Starter Solenoid Positon
HarryL
What's the correct position for a 4A ?
Is it on the floor of the battery box or the small
bulkhead(facing fore & aft) alongside the battery.
Welding covered the original holes.
Thanks everyone
Harry
3798j
Bronze
Harry - This photo should help.
fpstude
Jay, thanks for sharing your photo. For me, it clarifies the installation of the (emergency) hood release. Your photo should be part of the installation kit!
R TR6 Starter Solenoid Conection Triumph 11
S Starter Solenoid Nut Size for BJ8 Austin Healey 1
S TR2/3/3A Starter or Solenoid Triumph 13
ckeithjordan TR2/3/3A Starter Solenoid Triumph 3
K TR2/3/3A Starter,Solenoid, Ignition Switch Issue? Triumph 5
NutmegCT Failing starter solenoid? Restoration & Tools 15
S Wedge TR8 starter solenoid details? Triumph 3
Crankshaft TR2/3/3A Starter Solenoid Question Triumph 13
Perrymip TR2/3/3A Starter Solenoid Push Button Triumph 11
P Bugeye starter solenoid??? Spridgets 2
A TR6 Starter solenoid Triumph 3
S TR6 TR6 Starter/solenoid Clicking Triumph 1
Mychael Location for pull starter solenoid. Spridgets 11
The_architect Bugeye battery / solenoid / starter cable lengths Spridgets 7
B Solenoid to starter cable on my 57 Triumph 6
Stinger TR4/4A TR4A Starter Solenoid Connector Triumph 2
doates Spitfire Spitfire Starter Solenoid Triumph 2
M Replacing the starter solenoid Triumph 16
Tr4dude TR6 Tr6 starter solenoid Triumph 4
S TR2/3/3A tr3 solenoid to the starter Triumph 6
RJS Starter Solenoid Issues Triumph 3
KVH More Battery/Starter/Solenoid Woes Triumph 14
KVH TR4/4A TR4 Starter and Solenoid Issue Triumph 19
K TR2/3/3A TR3 Starter Solenoid Test...Out of vehicle?? Triumph 3
bigbadbluetr6 TR6 TR6 Starter Solenoid Triumph 3
Lin starter solenoid problem Austin Healey 3
Dudly Spitfire setting up starter solenoid 79 Spit Triumph 11
Dadandson Starter Solenoid Alternative Spridgets 3
mjobrien Wiring Question on Starter Solenoid. Austin Healey 2
J BJ8, PH I Starter Solenoid, I Think? Austin Healey 12
T Smoke from Starter Solenoid Spridgets 9
G Blue and black wire near starter solenoid Triumph 2
Jim_Gruber Starting Question / Solenoid / Wiring / Starter Spridgets 1
W Aftermarket starter solenoid? Triumph 9
A Wiring connections for starter solenoid Spridgets 1
J starter-solenoid issues? Triumph 12
A Starter Solenoid Question - Push vs. Non-Push Austin Healey 4
Frank C. Starter Solenoid Austin Healey 3
Hegg Starter Solenoid Buzzes when trying to start Triumph 2
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 7
R TR6 Lucas Starter 2M100 - Extra Part? Triumph 2
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
N TR5/TR250 Starter Box Assembly Leak Triumph 14
P TR2/3/3A British High Torque starter Triumph 6
W General Tech 2500S starter motor and fuse box questions Triumph 3
EWD For Sale ā€˜74 TR6 original starter Triumph Classifieds 0
M High-Torque Starter Austin Healey 10
W Generator and Starter Long Bolts Spridgets 0
