Thanks for posting John, the TLAR system on mine is very similar to yours. On the little piece above the wheel well it was only screwed at the outer edge huh? I did find a screw on the one side that was on the inside in the middle, but again, it is difficult to say what the hole was used for. Your car is going to be very nice when you are done. You really should win some shows with that plus it would not be just a wallet comparison because you did the work, good job.
