This is a regular topic in 6-Pack and I usually sit back with my mouth shut until I can't take it anymore. With the exception of
TR6Bill's famous cracked bracket picture, everything else I've read is pretty much here-say. As you'll see in my conversion pictures and write up, neither the "drill through the body conversion (11 years on car) or the "re-use old brackets conversion (2 years on car now) have caused any damage. So here's a "cut-n-paste" from my 6-Pack post.
<span style="font-style: italic">This one gets beaten to death every time the subject comes up.
I have the Blind Moose conversion along with the brackets to support the conversion. Here's my feelings, again, on the matter. Everyone's car is in different shape with regard to frame condition. We've seen guys with great looking frames only to discover that under the Tee Shirt is a rust bucket. Same for TA mounting points and diff mounting points. Paint over bad repair work can cover a multitude of sins. Before doing ANY mod that attaches to the frame, you need to do a thorough inspection and then make your decision.
The Blind Moose conversion was designed by Herman van Den Akker (of 5 speed conversion fame) who used it for a long time with no problems. His auto-cross friends quickly grabbed the conversion and promptly broke the old shock mount! Herman then designed the added bracket which the auto-x guys have been using ever since with no problems.
I'm not smart enough to know if tube shocks are better then the old lever shocks but I am smart enough to know that nothing should be attached to our 40 year old frames without very careful inspection be it: tube shocks, GP adjustable TA brackets, a Nissan diff or even new diff poly or nylatron bushings.</span>
