TR2/3/3A Starter Solenoid Question
Crankshaft
My starter switch fails intermitantly. It seems that when failure occurs, I can turn the engine over with the button on the solenoid and the push switch works next try. First of all, does this indicate a problem with the solenoid or push switch on the dash? Secondly if the problem proves to be with the solenoid, is it serviceable or need to replace? The dash sw has continuity when depressed.
Geo Hahn
I would suspect the solenoid. My recollection is that there is a disc in there that the magnet pushes against the high current connections - as I recall that disc can become corroded or in some way less conductive.
Next time the dash switch does not trigger it you might (instead of pushing the button on the solenoid) just use a short wire to briefly jump the post with the battery cable to the terminal for the white/red lead. If that makes the solenoid work then your switch or ignition wiring is suspect. If nothing happens than that would suggest the problem is the solenoid.
Why does it resume working after you have manually exercised it? I'm thinking that disk in the solenoid moves a bit each time so you get off the bad spot that was the problem.
Searching a bit --
I don't know that you would have much success opening up a solenoid, cleaning it and (the hard part) getting it back together -- but here is a photo array by someone who did 'fix' a balky one. Note that he is working with 2 solenoids - one he takes apart just to see what is in there and another that he drills to enable cleaning, drying and reuse:
https://www.jag-lovers.org/snaps/snap_view.php3?id=1458846628
M_Pied_Lourd
When that happened to me, it ended up being the starter motor itself going out...
Cheers
Tush
Crankshaft
Crankshaft
That's interesting. The starter never hesitates when it's activated by the button on the solenoid. But it is sure something to check. Thanks.
sp53
Nice stuff Geo thanks for posting. I never would have thought of that. I have tried to think of ways of opening the pot metal up and resealing somehow, but have not tried yet.
2long
Yes, my experience was that I sent my push button solenoid off to Cox Automotive in the UK, which is reputed to be the best around. But they said they could not repair my unit! That was stunning to me as it doesn't seem too complicated an item. I wanted to use my '54 date stamped piece, which I think is a nice little touch. So now I am thinking about trying the old "drill through the bakelite to clean the innards" trick described above!
Dan
Crankshaft
Crankshaft
I tried the jumper and nothing happened but did see a slight spark in the vicinity of the mounting bracket. With the jumper attached I wiggled the solenoid and it came to life. Going to attack the mount to clean and solidify the ground.
Thanks again Geo for the great trouble shooting advice.
sp53
I have had those old solenoids die slow by working sometimes and even a little bump with something to fire them up and sometimes the button would stick in the on positon when I tried that, and I would have pull off a battery cable. Plus I heard the new repose have problems. I used the tr4 upgrade on the last one I restored; it has the button but not the older look. The car I am doing now I plan to use an old stock one I bought used; it would be nice to see some NOS solenoids pop up on eBay.
steve
Crankshaft
Crankshaft
I never leave home without the crank. But in the meantime, in the process of cleaning and re-mounting, I discovered a ground loop coming out of the harness with a terminal that just happened to exactly reach the mounting screw. Attached with the clean and bright screw and what do you know, Bob's my uncle.
Thanks again to the members of this forum I'm on the road again (as Willie Nelson would sing)
bobhustead
Your description in post #8 indicates that the body of the solenoid is grounding to the car body only intermittently. Clean up the mating surfaces and tighten the bolts. The juice coming out of the small wire from the switch is activating coils to create electromagnetism and moves a plunger that makes contact between the big cable going from the batt and to the starter. The electromagnet won't work if the current it is getting doesn't go to ground.
Bob
Sorry. I didn't see your last post before writing this.
karls59tr
Bronze
So that's what that ground loop on my new harness is for. Makes sense now. I'm going to ground it at the solenoid base. Who knew.:encouragement:
Geo Hahn
So that's what that ground loop on my new harness is for... I'm going to ground it at the solenoid base...
I am not sure what this 'loop' is that you mention, but there is a ground that connects just to the right of the control box.
mjobrien Wiring Question on Starter Solenoid. Austin Healey 2
Jim_Gruber Starting Question / Solenoid / Wiring / Starter Spridgets 1
A Starter Solenoid Question - Push vs. Non-Push Austin Healey 4
R TR6 Starter Solenoid Conection Triumph 11
S Starter Solenoid Nut Size for BJ8 Austin Healey 1
S TR2/3/3A Starter or Solenoid Triumph 13
ckeithjordan TR2/3/3A Starter Solenoid Triumph 3
K TR2/3/3A Starter,Solenoid, Ignition Switch Issue? Triumph 5
NutmegCT Failing starter solenoid? Restoration & Tools 15
S Wedge TR8 starter solenoid details? Triumph 3
Perrymip TR2/3/3A Starter Solenoid Push Button Triumph 11
P Bugeye starter solenoid??? Spridgets 2
A TR6 Starter solenoid Triumph 3
H Starter Solenoid Positon Triumph 3
S TR6 TR6 Starter/solenoid Clicking Triumph 1
Mychael Location for pull starter solenoid. Spridgets 11
The_architect Bugeye battery / solenoid / starter cable lengths Spridgets 7
B Solenoid to starter cable on my 57 Triumph 6
Stinger TR4/4A TR4A Starter Solenoid Connector Triumph 2
doates Spitfire Spitfire Starter Solenoid Triumph 2
M Replacing the starter solenoid Triumph 16
Tr4dude TR6 Tr6 starter solenoid Triumph 4
S TR2/3/3A tr3 solenoid to the starter Triumph 6
RJS Starter Solenoid Issues Triumph 3
KVH More Battery/Starter/Solenoid Woes Triumph 14
KVH TR4/4A TR4 Starter and Solenoid Issue Triumph 19
K TR2/3/3A TR3 Starter Solenoid Test...Out of vehicle?? Triumph 3
bigbadbluetr6 TR6 TR6 Starter Solenoid Triumph 3
Lin starter solenoid problem Austin Healey 3
Dudly Spitfire setting up starter solenoid 79 Spit Triumph 11
Dadandson Starter Solenoid Alternative Spridgets 3
J BJ8, PH I Starter Solenoid, I Think? Austin Healey 12
T Smoke from Starter Solenoid Spridgets 9
G Blue and black wire near starter solenoid Triumph 2
W Aftermarket starter solenoid? Triumph 9
A Wiring connections for starter solenoid Spridgets 1
J starter-solenoid issues? Triumph 12
Frank C. Starter Solenoid Austin Healey 3
Hegg Starter Solenoid Buzzes when trying to start Triumph 2
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 7
R TR6 Lucas Starter 2M100 - Extra Part? Triumph 2
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
N TR5/TR250 Starter Box Assembly Leak Triumph 14
P TR2/3/3A British High Torque starter Triumph 6
W General Tech 2500S starter motor and fuse box questions Triumph 3
EWD For Sale ‘74 TR6 original starter Triumph Classifieds 0
M High-Torque Starter Austin Healey 10
W Generator and Starter Long Bolts Spridgets 0
