TR2/3/3A Rear main seal TR3
tinman58
I am going to start reassembly of the motor this week. But British Parts Northwest where I got the upgraded main seal kit 3 years ago are out of the replacement seal. I think that it a standard ford seal, But does anybody know for sure what part # it is from Napa ? I can't wait three weeks for BPNW to get it in stock.
toysrrus
Hi Dan,
Why not try the other "BIG" 3; Moss, VB, TRF?
Russ
tinman58
tinman58
Do all the "big three sell the same kit? I am concerned that they might be a different seal.
Geo Hahn
Are you going to be using a seal that requires machining of the crank? If so and if the machining has not occurred you may want to consider the newer kit that requires no machining.
I haven't used either but am of the opinion that a no-cut approach would be preferable.
TR3driver
Great Pumpkin - R.I.P
:iagree:
Especially considering how many people have found that the "machining required" seal leaks worse than the original. And I just saw an announcement from Joe (the North American distributor for the "no machining" seal) that he has caught up with the backlog and has 5 kits on the shelf. So right now would be a good time to order.
The "no machining" kit is actually two seals in one (belt and suspenders) as it leaves the original scroll seal functional (and includes the correct mandrel to make the original seal work properly).
TR4nut
Jerry said:
does he have a website where he sells the new seal?
Here it is:
Vintage Racer
Joe posts frequently (and is a founding member) on the Friends of Triumph mailing list - I always just email him on orders and he's quick to respond.
tinman58
tinman58
I am going to call the machine shop first thing in the morning, I hope that they haven't machined it yet. I like the idea of "no machining" and for $100 bucks and no leak.....
PatGalvin
Good luck Dan
My "modern oil seal" leaked terribly. Hope you can save your crank and use one of these new Joe Alexander seals. Otherwise, I'll be watching closely (hopefully, not watching the trail behind your car) as you install and run on your new BPNW seal (same one I have).
Pat
MGTF1250Dave
Aloha Dan,
I recently installed the "no machining" rear seal during my engine rebuild. It is a very straight forward install and I am very pleased with its performance. As Randall points out this kit gives you two rear seals.
tinman58
tinman58
I was abel to stop the machine shop from turning down the crank this morning. I am going to get the double seal from Joe . Thank you for the info on the new seal. Geo Han, Randell,Randy, Pat et all.
tinman58
tinman58
E-mailed Joe! One is on the way
J Rear Main Seal Kit Austin Healey 1
S TR2/3/3A rear main seal is leaking Triumph 13
D rear main seal Austin Healey 13
T BJ7 Slipping Clutch? rear main seal? Austin Healey 11
Gerard 1098 10CC rear main seal conversion Spridgets 4
W A-40 Somerset - Leakage at Rear Main Bearing / Oil Seal Other British Cars 0
KVH General TR Rear Main Seal--Minor Problem Triumph 4
Editor_Reid Rear Main Seal for BN2 Austin Healey 12
J BJ8 rear main seal kit - is it necessary and worth the risk to install? Austin Healey 33
T TR4/4A Oil drain hole from rear crank seal/rear main cap Triumph 3
C TR4/4A Rear main seal Triumph 36
S TR2/3/3A rear main seal Triumph 20
E 100 4 Does anyone recognize this rear main seal mod? Austin Healey 12
KVH TR4/4A Viton Rear Main Seal Triumph 12
C Rear Main Seal Leak with Moss Retrofit Austin Healey 21
TR3driver TR4/4A "Mad Marx" rear main seal for TR2-4A once again available Triumph 10
KVH TR4/4A Rear Main Seal Leak TR4A Triumph 1
B Rear main seal kit Spridgets 3
O TR2/3/3A TR3 Rear Main Seal Triumph 5
A TR2/3/3A More TR3 Rear main seal problems. Please Help!! Triumph 8
P how to replace rear main seal in 1500 midget Spridgets 2
R Rear main seal question. Spridgets 29
MGTF1250Dave Improved TR Rear Main Seal Kit Triumph 19
KVH TR4/4A Rear Main Seal TR4A Triumph 17
B 1970 XKE 4.2 rear main seal Jaguar 2
M TR2/3/3A TR3 crankshaft rear main seal opinions wanted. Triumph 8
58Custom 1275 Rear Main Seal Kit- - seek info Spridgets 2
glemon Rear engine main seal review Triumph 7
J Moss rear main seal. Austin Healey 5
TimK Rear Main Seal Kit Installation Austin Healey 24
M Rear main Scroll Seal Triumph 11
A Rear Main Oil Seal Conversion - Bearing Cap debris Austin Healey 5
V TR6 TR6 Rear Main Seal Triumph 17
aaronclark TR2/3/3A TR3 Rear Main Seal Questions Triumph 7
T TR2/3/3A Tr3A rear main seal conversion - adviced needed Triumph 11
spartan0199 rear main seal kit 833-145 Austin Healey 12
A TR6 TR6 rear main seal housing special bolt ?? Triumph 1
fad64b TR2/3/3A Rear main seal TR3 Triumph 12
S TR2/3/3A tr3 rear main seal Triumph 6
A TR6 TR6, Best front and rear main seal ??? Triumph 0
C rear main oil seal Austin Healey 4
G TR4/4A And the fun continues...rear main leak Triumph 5
B General MG Solutions for topical MG rear main leak? MG 7
Martinld123 Drain Pipe Rear Main Bearing Cap BN2, remove? Austin Healey 2
Gerard 1098 "10CC" rear main Spridgets 0
S TR2/3/3A tr3 rear main Triumph 24
TraceZ rear main leaks Spridgets 3
B rear main Spridgets 5
B rear main puller Austin Healey 6
