Wiring Question on Starter Solenoid.
mjobrien
In checking a start Solenoid for correct connections I noticed that the two high tension lugs are isolated from ground and to each others, as expected.
I also noticed the small lug lead from start switch was gounded?
Is this correct?
Thanks,
Michael.
Dave Russell
Yoda - R.I.P
The small lug lead is not actually grounded. It goes to one end of the solenoid operating coil which is likely to be around two to three Ohms. The other end of this coil is grounded. So you are reading from the terminal through the coil to ground.
mjobrien
mjobrien
Dave,
Thanks I was not thinking in terms of a coil and now understand why I get a reading to the case from that lug. I assume when power is applied the circut is completed and the Solenoid than passes the voltage between the two high tension lugs.
Thanks,
Michael.
R TR6 Starter wiring question Triumph 6
Willie_P TR4/4A WIRING question: gear reduction starter Triumph 3
Jim_Gruber Starting Question / Solenoid / Wiring / Starter Spridgets 1
B TR4/4A Basic Wiring Question Triumph 35
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
nichola TR6 Question on new wiring harness Triumph 6
J TR6 73 TR6 Temp Gauge Wiring Question Triumph 6
JPSmit Todays question - wiring Spridgets 14
ckeithjordan TR2/3/3A Wiring Harness Question[s] Triumph 10
C MGA Wiring harness question MG 7
Michael Oritt LED bulb/resistor wiring question Austin Healey 24
BoyRacer Wiring question for alternator conversion Austin Healey 3
G TR4/4A Front Parking Lamps Wiring Question Triumph 5
T TR2/3/3A Question on wiring Denso alternator through ammeter Triumph 4
Griz Trafficator Wiring Question Austin Healey 16
Michael Oritt Wiring question Austin Healey 5
N Spitfire alternator wiring question Triumph 1
Got_All_4 TR2/3/3A Quick Overdrive Wiring Question Triumph 6
K TR2/3/3A Another question about pulling the wiring thru the stator tube... Triumph 15
J TR6 '73 TR6, Wiring Question. Original Owner Triumph 5
AngliaGT '74 Midget - Wiring Question Spridgets 2
B Question about Dual Polarity Electronic Fuel Pump - How to Connect Wiring? Austin Healey 9
TomChar TR6 '74 brake failure / oil pressure / ARV wiring question Triumph 19
B TR6 Wiring question Triumph 11
Tinkerman TR2/3/3A Front turn signal wiring question on my post 60000 TR3A Triumph 8
D Original BN6 / BN7 Battery Switch Wiring Question Austin Healey 15
T BN-1 Wiring Question Austin Healey 3
Griz Rear Wiring Harness Question Austin Healey 6
Griz Another BJ7 Wiring Question Austin Healey 4
M Quick tachometer wiring question on a '65 Spridgets 10
Tugboat Wiring Question Triumph 6
glemon Wiper Motor Wiring Question Triumph 11
bash Alternator wiring question Triumph 5
B Another wiring question 57 smallmouth control head Triumph 2
B Question on OD wiring harness 57 Smallmouth Triumph 15
Tinkerman TR2/3/3A Wiring question TR 3A Triumph 4
T TR4/4A White wire question on TR4A A-type wiring Triumph 2
Tinkerman TR2/3/3A Wiring question TR3A Triumph 5
M_Pied_Lourd TR2/3/3A TR3A Gauge Cluster Wiring Question Triumph 7
R TR2/3/3A TR3 Headlight Wiring Question Triumph 6
R Wiring question. No spark, need help. Spridgets 16
Coyote1 Overdrive wiring question Triumph 8
T Wiring hack - iginition switch question Spridgets 8
B wiring harness question: Triumph 3
E BE Alternator Wiring Question Spridgets 5
hondo402000 TR6 Another TR6 wiring question Triumph 5
hondo402000 TR6 TR6 Wiring/amp gauge question Triumph 8
T TR4/4A TR4A alternator conversion wiring question Triumph 28
T OT Wiring question - but probably useful to know Triumph 10
