General TR Source for glass mirrors
ichthos
I need two new mirrors 4 5/16" and 1/16" thick. Anyone know of a source for these? The two mirrors I have a number of chips on the circumference, so they are not good candidates for resilvering. Thanks, Kevin
DornTRoriginal
I was on vacation but I recall this post and I see there wasn't a lot of response, I'm looking at buying some new fender mirrors, did you check https://www.texautomotive.com/
Vila
Not sure of your application, are we taking about exterior mirrors?
When I was restoring the interior rear view mirror for my 1962 TR4 I looked everywhere for a thin mirror and no one had them. I finally found exactly what I needed in the oddest place, TARGET.
The plastic handled mirrors they have in their cosmetic and hair product section have a thin mirror approximately 6 inches in diameter. If that meets your needs, be very careful when you are taking the mirror out of the plastic handle since it is glued in with a few dabs of silicone adhesive. I popped it out, cleaned the excess silicone off the back and took it to a local mirror shop where they cut it to size and ground the corners round using my original weathered mirror for the pattern.
When I was putting it in the mirror frame I cracked the first one and had to repeat the entire process again.
Let us know when you find what you need.
Gordon_Dedrick
I am also unsure of your application but I got a RIGHT side mirror from an old Ford F150 from a junkyard and had several mirrors cut from it by a local glass shop. The mirror for the TR3 is quite small and offered a very small field of view as original. The convex one from the Ford gives a much better (and Larger) rear view.
Gordon
NutmegCT
Something I learned back at the beginning of my "frugal days":
Cut a piece of clear glass to the size you need. Spray one side black, or mount the clear glass over a black background (black sprayed aluminum foil, tin, etc.).
Vwah-la! It's a mirror!
G New Memebr needs good glass source Spridgets 12
R TR6 Help: Brake Part Source or …. ? Triumph 1
M General TR Source for J Type O/D Solenoid Circlip Triumph 0
Jayplum TR2/3/3A Source for quality parts Triumph 11
B Vacuum Source Austin Healey 4
W Best source for Bugeye front shocks Spridgets 3
B TR6 Source for Carmine Red Triumph 4
steveg TR6 Source for fuel line P-clip Triumph 17
Sarastro TR4/4A Source for good convertible-top snaps Triumph 6
Sarastro TR4/4A Identifying the source of gear noise. Triumph 15
M TR2/3/3A Identifying Rear Axle Leak Source Triumph 12
D Source for XJ6c Series ll Ignition key blanks & remote Jaguar 1
Michael Oritt Tenax fastener source needed Austin Healey 6
Csarneson Source for distributor drive peg? Mystery Part? Austin Healey 8
R TR6 Body Parts Source, Upper Midwest Triumph 6
angelfj1 TR2/3/3A Possible UK Source for Authentic looking Clutch/Brake MC Triumph 5
Jim_Gruber Source for Smiths Gauges in UK I believe Spridgets 7
crya Current go-to source for VIN/Chassis Repro Plates? Austin Healey 8
RAC68 Source - Metal Clips for securing Convertible Top and/or Seat Covers Austin Healey 11
S Wanted Source for 100 6 right hand remote control door regulator Austin Healey Classifieds 1
S TR2/3/3A source for those little drain hoses Triumph 6
I TR6 Source for Elevator Bolts? Triumph 16
I TR6 Source for license plate light bracket? Triumph 5
steveg Excellent source for info on and rebushing of SU carbs Restoration & Tools 0
MikeAH100M Whitworth Source Austin Healey 8
Jim_Gruber Source for 3" cotter pins for bump rubber on BE Rear axle Spridgets 5
K Healey Blue Paint Source Austin Healey 30
D Body work finishing supplies source. Restoration & Tools 0
Csarneson Source for Distributor Fiber Thrust Washer Austin Healey 3
JPSmit DC Power source thoughts Restoration & Tools 11
B TR2/3/3A Locating source of oil leak Triumph 6
J Half round tube or D tube source ?? Restoration & Tools 2
HealeyDave TR2/3/3A TR3 Dash Cover Source Triumph 9
B New frame candidate or parts source? Austin Healey 12
S Bay Area source for 60 Sprite Roll Bar? Spridgets 6
Jim_Gruber Source for PosiDrive Screws Spridgets 7
R TR2/3/3A Source for rubber seal on A/M side curtains Triumph 4
J TR4/4A TR4A rear wheel cylinder source Triumph 3
I Bigeye transmission source? Spridgets 7
Rut TR4/4A Good interior source Triumph 29
R Source for return spring on Early BN4 locking door handle? Austin Healey 1
Jim_Gruber Source for Small U Bolts on 1/4 Elliptic Springs- Spridgets 11
bighealeysource Source for correct washer for overdrive drain plug Austin Healey 6
Csarneson Source for BN4 2nd Gear Austin Healey 8
CJD TR2/3/3A Source for Horsehair Padding? Triumph 10
Michael Oritt Rear upright casting--source needed Racing 4
I TR6 Under bonnet sticker source Triumph 3
D General TR Front carpet source? Triumph 1
Steve P. Best source for new tappets? Austin Healey 11
Patrick67BJ8 "Cover" for Top. Source wanted Austin Healey 6
