Aftermarket starter solenoid?
Winston
The starter solenoid on our TR4 gave up the ghost yesterday. I'm starting the car by jumping the two posts on the broken part.
I went up to O'Reilys and picked up a $10.00 screw terminal vs. spade terminal and installed. No Go !
I know that the part from China is for a 12 volt system, why would'nt it work?
martx-5
There could be several problems...
1. There is nothing wrong with the original solenoid. Check to see that you have 12V going to the activation terminal when the key is in the start position. That would be the small gauge wire going to the solenoid. If you don't have 12V there, then the problem is elsewhere (from the keyswitch) and not in the solenoid. If you don't have a voltmeter, just take a small wire and jump from where the battery cable connects to the solenoid to the small post on the solenoid. You could try this with either solenoid to see if they work.
2. If the new solenoid has two small posts and you may have the keyswitch wire hooked to the wrong one. Some solenoids have the second post to supply 12V to the ignition system for starting.
3. You bought a solenoid that has two small posts, but one of them provides a ground for the solenoid coil. You'd have to run a ground wire on that second post. Those aren't too common, so you probably don't have one of those.
4. The solenoid you bought is no good or wrong for the application. What did you ask for?? If you're not concerned with originality (which, at this point I don't think you are), just ask for a late '60's Ford solenoid. Say a Mustang...any engine. It will have the two small posts, but you will only need to use one of them.
dklawson
My first thought was along the lines of Martx-5's points 2 and 3. There are a few solenoids out there that require a dedicated ground connection since they don't get it through their mounting bracket. Other solenoids support a switched output lug going to the coil when used on cars with ballasted ignition. If you hook the ignition switch connection to that terminal it won't do any damage but it won't work either.
Take the solenoid off the car and make connections from the battery to the small lug(s) on the solenoid and its mounting bracket. (Obviously you'll be doing this with the heavy gauge wires disconnected). When you get the right combination of ground connection and input power you'll hear and feel the solenoid fire closed and you'll know how to connect it to your wiring. If you can't get it to work that way, take it back and follow Martx-5's suggestion in his point #4.
W
Winston
Thanks for the input. I went ahead and ordered the Vicky Brit part, (should be here today or tommorrow).
I also noticed in the recent British Motoring from Moss that they offer an ignition switch for $29.95 on sale,I will probably order one while replacing all else.
dklawson
Out of curiosity... what solenoid was original to the TR4? Did it use the squarish Lucas solenoid or the round body one with the rubber pushbutton on its rear end (for manual cranking of the engine)? Be advised that the round body ones available now are junk. I've gone through three in as many years.
The problem with these 'new' ones is there is an "E" clip on the actuating shaft inside the solenoid. Over time the E clip works loose and falls off the shaft. Once that happens the solenoid can't drive the contacts together. You may still want to find a suitable U.S. solenoid if you're using the Lucas round solenoid.
W
Winston
Doug,
I'm unsure about the original part. I have ordered the square solenoid with the spade terminals. I'm pretty sure the part is not original and was probably changed when the car was switched to a negative ground.
dklawson
I lost my most recent solenoid while at the grocery store. There's nothing like a car full of frozen foods on a hot day to give you incentive to fix your car. I used insulated lineman's pliers across the solenoid contacts to crank the engine. As soon as I got home I installed a used square solenoid.
Regardless of what was originally on your TR4, the square solenoid should prove more reliable. You can also drill out the rivets holding it together to fix any problems and then use machine screws to put it back together. You can't do that on the round solenoids.
Geo Hahn
[ QUOTE ]
[/ QUOTE ]
To the best of my knowledge, the rubber-button solenoid was used on all TR4s... the TR4As (like Winston's) may be where the square solenoid was introduced.
Good used rubber-button solenoids are usually available and that is what I use as I like the remote-start feature. They don't say Lucas on them but they do have a date of manufacture so one can determine if they are original parts.
I do have a square-bodied spare just in case.
dklawson
I'm anal enough that I don't even throw out the dead, round aftermarket solenoids. I took the one that died last month and "reconditioned it". It will never look the same since I can't roll form a closure for it, but it is all put together.
