Question on rear brake drums BN6 wire wheel
BN6_2197
Gents,
I have some questions about original brake drums for BN6 with wire wheels:
* what is the original part number (mine have 1B.7526 / MOWOG)?
* what is the original color (mine are silver painted)?
* are they ribbed or not ribbed (mine are ribbed, some suppiers say ribbed version is for disc wheels)?
* what is the maximum inner radius (my radius is irregular and i wnt to bore them to get the radius regular)?
By the way: what is the best procedure to remove the brake shoes?
Volker
Deleted member 21878
for removing, i usually just grab one of the shoes and slide up off the adjuster. of course it helps to have it backed off all the way first. once you pop one out they come right off. if you are not changing the wheel cylinders i usually put a wire tie around it so the cylinder can not expand.
take some pictures as to the orientation of the shoes and how the springs are hooked before you start. good to have a reference if your memeory is as short as mine.
red57
It was always my understanding that the originals were ribbed (at least for wire wheels) but the suppliers have cheapened up and only offer the smooth as replacements...Look at the link Steve posted from Moss, the drawing clearly shows ribbed for wire wheels but if you click on the drum in the parts listings below, the picture is of a smooth drum for wire wheels. I do believe the ribbed ones cool better.
Moss doesn't list a drum for the disc wheels and I'm not sure that they are available anywhere else. I have bolt on wheels and before I changed to discs I used wire wheel drums and an aluminum spacer to get the correct wheel mounting surface - a lot less unsprung weight (and you can find the ribbed ones sometimes on ebay)
Dave
BN6_2197
BN6_2197
Gents,
can somebody comment on the original color and the max radius for booring?
Volker
I tried to get a local shop/store to turn the drums on my BJ8. They could not find a max. diameter/min. thickness--whatever they use--for the drums and refused to turn them; said here in California it is a crime (felony?) to do so without a spec. I believe the original/correct color is a satiny silver similar to the color used on painted wheels, but I painted my BJ8's drums black because it really makes the chrome wires stand out.
elrey
My 62 mkll side shift tri-carb (built Nov. 61) has wire wheels with silver painted ribbed rear drums.
BN6_2197
BN6_2197
My local garage is willing to tunr them but they asked for a max diameter since the radius of the brake shoes must fit after processing the drums.
red57
The max dia. call-out is to make sure the drums are still safe and not overly weakened by removing material, and has nothing to do with the shoe arc.
Your shop should also be able to re-arc the shoes - that is normally what is done, drums turned and then shoes re-arched to match.
Dave
CraigC
Bob what they told you was incorrect. They probably never had anyone that was a licensed inspector in their employ
A direct quote from the May 2015 version of the California Brake Adjuster Handbook regarding certification of a brake system states:
"Before you reline any brakes, measure the drum diameter with a micrometer. It is recommended that you do not machine a drum to exceed the maximum diameter as identified on the drum. It is also recommended that an older drum not identified with a maximum drum diameter should not be machined to exceed 0.060 inches inside diameter over its original size. If the vehicle or brake parts manufacturer provides a specification,such specification may be used. This recommendation applies to light-duty passenger vehicles, including light trucks."
Having once possessed a California Brake Inspection License, this has been the standard for many decades. Personally, I would feel more comfortable sticking to under .030" above the original diameter.
CraigC
Dave
You are not likely to find any shop today that has the equipment to re-arc linings. The last time I had access to such equipment was nearly 30 years ago AND we were not allowed to use it due to lack of dust collection equipment necessary to prevent any asbestos dust from becoming airborne. While today's linings should not use any asbestos, who really knows if that is the case when the linings likely come from China.
Most reputable brake shoe suppliers manufacture their linings to be arced for a drum that is .030" oversize. I would not assume that the suppliers of brake linings for our vehicles follow that standard. It just means that there will be a longer "break-in" period for the drum brakes as they will have to wear in to match the drum diameter.
Thanks for the info, Craig. I'll print out a copy of the relevant passage and show to the shop, and if they won't do it I'll find a shop who will (maybe the shop couldn't find the original diameter spec, and gave me a line of manure).
ps. The handbook looks to be good bedtime reading.
A TR2/3/3A Newbie Question regarding Girling rear brake cylinder Triumph 5
bugedd RX7 rear axle and brake question Spridgets 2
T Rear brake clyinder orientation question Triumph 4
J Question on rear brake mounting plates Spridgets 5
T TR2/3/3A tr3 rear brake band installation question Triumph 7
tomshobby rear brake line question Spridgets 17
bcbug 76 midget rear brake assemble question Spridgets 2
jlaird Question-rear brake shoes Spridgets 7
jjbunn Rear brake question Triumph 11
B Rear Brake Switchover Question Spridgets 6
JPSmit Quick rear brake question Spridgets 56
sparkydave Rear brake cylinder question Spridgets 7
White79MGB TR2/3/3A TR3 Rear Brake Question Triumph 11
R Rear Brake Question Austin Healey 1
CharlieCarpenter Rear Brake Question Austin Healey 6
D Rear spring length question. Austin Healey 6
W TR2/3/3A Why a PO cut these holes in rear floor? Also, question re dealing with captive nuts Triumph 6
K TR2/3/3A Odd question re: rear axle hitting fuel line? Triumph 4
S Question regarding NOS vs New rear leaf spring bushings Austin Healey 3
KVH TR4/4A Here'a Another Rear Axle Hub Question/Problem Triumph 7
Popeye TR4/4A TR4A solid axle rear leaf spring question Triumph 14
bugedd Rear trailing arm question Spridgets 2
J TR2/3/3A Interior rear wheel arch covers question. Triumph 2
PAUL161 MGB Early Banjo Rear Question MG 8
R TR2/3/3A Rear axle tab washer question Triumph 8
Griz Rear Wiring Harness Question Austin Healey 6
TR4nut TR2/3/3A Girling 10" Rear Brakes question Triumph 29
JPSmit Rear - Transmission seal question Spridgets 8
J Possibly stupid question about drivetrain / rear end Spridgets 11
J Rear Spring question ?? Triumph 6
J Rear Hub/Bearing Question Spridgets 4
Willie_P Quick question: rear diff TR 3/4 Triumph 6
JohnnyMead TR2/3/3A TR3A Rear Wheel Cyl Assembly Question Triumph 5
bugedd Rear travel question Spridgets 17
M Rear Trailing arm Shims Question [pic] Triumph 2
JPSmit Rear Hub Question Spridgets 2
vette Next Question on Rear Springs Mounting Austin Healey 2
Pete_Chadwell TR6 TR6 Rear Hub question, plus gearbox vibe Triumph 8
R Rear main seal question. Spridgets 29
D Spitfire spitfire rear spring question Triumph 2
SherpaPilot TR6 TR6 Rear Axle Bearing Question Triumph 10
D Spitfire 1976 spitfire rear bumper question Triumph 3
chrpark rear view mirror - another 'holes' question Spridgets 6
bigbadbluetr6 TR6 TR-6 rear tube shock conversion question Triumph 20
M TR2/3/3A TR3 rear shock link question Triumph 4
eschneider Spitfire another Spitfire question - stuck rear hubs Triumph 26
D Rear wheel cylinder replacement question BT7 Austin Healey 6
