Starter does not want to stop
Jim Lee
First, thanks for all the help with the choke. I think I have that problem on the run. In the course of messing around with the choke I somehow made my TR3's starter run constantly. Here is the sequence of events.
- Standing next to the engine bay I pressed the handy starter switch on the solenoid. It turned fine but I finally realized that it was not going to start without the key turned on so that ignition would be happening.
- Turned the key on and pressed the starter button on the solenoid again. Starter turned...and turned...and turned. Fortunately the ground cable on my battery was loose enough that I could remove it. Put the ground cable back on for a second and the starter starts up again.
- I have an extra starter/solenoid so I am putting that in to make sure that the current solenoid is not bad. I tested the continuity of that starter button and it tested fine. Exactly the same as the other, original, starter button that I am going to put in as a test.
- Also tested the push button starter switch in the cockpit. It tested fine as far as continuity goes. Open when not pushed, closed when pushed.
Anyone have any guesses as to what might be going on? The first thing I do tomorrow is to put the old starter/solenoid in and see if I have the same 'starter won't stop' issue.
As a side note, does anyone know what the thread is on the starter/solenoid? Is it some crazy Old World English deal? M8 1.0, 1.25 did not work. 5/16's 18 or 25 did not work. I have one nut that was on one of the poles but I am missing the other.
Thanks very, very much,
Jim Lee
TR3driver
Great Pumpkin - R.I.P
Quick test, pull the small side wire (white w/red as I recall) off the solenoid, then try again. If the starter still runs, the solenoid is bad. If not, the problem is somewhere back towards the pushbutton on the dash.
Yes, those are "crazy Old World threads"
I don't recall the exact size offhand, but they are either Whitworth or BA. So is the stud on the starter.
Geo Hahn
I have had that happen once -- but it never recurred.
Mine was a bit more exciting as it came at the same moment that the starter jammed. I rocked the car backwards (in 4th) to free the starter, then the stuck solenoid took over and began to drive the car forward. I was parked just a couple of feet from a concrete wall with the added difficulty factor that the right front tire was driving over my foot.
I, too, keep the ground cable loose though I had to wait until the tire got off my foot to reach for it. Longest 3 seconds of my life so far.
TR3driver
YoW!
J
Jim Lee
That is motoring excitement.
Is that little wire what tells it to turn?
I take it that the little wire on the side is what tells
it to turn? If so could I hook everything up except that wire and test to see if it is hot without anything turned on?
The only suspect thing about the starter/solenoid that was on there was that the two posts can be wiggled a bit and cannot be screwed in tight. Whereas the original ones posts are tight do not move at all. My assumption is that the original one, which I believe is original to the car, is of a higher quality than the reproduction. When I removed the original solenoid I believe that I did it as a test and never got around to replacing it...so I am pretty confident it is good.
The only issue is having to get a Whitworth nut. Do the big three sell those at a reasonable cost?
Thanks,
Jim Lee
ekamm
My solenoid button will stick occasionally as well. I don't use it unless absolutely necessary. And I am ready to pull the disconnect. I always chalked it up to an original part that likely has some very old thick grease or dirty contacts.
TR3driver
Yes, the little wire supplies power to the solenoid from the pushbutton on the dash. When the solenoid is energized, it closes the contacts between the two big posts, thereby passing power to the starter. So if the solenoid is stuck, it will pass power to the starter even without power from the small wire.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]The only suspect thing about the starter/solenoid that was on there was that the two posts can be wiggled a bit and cannot be screwed in tight. [/QUOTE]There should be a nut on each post, that locks the post to the body of the solenoid. Then a second nut and lockwasher attach the cable to the post.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]The only issue is having to get a Whitworth nut. Do the big three sell those at a reasonable cost?[/QUOTE]
Not as far as I know. They only come with the solenoid. ISTR they are also an unusual size as well as unusual thread.
But you might be able to come up with something that would work from https://www.britishfasteners.com/
dklawson
I know the studs use a unique thread as Randall has said, but I accidentally came across a work around. From an old piece of equipment I had some 5/16-24 thin brass jam nuts. The jam nuts were about 1/2 the thickness of normal nuts. Though the pitch was not correct, the short length of the threads in the nut did sort-of fit the solenoid studs. I used those in the "inner" position against the Bakelite housing and used the remaining original nuts on the outside. If you do not find the real nuts you need, perhaps you could sand/grind/file down some regular thickness 5/16-24 nuts to work.
J
Jim Lee
Ok. I have gone back to the original solenoid/switch and it is working as advertised. Now the engine is simply not starting. I am beginning to wonder if something is off with the starter. I do not get the feeling that it is turning over the engine as fast as it did. Just checked out the battery and it checked out fine at my local auto store. I was hoping that was the issue. I had a problem with old gas not long ago but then it was at least running on starting fluid for a few seconds. I am going to go over as much as I can on the ignition tomorrow. I will try to get some video of the starter turning on here to see if you all think it is normal. It is like it will turn a few times and then just stop turning, then I take my hand off the switch and it is getting hot on the positive cable coming from the battery. It was not more than a couple of months ago that it was running like unto a top. It looks like I have a few days of unseasonably nice weather for the next couple of days so I should be able to spend some time bonding with my black beauty.
