TR2/3/3A TR3 Rear Overider Bracket "distance tube"?
bgbassplyr
Re: TR3 Rear Overider Bracket "distance tube"?
Mine were twice as long as from one end to the center, lol.
Sorry I don't have the answer you are looking for. Someone will come along soon.
M_Pied_Lourd
I can measure it tomorrow Karl if no one answers before then. I have mine off the car.
Cheers,
M. Pied Lourd
K
karls59tr
Bronze
That would be great. A friend is fabricating his own distance tubes on his 3 and needed to know.
mgedit
I have one of the "improved" ones ... it is 4.25 inches long. The original one I have is installed, but I think I compared them at one point, and they were the same length. Cheers, Mike
M_Pied_Lourd
Yes Mike, they are the same length. So 4.25 inches it is.
Cheers,
Tush
K
karls59tr
Bronze
Thanks for the info Mike and Tush. There are approximately 20 TR3's in Manitoba according to one guesstimate. Quite a few restored and some project cars. I was surprised that there were that many all tolled. Any idea how many 3's are on the road in Ontario? Cheers Karl
M_Pied_Lourd
Hi Karl,
Well, looking through the members database for the Toronto Triumph Club we have 8 TR2's and 37 TR3-3B's listed. Got to be close to 100 in Ontario I would guess.
Cheers,
David
K
karls59tr
Bronze
Wow. Didn't realize ther were that many on the road there. I guess there might be another 50 in Alberta and 100 in BC? Time for a TR3 Convention. :smile:
G
Are we using standard or metric to get these numbers?
mgedit
In terms of TR3s in OVTC, I think we have 11 in various states of repair. Cheers, Mike
K TR2/3/3A TR3 rear overider distance from body? Triumph 3
Donald1107 TR2/3/3A TR3 Rear Shocks Triumph 11
B Wanted TR3 Hardtop Rear Stiffener Brackets Triumph Classifieds 0
J TR2/3/3A TR3 Rear seat Triumph 11
K For Sale TR3 rear rebound brackets Triumph Classifieds 0
J For Sale Triumph TR3 rear differential and rear brake assembly - Northern Illinois Triumph Classifieds 1
E For Sale Tr3 rear axle, rear end Triumph Classifieds 6
K For Sale TR3 rear cockpit center capping Triumph Classifieds 0
J Wanted Need tr3 rear axle housing Triumph Classifieds 0
D TR2/3/3A TR3 Engine dumping Coolant out its rear end - HELP Triumph 5
A TR2/3/3A Newbie wrestling with TR3 rear wheel studs Triumph 3
Tinkerman TR2/3/3A TR3 A REAR WING BOLTS order of assembly? Triumph 3
Got_All_4 TR2/3/3A Tr3 rear differential seal Triumph 7
J TR2/3/3A Tramp bar for rear of TR3 or?? Triumph 7
mgedit TR2/3/3A Steady Springs Rear Brakes 56 TR3 Triumph 0
jfarris TR2/3/3A Wanted - TR3 Monza Muffler - Rear Section Only Triumph 1
M TR2/3/3A TR3 overdrive trans rear speedi sleeve Triumph 6
K TR2/3/3A TR3 Exhaust header's proximity to rear of generator? Triumph 4
J TR2/3/3A Strange fiberboard panel behind rear seat in TR3 Triumph 10
1937dodge TR2/3/3A Anyone have any photos of TR3's sporting rear finned aluminum brake drums? Triumph 8
T TR2/3/3A TR3 Rear wheel cylinder attachment clips Triumph 6
mgedit TR2/3/3A Rear Drum Brakes 56 TR3 Triumph 2
rckuhlman TR2/3/3A TR3 Castle Nut on Right Rear Axle Triumph 3
K TR2/3/3A TR3 4:11 gears in rear Diff Triumph 6
S TR2/3/3A rear brakes tr3 Triumph 1
S TR2/3/3A tr3 rear main Triumph 24
M TR2/3/3A Topping off rear shocks on TR3 Triumph 11
Kleykamp TR2/3/3A TR3 rear fender bolts Triumph 2
RickAnderson TR2/3/3A Wanted: TR3 Rear Bumper Overrider - any condition. Triumph 2
M TR2/3/3A TR3 rear axle hub gasket ???? Triumph 4
S TR2/3/3A rear fender vinyl tr3 Triumph 6
mgedit TR2/3/3A Rear capping 56 TR3 Triumph 4
M TR2/3/3A Topping off rear shocks on TR3 Triumph 13
Kleykamp TR2/3/3A TR3 rear fender needed Triumph 18
Tr3aguy TR2/3/3A Rear Lettering TR3 post 60000 Triumph 3
luke44 TR2/3/3A TR3 Rear Bumper Overriders - Upside Down? Triumph 12
T TR2/3/3A The light came on: my TR3 rear apron. Triumph 12
S TR2/3/3A tr3 rear interior panels Triumph 6
J TR2/3/3A TR3 Rear Apron Replacement Triumph 4
J TR2/3/3A stainless steel rear spring pins for TR3 Triumph 19
O TR2/3/3A TR3 Rear Main Seal Triumph 5
A TR2/3/3A More TR3 Rear main seal problems. Please Help!! Triumph 8
J TR2/3/3A '56 TR3 Brakes and rear axle advice Triumph 7
tinman58 TR2/3/3A Rear main seal TR3 Triumph 11
O TR2/3/3A TR3 Rear Turn lights Versus Rear Stop Tail lights? Triumph 5
S TR2/3/3A tr3 brakes-Rear wheel Triumph 2
S TR2/3/3A rear brake lines tr3 Triumph 3
S TR2/3/3A rear axle grease fitting tr3 Triumph 6
J TR2/3/3A TR3/3a Girling rear axle... Triumph 4
