TR2/3/3A TR3 Rear Apron Replacement
Jprmm15
Member
HELP!!
Took the body off the frame and the rear apron from the spare tire well down is bad, real bad. I know this isn't anything you guys haven't dealt with before. Any leads on replacement panels without spending a grand through the usual leads(Moss/TRF)? Rumor has it there is someone in the midwest that makes good half rear apron's for a good price. Any advice so I don't have to piece meal this thing together? Thanks in advance!!
JR
M_Pied_Lourd
Hi JR,
Yes, a difficult piece to repair. I was in the same boat as you not too long ago and had to make a decision. I was lucky and ended up finding a new valence on ebay from a vendor in France. When I recieved it, it still has the Roadster Factory Sticker on it. I got it for about 1/2 the price it is listed in their catalogue.
I was looking at the repair sections as well from Victoria British but they are very expensive as well for what they are.
Reagardless of what you end up doing, you will still have some fitment issues even with the new metal.
I was considering Radford panel in the UK at one point as well.
https://www.radfordpanel.com/tr2.htm
Good luck with your project.
Cheers,
M. Pied Lourd
J
Jprmm15
Member
I will send them an email to check pricing. If only I could be so lucky and find a piece on ebay like that. Thanks for your reply.
J
Jprmm15
Member
Thanks. Just heard back from Radford Panel and the piece I need is only 240 dollars. Thanks for the tip. Of course, I haven't gotten a shipping quote yet. Ouch.
M_Pied_Lourd
Good to hear. Please post a pic when you recieve your patch panel.
Cheers,
M. Pied Lourd
ps hope the shipping is not too bad.
T TR2/3/3A The light came on: my TR3 rear apron. Triumph 12
G TR2/3/3A TR3 rear apron panel Triumph 2
Donald1107 TR2/3/3A TR3 Rear Shocks Triumph 11
B Wanted TR3 Hardtop Rear Stiffener Brackets Triumph Classifieds 0
J TR2/3/3A TR3 Rear seat Triumph 11
K For Sale TR3 rear rebound brackets Triumph Classifieds 0
J For Sale Triumph TR3 rear differential and rear brake assembly - Northern Illinois Triumph Classifieds 1
E For Sale Tr3 rear axle, rear end Triumph Classifieds 6
K For Sale TR3 rear cockpit center capping Triumph Classifieds 0
J Wanted Need tr3 rear axle housing Triumph Classifieds 0
D TR2/3/3A TR3 Engine dumping Coolant out its rear end - HELP Triumph 5
A TR2/3/3A Newbie wrestling with TR3 rear wheel studs Triumph 3
Tinkerman TR2/3/3A TR3 A REAR WING BOLTS order of assembly? Triumph 3
Got_All_4 TR2/3/3A Tr3 rear differential seal Triumph 7
J TR2/3/3A Tramp bar for rear of TR3 or?? Triumph 7
mgedit TR2/3/3A Steady Springs Rear Brakes 56 TR3 Triumph 0
jfarris TR2/3/3A Wanted - TR3 Monza Muffler - Rear Section Only Triumph 1
M TR2/3/3A TR3 overdrive trans rear speedi sleeve Triumph 6
K TR2/3/3A TR3 Exhaust header's proximity to rear of generator? Triumph 4
J TR2/3/3A Strange fiberboard panel behind rear seat in TR3 Triumph 10
1937dodge TR2/3/3A Anyone have any photos of TR3's sporting rear finned aluminum brake drums? Triumph 8
T TR2/3/3A TR3 Rear wheel cylinder attachment clips Triumph 6
mgedit TR2/3/3A Rear Drum Brakes 56 TR3 Triumph 2
rckuhlman TR2/3/3A TR3 Castle Nut on Right Rear Axle Triumph 3
K TR2/3/3A TR3 4:11 gears in rear Diff Triumph 6
S TR2/3/3A rear brakes tr3 Triumph 1
S TR2/3/3A tr3 rear main Triumph 24
M TR2/3/3A Topping off rear shocks on TR3 Triumph 11
Kleykamp TR2/3/3A TR3 rear fender bolts Triumph 2
RickAnderson TR2/3/3A Wanted: TR3 Rear Bumper Overrider - any condition. Triumph 2
M TR2/3/3A TR3 rear axle hub gasket ???? Triumph 4
S TR2/3/3A rear fender vinyl tr3 Triumph 6
mgedit TR2/3/3A Rear capping 56 TR3 Triumph 4
M TR2/3/3A Topping off rear shocks on TR3 Triumph 13
Kleykamp TR2/3/3A TR3 rear fender needed Triumph 18
K TR2/3/3A TR3 rear overider distance from body? Triumph 3
Tr3aguy TR2/3/3A Rear Lettering TR3 post 60000 Triumph 3
luke44 TR2/3/3A TR3 Rear Bumper Overriders - Upside Down? Triumph 12
S TR2/3/3A tr3 rear interior panels Triumph 6
K TR2/3/3A TR3 Rear Overider Bracket "distance tube"? Triumph 10
J TR2/3/3A stainless steel rear spring pins for TR3 Triumph 19
O TR2/3/3A TR3 Rear Main Seal Triumph 5
A TR2/3/3A More TR3 Rear main seal problems. Please Help!! Triumph 8
J TR2/3/3A '56 TR3 Brakes and rear axle advice Triumph 7
tinman58 TR2/3/3A Rear main seal TR3 Triumph 11
O TR2/3/3A TR3 Rear Turn lights Versus Rear Stop Tail lights? Triumph 5
S TR2/3/3A tr3 brakes-Rear wheel Triumph 2
S TR2/3/3A rear brake lines tr3 Triumph 3
S TR2/3/3A rear axle grease fitting tr3 Triumph 6
