fix Triumph 5
H TR6 TR6 Door seal Furflex Triumph 1
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
