TR2/3/3A Push switch for washer fluid pump
Got_All_4
Recently installed a electric washer pump under the dash with the traditional Tudor bottle in the engine compartment. Did it such a way that it is not visible. Now I'm looking for a momentary switch that when pushed it engages and turns off when released. Like a TR3 starter switch. I do want to keep it looking proper with a traditional Lucas black knob too. Been searching the net and eBay with no luck. Any suggestions?
Foura
I converted the pump washers on the 4A to electric operation. I used a heater switch (on/off) with the original washer pump knob. You can start the washers up and get a bit of water on the screen before you start the wipers. Rimmers list a single speed wiper switch for the 3A which could do the trick.
When I have the Navigator/Speed Limiter with me, I find that I have automatic washers AND wipers while I concentrate on steering. She has a strong self preservation instinct.
TomMull
Why not use one of those?
justin_mercier Source for a push/pull DPDT switch? Triumph 13
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
K TR2/3/3A Clutch and Brake Master Cylinder push rod stop bolts? Triumph 15
C MGA Change a pull starter to a push button system MG 6
PAUL161 T-Series Bent Push Rods MG 34
R J-H no longer needs a push! Other British Cars 6
K Restoring Horn Push Button Austin Healey 12
Joe Reed General MG Early Midget horn push on Personal wood rim steering wheel... MG 3
Patrick67BJ8 Brake Pedal Vary Hard to Push Down and Brakes feel like there's no Booster on my BJ8 Austin Healey 27
Lukens TR2/3/3A Anyone ever see a push/pull throttle mounted on the dash? Triumph 4
T timmers 67, push rods and lifters Austin Healey 4
Martinld123 Push button on top of new H6 carbs float bowl from Moss Austin Healey 3
Joe Reed MGB Clutch Slave push rod...past its prime MG 2
KVH TR4/4A Rocker Shaft Lubrication, and Issue with Push Rods Triumph 1
GTP1960 TR2/3/3A Clutch slave cylinder / push rod alignment Triumph 10
F BT7 3000 - Push rod problem on clutch slave cylinder Austin Healey 7
S TR2/3/3A copper gasket sealer and push rods Triumph 10
J Healey 100 -- Broken rocker and bent push rods !!! Austin Healey 7
Perrymip TR2/3/3A Starter Solenoid Push Button Triumph 11
tahoe healey Clutch master cyl. push rod Austin Healey 2
P Grounding of Horn Push-Bugeye Spridgets 4
Kleykamp TR2/3/3A hollow push rods ? Triumph 6
DornTRoriginal TR2/3/3A My Push Rod Situation Triumph 12
SMGoose Push rod return spring Triumph 7
M stainless push button snaps for convt boot Austin Healey 2
F Replacing the horn push adjustable steering wheel Austin Healey 7
T TR2/3/3A TR3b Master cylinder push rod clevis Triumph 2
C Wiring new Mota Lita horn push into my MG Midget Spridgets 6
Donalvin removal of push-pull dash control buttons Triumph 5
S TR4/4A Leaking push rod tubes, TR4a Triumph 7
BugeyeNJ58 Push or Pull - Electric Fan Spridgets 3
T Bugeye clutch MC push rod length Spridgets 6
G Push'in Springtime Spridgets 3
Mickey Richaud Brake M/C Push Rod Spridgets 8
Mickey Richaud Brake M/C Push Rod MG 2
6 elect. fan..push or pull Triumph 16
S TR2/3/3A tr3 unsoldered push in connectors Triumph 3
bighealeysource Push the Dot post on dash of BN6/BN7 Austin Healey 1
K M/C push rod adjustments Spridgets 4
R clutch push rod replacement question Spridgets 6
longbridgehealey horn push Spridgets 3
T TR4/4A ? on TR4A clutch shaft - wear @ push-rod attachment Triumph 6
wangdango TR6 '76 tr6 horn push Triumph 1
mikecyc72usa The final push Triumph 0
I push rod question Triumph 8
drooartz Clutch push rod Spridgets 13
A TR4/4A TR-4 cylinder head push rod tubes Triumph 2
livinginthepast Stupid Q dejour - horn push/badge won't stay put! Spridgets 14
ncbugeye Completed push fuel pump installation Spridgets 3
ncbugeye Push SU fuel pump in Bugeye Spridgets 8
