MGB Alternator wiring "71 MGB
GaryBeu
Banned
Most of the wiring in this car is a nightmare...loose ends, splices that are bad, etc. I can't even describe the wiring to the alternator. We're trying to set it right so... we have a Lucas 3 wire alternator (on left is a small prong then two large prongs to the right). We have a large gauge brown wire, a smaller gauge brown wire and a small gauge brown/yellow wire. What order do they attach to the alternator? Only the two browns were connected and both went to the large brown in a weird terminal! Thanks.
G
GaryBeu
Banned
Re: Alternator wiring "71 MGB
Thanks...I just checked out this site. There are several diagrams for the 1971. How do I know which it is?
bob67bgt
I think the Moss cataloge has the conversion picture from the 2 plug unit used from 69-71? to a single plug later Alternator. Bob
G
GaryBeu
Banned
bob67bgt...I found the info in the Moss catalog. THANKS!!
D MGB mgb 77 alternator wiring. MG 2
kyreb1862 MGB 77 MGB Alternator Wiring MG 4
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
F TR2/3/3A I'm stuck... alternator/wiring/starting/? Triumph 2
apbos Positive Ground Alternator wiring. Spridgets 9
BoyRacer Wiring question for alternator conversion Austin Healey 3
G TR2/3/3A Wiring ammeter with the British Wiring alternator conversion. Triumph 13
D TR2/3/3A Alternator wiring diagram Triumph 7
M wiring of alternator Austin Healey 3
T TR2/3/3A Question on wiring Denso alternator through ammeter Triumph 4
K TR2/3/3A Triumph Rescue/British Wiring Alternator Kit Triumph 10
N Spitfire alternator wiring question Triumph 1
K TR2/3/3A Alternator from British Wiring Triumph 12
mgedit TR2/3/3A Alternator Wiring for TR3 Triumph 18
Lukens TR2/3/3A Help wiring convertion alternator Triumph 6
B TR6 Does a 75 amp alternator require a wiring upgrade of any kind? Triumph 3
bash Alternator wiring question Triumph 5
Patrick67BJ8 Alternator Conversion & Regulator Wiring Help Need Austin Healey 11
H TR4/4A tr4 alternator wiring Triumph 4
I Alternator wiring Austin Healey 5
E BE Alternator Wiring Question Spridgets 5
T TR4/4A TR4A alternator conversion wiring question Triumph 28
tweety Alternator wiring connector, Sources? Spridgets 4
bill_powell Alternator Conversion / Wiring Spridgets 13
kodanja Alternator upgrade wiring? Triumph 30
B TR6 71 TR6 Alternator Wiring Triumph 2
Webb Quick Alternator Wiring Question Triumph 3
Airfix TR6 TR6 alternator wiring? Triumph 5
D Alternator Wiring MG 7
C Wiring Check. Alternator wiring. MG 19
LastDeadLast Bosch Alternator Wiring Question Triumph 1
I MGB Alternator help MG 0
P Alternator Installation Pic Austin Healey 4
P Generator to Alternator Swap Austin Healey 2
W Generator or Alternator? Austin Healey 18
Writer2022 GT6 GT6 MK3 Alternator Problem Triumph 4
K TR2/3/3A Is it time for a new alternator??? Triumph 8
M Smog pump and alternator brackets Spridgets 0
V MGB Never occurred to me that my '66 would be positive ground. Does the presence of an alternator show that it's been converted? MG 22
A General MG 78 MG MIDGET ALTERNATOR SMOKES MG 5
E MGB external alternator regulator MG 2
DrEntropy MGB Generator to alternator swap MG 1
M TR2/3/3A Generator Warning Light on with the Alternator Charging the Battery Triumph 4
K TR2/3/3A Overtightening the alternator belt? Triumph 14
B TR6 Swapped Lucas to GM alternator Triumph 9
M TR6 Alternator Issue for 72 TR6 Triumph 7
K TR2/3/3A Can anyone confirm that if you replace the ammeter with a voltmeter ( generator removed and alternator added) that you...... Triumph 5
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
G Spitfire Alternator troubles Triumph 2
