Starter Solenoid Question - Push vs. Non-Push
Andrew1
Hello all.
I wanted to inquire about starter solinoids for BJ8. I recently had problems with my stater, and thank goodness for that little manual push button on the solenoid, or I would have unecessarily had the starter off. The fault was in the solenoid itself.
My 1967 Bj8 was about 200 cars from the end of the production line, and my parts supplier spec'ed out a solenoid (lucas repro) that does not look like the push button type. She said that this one was used on later Bj8's.
I want to findout from the experts in the forum to verify that the Bj8 could have used two alternative stater solenoids?
This solenoid also has an extra small-sized lucar terminal that was explained as a "take off for the coil". I don't know what that means?
Thanks,
Andrew
Keoke
Hi Andrew,There are some non Healey starter relays that have a terminal that routes a direct wire from the battery to the coil to bypass the voltage dropping ballast resisitors usually contained in coil circuits in the run position.However, the original Healey starter button type solenoid does not include that function. The small Lucar terminal on the button type solenoid is connected to the starter button/Igntion switch in the cockpit.---Fwiw---Keoke
A
Andrew1
Thanks as always Keoke:
Were there ever any Healey Bj8's shipped with a starter solenoid different than the push button style?
- Andrew -
Keoke
HI Andrew, no not to my knowledge. The only cars that I have seen without the push button solenoid all had aftermarket parts in place.---Fwiw---Keoke
zblu
Early landrovers used the same push button solenoid, they would have been from the same parts bin, you might get an original part under a different part number!, might be cheaper too!
Crankshaft TR2/3/3A Starter Solenoid Question Triumph 13
mjobrien Wiring Question on Starter Solenoid. Austin Healey 2
Jim_Gruber Starting Question / Solenoid / Wiring / Starter Spridgets 1
R TR6 Starter Solenoid Conection Triumph 11
S Starter Solenoid Nut Size for BJ8 Austin Healey 1
S TR2/3/3A Starter or Solenoid Triumph 13
ckeithjordan TR2/3/3A Starter Solenoid Triumph 3
K TR2/3/3A Starter,Solenoid, Ignition Switch Issue? Triumph 5
NutmegCT Failing starter solenoid? Restoration & Tools 15
S Wedge TR8 starter solenoid details? Triumph 3
Perrymip TR2/3/3A Starter Solenoid Push Button Triumph 11
P Bugeye starter solenoid??? Spridgets 2
A TR6 Starter solenoid Triumph 3
H Starter Solenoid Positon Triumph 3
S TR6 TR6 Starter/solenoid Clicking Triumph 1
Mychael Location for pull starter solenoid. Spridgets 11
The_architect Bugeye battery / solenoid / starter cable lengths Spridgets 7
B Solenoid to starter cable on my 57 Triumph 6
Stinger TR4/4A TR4A Starter Solenoid Connector Triumph 2
doates Spitfire Spitfire Starter Solenoid Triumph 2
M Replacing the starter solenoid Triumph 16
Tr4dude TR6 Tr6 starter solenoid Triumph 4
S TR2/3/3A tr3 solenoid to the starter Triumph 6
RJS Starter Solenoid Issues Triumph 3
KVH More Battery/Starter/Solenoid Woes Triumph 14
KVH TR4/4A TR4 Starter and Solenoid Issue Triumph 19
K TR2/3/3A TR3 Starter Solenoid Test...Out of vehicle?? Triumph 3
bigbadbluetr6 TR6 TR6 Starter Solenoid Triumph 3
Lin starter solenoid problem Austin Healey 3
Dudly Spitfire setting up starter solenoid 79 Spit Triumph 11
Dadandson Starter Solenoid Alternative Spridgets 3
J BJ8, PH I Starter Solenoid, I Think? Austin Healey 12
T Smoke from Starter Solenoid Spridgets 9
G Blue and black wire near starter solenoid Triumph 2
W Aftermarket starter solenoid? Triumph 9
A Wiring connections for starter solenoid Spridgets 1
J starter-solenoid issues? Triumph 12
Frank C. Starter Solenoid Austin Healey 3
Hegg Starter Solenoid Buzzes when trying to start Triumph 2
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 7
R TR6 Lucas Starter 2M100 - Extra Part? Triumph 2
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
N TR5/TR250 Starter Box Assembly Leak Triumph 14
P TR2/3/3A British High Torque starter Triumph 6
W General Tech 2500S starter motor and fuse box questions Triumph 3
EWD For Sale ā€˜74 TR6 original starter Triumph Classifieds 0
M High-Torque Starter Austin Healey 10
W Generator and Starter Long Bolts Spridgets 0
