Source for a push/pull DPDT switch?
justin_mercier
I want to replace the hazard switch in my TR6 and Dan Masters says to just use a DPDT switch without a center off position to fix all your problems... the only problem I'm having is I can only find DPDT switches in 'toggle' form, and I would like to use a push/pull switch instead.
I have searched all over, and I'm almost to the point where I'll make a push/pull switch out of normal toggle switch by adding pivot hinges to the end of the toggle and mounting it horizontally behind the dash.
TR3driver
Great Pumpkin - R.I.P
One solution might be to use a simple on/off switch, and a DPDT relay (or pair of SPDT relays).
Or poke around on eBay and find a reproduction of the original for a reasonable price. I managed to find one for $25 a few years ago. Not sure if it would be correct for your TR6, but it is a push-pull DPDT switch.
BTW, I'm pretty sure Dan was thinking of a toggle switch. I've never seen a push-pull switch with "center off".
71MKIV
believe it or not your flap probably has one on the shelf.
They have been sold since forever as hazard switches. Beige knob, push pull dpdt switch.
trrdster2000
Looks like the heater blower switch on the TR6. Hole size might be the problem.
Wayne
justin_mercier
justin_mercier
It should not have a center off, the hazard switch is a DPDT switch without a center off, but the original lucas ones suck, real bad =D
The one on ebay there is exactly what I'm trying to get away from entirely and go with a modern equivalent =)
Rhodyspit75
If you are looking for a modern equivalent then go with the relay idea. That way you have a lot of options for the actual switch and knob. All you will need is a simple on off switch and let the relays do the rest.
TR3driver
Right. My point was just that it makes no sense to even mention "without center off" if one is talking about a push-pull switch, as they don't come that way. If a push-pull switch has an "off" position it is at one end, not center.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]
but the original lucas ones suck, real bad [/QUOTE]
Ok, if you say so. Mine seems to work fine, but then I don't use hazard flashers very often
And I did spend some quality time with it, cleaning out casting flash and lubricating so it slid smoothly.
justin_mercier
justin_mercier
Every time I had a problem with my turn signals or signal brightness or whatnot it always traced back to my hazard switch. I've pulled the thing apart and rebuilt it a few times and it's still bad. Just using a modern DPDT toggle switch made all those problems go away, but i like the push-pull aesthetic.
R TR6 Help: Brake Part Source or …. ? Triumph 1
M General TR Source for J Type O/D Solenoid Circlip Triumph 0
Jayplum TR2/3/3A Source for quality parts Triumph 11
B Vacuum Source Austin Healey 4
W Best source for Bugeye front shocks Spridgets 3
B TR6 Source for Carmine Red Triumph 4
steveg TR6 Source for fuel line P-clip Triumph 17
Sarastro TR4/4A Source for good convertible-top snaps Triumph 6
Sarastro TR4/4A Identifying the source of gear noise. Triumph 15
M TR2/3/3A Identifying Rear Axle Leak Source Triumph 12
D Source for XJ6c Series ll Ignition key blanks & remote Jaguar 1
Michael Oritt Tenax fastener source needed Austin Healey 6
Csarneson Source for distributor drive peg? Mystery Part? Austin Healey 8
R TR6 Body Parts Source, Upper Midwest Triumph 6
angelfj1 TR2/3/3A Possible UK Source for Authentic looking Clutch/Brake MC Triumph 5
Jim_Gruber Source for Smiths Gauges in UK I believe Spridgets 7
crya Current go-to source for VIN/Chassis Repro Plates? Austin Healey 8
RAC68 Source - Metal Clips for securing Convertible Top and/or Seat Covers Austin Healey 11
S Wanted Source for 100 6 right hand remote control door regulator Austin Healey Classifieds 1
S TR2/3/3A source for those little drain hoses Triumph 6
I TR6 Source for Elevator Bolts? Triumph 16
I TR6 Source for license plate light bracket? Triumph 5
steveg Excellent source for info on and rebushing of SU carbs Restoration & Tools 0
MikeAH100M Whitworth Source Austin Healey 8
Jim_Gruber Source for 3" cotter pins for bump rubber on BE Rear axle Spridgets 5
K Healey Blue Paint Source Austin Healey 30
D Body work finishing supplies source. Restoration & Tools 0
Csarneson Source for Distributor Fiber Thrust Washer Austin Healey 3
JPSmit DC Power source thoughts Restoration & Tools 11
B TR2/3/3A Locating source of oil leak Triumph 6
J Half round tube or D tube source ?? Restoration & Tools 2
HealeyDave TR2/3/3A TR3 Dash Cover Source Triumph 9
B New frame candidate or parts source? Austin Healey 12
S Bay Area source for 60 Sprite Roll Bar? Spridgets 6
Jim_Gruber Source for PosiDrive Screws Spridgets 7
R TR2/3/3A Source for rubber seal on A/M side curtains Triumph 4
J TR4/4A TR4A rear wheel cylinder source Triumph 3
I Bigeye transmission source? Spridgets 7
Rut TR4/4A Good interior source Triumph 29
R Source for return spring on Early BN4 locking door handle? Austin Healey 1
Jim_Gruber Source for Small U Bolts on 1/4 Elliptic Springs- Spridgets 11
bighealeysource Source for correct washer for overdrive drain plug Austin Healey 6
Csarneson Source for BN4 2nd Gear Austin Healey 8
CJD TR2/3/3A Source for Horsehair Padding? Triumph 10
Michael Oritt Rear upright casting--source needed Racing 4
I TR6 Under bonnet sticker source Triumph 3
D General TR Front carpet source? Triumph 1
Steve P. Best source for new tappets? Austin Healey 11
I General TR Source for glass mirrors Triumph 5
Patrick67BJ8 "Cover" for Top. Source wanted Austin Healey 6
