Perrymip
I've used this luxurious feature for all kind of things including adjusting valve lash, setting points gap, moving the engine tp TDC, and so on. But twice in my life that solenoid has stuck ON. This is an unpleasant moment, the starter racing on and on, all one's first first instincts unproductive, then, finally, wrenching free the battery cable to shut everything off.
My first instinct: replace the solenoid. The reason for this is that I feel so snake-bit after the failure, that I really don't want to lean over and press that button again. So I put a new one in. But the "new' ones are not the "old" ones, beefy and hefty pieces of Lucas engineering. And I recently had a "new" one commit this same ugly failure.
Any advice, other than avoid using the solenoid button?
