General TR Rear Main Seal--Minor Problem
KVH
I just tried unsuccessfully to install the Viton rear main seal, so I thought it best to start a new thread due to the specific nature of the problem. I'll try again and get it, but here is what happened:
a) The holes in one of the halves of the assembly are such a tight fit to the holes in my engine block, that I'm scoring the internal bore of two of the screw holes in the fitting just tightening it in, and there's no sense in proceeding since when I'm done the half in question will have no play or ability to achieve adjustment. In fact, it's going in with one side too high; and
b) All the fiddling allowed the silicone to start setting too quickly and I don't trust the bond.
I'm inclined to use Wellseal the next go around, but what do I do with that rear main seal?
I can see gently filing two of the screw holes just a slight bit larger with a round file. I don't want to drill anything.
I have to assume I'm not the first to encounter this issue? Filing the screw holes a bit should be no big deal?
Thanks in advance for any advice.
TR3driver
Great Pumpkin - R.I.P
Filing the holes should be no problem, but check the fit onto the mandrel first. It may be that the casting got distorted during shipping or something.
sp53
Are you talking about the felt and gasket shellac or where the two halves of the rear main meet KVH? It has been a year or so since I put a mad max seal in, so I posted what the people said and they really helped me.
TR4nut
You are using a new blue anodized housing correct? If so I think filing is appropriate but as Randall notes check the mandrel. When the kit first came out it reused stock housings but the new casting may not have the holes sized quite right.
KVH
KVH
Yes, I have the new, blue rear main seal housings, I assume aluminum. I found a post from Christian Marx mentioning use of silicone to seal where the "flats" of the housing meet the block and bearing cap. I think the old school is Wellseal which I'd prefer to use. In fact, the post mentioning silicone showed the old style gray aluminum. I could also use Permatex High Tack for the sealer. High Temp Red Silicone didn't seem to adhere well to the highly polished blue aluminum surfaces of the new style main seal.
As for the felts, those are another issue. I plan to soak those in Permatex High Tack or Wellseal, mainly since that's what I have in my little shop.
J Rear Main Seal Kit Austin Healey 1
S TR2/3/3A rear main seal is leaking Triumph 13
D rear main seal Austin Healey 13
T BJ7 Slipping Clutch? rear main seal? Austin Healey 11
Gerard 1098 10CC rear main seal conversion Spridgets 4
W A-40 Somerset - Leakage at Rear Main Bearing / Oil Seal Other British Cars 0
Editor_Reid Rear Main Seal for BN2 Austin Healey 12
J BJ8 rear main seal kit - is it necessary and worth the risk to install? Austin Healey 33
T TR4/4A Oil drain hole from rear crank seal/rear main cap Triumph 3
C TR4/4A Rear main seal Triumph 36
S TR2/3/3A rear main seal Triumph 20
E 100 4 Does anyone recognize this rear main seal mod? Austin Healey 12
KVH TR4/4A Viton Rear Main Seal Triumph 12
C Rear Main Seal Leak with Moss Retrofit Austin Healey 21
TR3driver TR4/4A "Mad Marx" rear main seal for TR2-4A once again available Triumph 10
KVH TR4/4A Rear Main Seal Leak TR4A Triumph 1
B Rear main seal kit Spridgets 3
O TR2/3/3A TR3 Rear Main Seal Triumph 5
A TR2/3/3A More TR3 Rear main seal problems. Please Help!! Triumph 8
tinman58 TR2/3/3A Rear main seal TR3 Triumph 11
P how to replace rear main seal in 1500 midget Spridgets 2
R Rear main seal question. Spridgets 29
MGTF1250Dave Improved TR Rear Main Seal Kit Triumph 19
KVH TR4/4A Rear Main Seal TR4A Triumph 17
B 1970 XKE 4.2 rear main seal Jaguar 2
M TR2/3/3A TR3 crankshaft rear main seal opinions wanted. Triumph 8
58Custom 1275 Rear Main Seal Kit- - seek info Spridgets 2
glemon Rear engine main seal review Triumph 7
J Moss rear main seal. Austin Healey 5
TimK Rear Main Seal Kit Installation Austin Healey 24
M Rear main Scroll Seal Triumph 11
A Rear Main Oil Seal Conversion - Bearing Cap debris Austin Healey 5
V TR6 TR6 Rear Main Seal Triumph 17
aaronclark TR2/3/3A TR3 Rear Main Seal Questions Triumph 7
T TR2/3/3A Tr3A rear main seal conversion - adviced needed Triumph 11
spartan0199 rear main seal kit 833-145 Austin Healey 12
A TR6 TR6 rear main seal housing special bolt ?? Triumph 1
fad64b TR2/3/3A Rear main seal TR3 Triumph 12
S TR2/3/3A tr3 rear main seal Triumph 6
A TR6 TR6, Best front and rear main seal ??? Triumph 0
C rear main oil seal Austin Healey 4
G TR4/4A And the fun continues...rear main leak Triumph 5
B General MG Solutions for topical MG rear main leak? MG 7
Martinld123 Drain Pipe Rear Main Bearing Cap BN2, remove? Austin Healey 2
Gerard 1098 "10CC" rear main Spridgets 0
S TR2/3/3A tr3 rear main Triumph 24
TraceZ rear main leaks Spridgets 3
B rear main Spridgets 5
B rear main puller Austin Healey 6