Thanks for the info on production dates on the Lucas solenoids. Next time I'm at a swap meet I'll keep my eyes open for them.
J TR2/3/3A Aftermarket starter for TR3 question Triumph 8
S MGB Aftermarket starter for 66 mgb MG 9
King_of_England aftermarket gear reduction starter failure Triumph 10
DutchConnection Clutch finger problems on Powetune aftermarket clutch cover Spridgets 0
roscoe Aftermarket Seats with Headrests Austin Healey 9
AUSMHLY Clutch Pilot Bush: NOS vs Aftermarket Austin Healey 8
Y MGB Aftermarket wheels MG 5
kodanja TR2/3/3A Rocker studs for aftermarket Rocker covers Triumph 4
kodanja TR2/3/3A Aftermarket Sun Visors? Triumph 12
K TR2/3/3A Aftermarket Distributor Points and Terminal Bush leads? Triumph 1
HealeyPassion Aftermarket heater/defroster with 3 speed fan Austin Healey 15
B For Sale Seat Mounting brackets for aftermarket seats Spridgets Classified 0
Z TR2/3/3A Windshield Aftermarket Triumph 22
S TR2/3/3A Stock air cleaners and aftermarket air cleaners. Triumph 7
B 100-4 Aftermarket Hardtops Austin Healey 7
H TR4/4A Original TR4a grill versus aftermarket Triumph 0
55modified Need suggestions for fastening aftermarket hardtop for BN1. Austin Healey 15
S TR4/4A aftermarket choke cable Triumph 3
Csarneson Rear Springs - Aftermarket or buy an old used pair Austin Healey 10
W TR6 tr6 horn aftermarket Triumph 1
T TR6 TR6 aftermarket rear shocks Triumph 35
NutmegCT Aftermarket a/c? Restoration & Tools 15
T TR2/3/3A Question on TR3A aftermarket side curtains Triumph 8
T TR2/3/3A Aftermarket brake master cylinder 1961 TR 3A Triumph 11
S TR2/3/3A aftermarket trunnions? Triumph 6
R Installing an aftermarket brake servo kit Austin Healey 6
F Thoughts on aftermarket air cleaners? Austin Healey 12
J aftermarket sheetmetal Spridgets 2
66healey Aftermarket brake booster pictures Austin Healey 7
Gray_Cat Bugeye Aftermarket Steering Wheels Spridgets 15
V TR6 Top, aftermarket plastic/fiberglass for TR6? Triumph 6
Branson Aftermarket wiring harness + original sprite wire Spridgets 5
R Red, white and tan covert tops aftermarket 60's? Triumph 11
B Spitfire Aftermarket synchros 1500 Spit single rail Triumph 2
RJS Aftermarket Cooling Fans Triumph 3
W TR6 TR6 aftermarket headers Triumph 26
newmexTR3 TR2/3/3A Aftermarket headlight relay mounting options TR2-4 Triumph 5
M TR6 ??TR6 steering wheel NOS or Aftermarket on ebay?? Triumph 7
Don_R Aftermarket Steering Wheel Triumph 7
newmexTR3 TR2/3/3A TR3 Aftermarket Door Seals that work? Triumph 11
R TR6 TR6 Aftermarket Seatbelts Triumph 4
Editor_Reid Rare 100 Aftermarket Accessory Austin Healey 7
rustbucket T-Series Original vs. Aftermarket Cutch MC & Slave MG 4
71TR6 TR6 Aftermarket TR6 Steel Wheel Triumph 3
R TR2/3/3A TR3 Hardtop OEM or Aftermarket Triumph 21
K TR6 Custom Hardtops - aftermarket top TR6 Triumph 11
AUSMHLY Survey - stock, hybrid, aftermarket steering wheel Austin Healey 37
Steve P. 5" aftermarket rims, what tire size needed??? Spridgets 3
v8mgbal aftermarket steering wheels Spridgets 19
