Rear Brake Question
Ray Smith
Are the two "steady posts", the threaded pins that are screwed into the brake backing plate, intended to make contact with the brake shoe? What purpose do the little felt tips on the ends of the steady posts serve?
Ray
Keoke
Those little felt pads are called steady bushes they should align the surface of the shoe to coincide with the drum and dampen clatter. A little antisieze compound or white grease on them wiil improve their function and they should be adjusted to just touch the webb of the shoe.--Fwiw---Keoke
BN6_2197 Question on rear brake drums BN6 wire wheel Austin Healey 15
A TR2/3/3A Newbie Question regarding Girling rear brake cylinder Triumph 5
bugedd RX7 rear axle and brake question Spridgets 2
T Rear brake clyinder orientation question Triumph 4
J Question on rear brake mounting plates Spridgets 5
T TR2/3/3A tr3 rear brake band installation question Triumph 7
tomshobby rear brake line question Spridgets 17
bcbug 76 midget rear brake assemble question Spridgets 2
jlaird Question-rear brake shoes Spridgets 7
jjbunn Rear brake question Triumph 11
B Rear Brake Switchover Question Spridgets 6
JPSmit Quick rear brake question Spridgets 56
sparkydave Rear brake cylinder question Spridgets 7
White79MGB TR2/3/3A TR3 Rear Brake Question Triumph 11
CharlieCarpenter Rear Brake Question Austin Healey 6
KVH General TR Rear Brake Shoe Orientation Triumph 12
BN6_L1232 Rear Disc Brake Installation Instructions Austin Healey 3
J TR2/3/3A TR3A Girling 9" Rear Brake Initial Adjustment Triumph 9
R TR6 Rear brake wheel cylinder fitment Triumph 5
D Rear Brake Drum Nuts Austin Healey 15
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
G Rear Brake Adjustment Austin Healey 30
Kurtis TR4/4A Rear wheel brake cylinder replacement Triumph 1
J TR6 1973 TR6 Rear Brake Operation Questions Triumph 4
R TR2/3/3A Lockeed rear brake banjo fittings. Triumph 7
K MG Midget Early and Later model rear brake shoes.... Spridgets 2
A AH 3000 rear disc brake conversion Austin Healey 28
K TR2/3/3A Rear brake wheel cylinder attachment again Triumph 1
J For Sale Triumph TR3 rear differential and rear brake assembly - Northern Illinois Triumph Classifieds 1
Gliderman8 TR6 Removing Left Rear brake line... help! Triumph 9
Got_All_4 General TR Is there a special tool needed for rear brake cylinders Triumph 14
histerical Wanted WTB Set of Later Spridget Rear Brake Backing Plates Spridgets Classified 0
warwick-steve Rear Brake cylinder connection Austin Healey 12
Michael Oritt Moss Motors rear brake "set" Austin Healey 11
J Spitfire Spitfire Rear Brake Bleeding Triumph 9
vette Tire Size and Improving Rear Brake Drums Austin Healey 17
regularman Gear leaking from axle housing into rear brake drum Spridgets 3
nevets BN6 rear brake pipes Austin Healey 15
nevets stuck rear brake drum Austin Healey 18
Jim_Gruber Reinstalling Brake Hubs and Wheel Hubs in Rear. Spridgets 5
Jim_Gruber Brake Lines for Bugsy - What do I need for a Flaring Tool / Rear Discs for Bugsy Spridgets 39
C Help diagnosing rear brake issues... Austin Healey 20
W BN1 vs. BN2 rear brake lines / pipes Austin Healey 4
A rear brake drum too tight after rebuild Austin Healey 3
SASSAMON TR2/3/3A Rear Brake Cylinder Recommendations Triumph 2
Jim_Gruber BE Rear Brake Spring Orientation Spridgets 13
M suggestions on vendor Rear brake rebuild Spridgets 15
Dave Richards Rear Brake Cylinders not Fitting Hand Brake Lever Austin Healey 2
