BE Alternator Wiring Question
erstearns
I have installed an alternator, changing over to neg ground and eleminating the control box. I have a new wiring harness that has what appears to be a 12 gauge yellow gen wire.
Can I run a single 10 or 8 gauge wire from the B+ alternator terminal to the battery side of the mechanical starter switch (or to the positive terminal of the battery) and eleminate the 12 gauge yellow wire that would get bundled with the other A & A1 control box wires?
spritenut
You have to connect the brown, the brown/blue, and the yellow wire together at some point.
So if you connect it to the hot side of the solenoid, you still have to connect the brown & brown/blue together at the old voltage regulator. They are already hooked together in the regulator but if you eliminated the regulator, make sure all the heavy brown wires are connected.
E
erstearns
There is literature and discussion about doubling the yellow wire from the alternator because it is too small as originally wired for a generator. It seems more effecient to run one heavier gauge wire.
If I read the diagram correctly, for converting to neg ground, installing alternator and removing control box, the brown wire picks up current at the battery and distributes it to the brown/blue to ignition and to the always on terminal at the fuse block.
The heavier 10 gauge wire I propose adding is for the charging system and the most direct route is from the alternator to the battery (or to the hot side of the starter switch.
Am I thinking correctly?
Sarastro
You're right about running one heavier wire. When you double the wire, you don't exactly double the current carrying capability, since the resistances are never exactly equal. You end up with one of the wires carrying most of the current anyway.
The rest of what you are planning sounds right to me.
You need to wire up the ignition idiot light, too. It normally goes to the "D" terminal of the box (yellow wire), which is just the generator output. Alternators usually have a separate terminal for this light, but if not, it can go to the alternator output terminal.
I know you'll enjoy the alternator, or at least the peace of mind it gives you. I made the mistake of installing an ammeter, so I could see how badly the generator kept the battery charged. That really encouraged me to install the alternator in a hurry!
E
erstearns
I've got a terminal on the alt for the light wire. Going to run a 10 gauge either to the battery or starter switch and eleminate the 12 or 14 gauge yellow wire on the new harness.
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
BoyRacer Wiring question for alternator conversion Austin Healey 3
T TR2/3/3A Question on wiring Denso alternator through ammeter Triumph 4
N Spitfire alternator wiring question Triumph 1
bash Alternator wiring question Triumph 5
T TR4/4A TR4A alternator conversion wiring question Triumph 28
Webb Quick Alternator Wiring Question Triumph 3
LastDeadLast Bosch Alternator Wiring Question Triumph 1
F TR2/3/3A I'm stuck... alternator/wiring/starting/? Triumph 2
apbos Positive Ground Alternator wiring. Spridgets 9
G TR2/3/3A Wiring ammeter with the British Wiring alternator conversion. Triumph 13
D TR2/3/3A Alternator wiring diagram Triumph 7
M wiring of alternator Austin Healey 3
K TR2/3/3A Triumph Rescue/British Wiring Alternator Kit Triumph 10
K TR2/3/3A Alternator from British Wiring Triumph 12
mgedit TR2/3/3A Alternator Wiring for TR3 Triumph 18
Lukens TR2/3/3A Help wiring convertion alternator Triumph 6
B TR6 Does a 75 amp alternator require a wiring upgrade of any kind? Triumph 3
D MGB mgb 77 alternator wiring. MG 2
Patrick67BJ8 Alternator Conversion & Regulator Wiring Help Need Austin Healey 11
H TR4/4A tr4 alternator wiring Triumph 4
I Alternator wiring Austin Healey 5
tweety Alternator wiring connector, Sources? Spridgets 4
G MGB Alternator wiring "71 MGB MG 4
bill_powell Alternator Conversion / Wiring Spridgets 13
kodanja Alternator upgrade wiring? Triumph 30
kyreb1862 MGB 77 MGB Alternator Wiring MG 4
B TR6 71 TR6 Alternator Wiring Triumph 2
Airfix TR6 TR6 alternator wiring? Triumph 5
D Alternator Wiring MG 7
C Wiring Check. Alternator wiring. MG 19
I MGB Alternator help MG 0
P Alternator Installation Pic Austin Healey 4
P Generator to Alternator Swap Austin Healey 2
W Generator or Alternator? Austin Healey 18
Writer2022 GT6 GT6 MK3 Alternator Problem Triumph 4
K TR2/3/3A Is it time for a new alternator??? Triumph 8
M Smog pump and alternator brackets Spridgets 0
V MGB Never occurred to me that my '66 would be positive ground. Does the presence of an alternator show that it's been converted? MG 22
A General MG 78 MG MIDGET ALTERNATOR SMOKES MG 5
E MGB external alternator regulator MG 2
DrEntropy MGB Generator to alternator swap MG 1
M TR2/3/3A Generator Warning Light on with the Alternator Charging the Battery Triumph 4
K TR2/3/3A Overtightening the alternator belt? Triumph 14
B TR6 Swapped Lucas to GM alternator Triumph 9
M TR6 Alternator Issue for 72 TR6 Triumph 7
K TR2/3/3A Can anyone confirm that if you replace the ammeter with a voltmeter ( generator removed and alternator added) that you...... Triumph 5
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
G Spitfire Alternator troubles Triumph 2