Is there any kind of simple test I can do on the starter? It is original but has been rebuilt at least once.
Thanks very much,
JimLee
TR3driver
Feel along both battery cables and see if you can identify a particular spot where it is getting hot. If so, that indicates a bad connection or possibly a damaged wire. They can sometimes corrode underneath the insulation and not conduct very well. Ditto the ground strap on the engine.
Otherwise, your description sounds a lot like the starter is trying to work on 2 poles instead of 4. Only simple test I know is to remove it and either examine it yourself or take it to a shop for testing. If it is running on 2 poles, then it will appear to spin fine with no load; but the shop will have a way to measure torque.
J
Jim Lee
Thanks all. The Black Beauty is back on the road where it should be. We had another 60+ degree day here in the Tar Heel state. Put the reproduction switch/solenoid back in and for some reason it fired right up. I am going to see if I can hunt down the correct Witworth (sp?) nut so that I can put my original one back in.
On to new TR3 related learning experiences.
Thanks,
Jim Lee
RJS
Sounds like you've experienced bad solenoids in the past, as I have. The quality of the new solenoids today from the big three are suspect at best (all of $16 - get what you pay for I guess). I've had issues with the contacts sticking and the starter continuing to run. Usually, a rap on the solenoid with a hammer is enough to remedy.
I've done some research and "next time" I'll probably go with a much higher quality option from NAPA (these are direct replacement listings for a '66 TR4A):
Echlin PN: ECH ST 236 = $49
Altrom PN: ATM 1437001 = $72
I have also read here on BCF these solenoids for a '72 Ford Maverick will work
Echlin PN: ECH ST 81 = $24
Echlin PN: MPEST81SB = $12
Hope this helps and wish you luck,
Bob
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 7
R TR6 Starter Solenoid Conection Triumph 11
R TR6 Lucas Starter 2M100 - Extra Part? Triumph 2
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
N TR5/TR250 Starter Box Assembly Leak Triumph 14
P TR2/3/3A British High Torque starter Triumph 6
W General Tech 2500S starter motor and fuse box questions Triumph 3
EWD For Sale ‘74 TR6 original starter Triumph Classifieds 0
M High-Torque Starter Austin Healey 10
W Generator and Starter Long Bolts Spridgets 0
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
R Bugeye Starter Switch Spridgets 7
B General MG Remote Starter Switch MG 6
S MGB MGB Starter Woes MG 13
M TR6 Starter Relay on a 73 TR6?? Triumph 22
edkap2002 TR6 starter motor advice Triumph 12
algot1901 1950 Prefect starter Other British Cars 1
Martinld123 High-Torque Starter Austin Healey 4
R TR6 Starter wiring question Triumph 6
S TR2/3/3A Rebuilding the early tr3 starter Triumph 5
RichB4493 TR2/3/3A TR3 not starting - Slow/Weak Starter Triumph 33
B TR4/4A High Torque Starter Wiring Triumph 9
algot1901 1950 Prefect Starter Other British Cars 10
S Starter Solenoid Nut Size for BJ8 Austin Healey 1
B High-Torque Starter Rattling Noise Austin Healey 3
EWD TR6 ‘74 TR6 Starter & Trans Cover Triumph 13
Jim_Stevens TR2/3/3A Starter/ring gear engagement Triumph 11
J TR6 72 TR6 starter problem Triumph 10
A TR2/3/3A Early TR3 starter (bomb style) bushings sizes Triumph 7
C MGA Change a pull starter to a push button system MG 6
Michael Oritt Starter Button Austin Healey 19
D WOSP Starter Austin Healey 9
DrEntropy MGB Replacement starter MG 7
steveg TR6 '74 - Where is the Starter Relay located? Triumph 1
AUSMHLY Crankshaft Starter Nut Austin Healey 10
K For Sale Triumph TR3 Bullnose Starter Triumph Classifieds 0
B TR4/4A Starter dog bolt Triumph 15
D Starter Austin Healey 26
red57 What starter is this? Austin Healey 6
S TR2/3/3A Correct Starter Triumph 4
Jim_Stevens TR2/3/3A No Ignition light and no starter Triumph 11
R TR6 Is this a starter issue? Triumph 6
Got_All_4 TR2/3/3A Gear reduction starter problems Triumph 5
John_Mc TR6 Starter not engaging consistently Triumph 9
R TR2/3/3A Starter rear plate 54 TR-2 Triumph 12
M TR6 Starter lagging issue Triumph 2
Gliderman8 Starter keeps running TVR 20
B TR2/3/3A Starter catches 50% of the time Triumph 15
