Wiring Check. Alternator wiring.
cjowett
72MGB rebuilt Alternator but no wiring reference.
Can anyone tell me where the Black, Brown and Yellow wires connect to?
It may need someone to go and look at their own just to check but I would be very grateful as I have been trying to find out for over a week now.
Thanks.
Bugeye58
What's the part number of the alternator? There are different alternators, and the rectifier wiring is specific to the alternator being used.
Jeff
AlanT
There should be no black wires going to the alternator. The solid brown wires go to the larger terminals with the larger gauge wire going to the middle terminal. If there is an 'exciter' wire it goes beside the big brown wire on the large terminal adjacent to it. The small brown/yellow goes to the small terminal. This is assuming you have the three terminal alternator. Check/clean the connections on the starter solenoid . Also , make sure the alternator light works correctly.
Alan T
Bugeye58
Alan, he is referring to the internal wiring of the regulator, judging by his attached picture. Just need to know which alternator.
Jeff
AlanT
Oops.....missed the pic. The original alternator had a three or four wire regulator. Rebuilders typically replaced it with a two wire and connected it differently. So is that regulator a two wire regulator?
Alan T
AlanT
Well I have a perfect image of the alternator you need to see but cannot get it to download because the file is too large. Anywho , the black wire goes under the brush holder bolt (ground) , the yellow wire on the outer brush contact and the orange wire opposite the yellow on the same contact.
There should be a jumper connection from the center brush to the top of the regulator .
Alan T
C
cjowett
I'm afraid it has no part number visible. I'm going to see if I can work it out by the post that AlanT has written. Thanks for your help.
Colin.
C
cjowett
OK, that is well described and should help me get my car on the road. I'll let you know!
Thanks
Colin. /ubbthreads/images/graemlins/driving.gif
C
cjowett
It Runs!!!!!!!
Ignition light is still on but I think that is because the battery is so old and needs replacing.
Ignition light only comes on when the alternator is not working right... It's not a battery light.... Unfortunately. /ubbthreads/images/graemlins/frown.gif
Platinum
Before condemning the battery, charge it for a good while and try again... worth a shot.
C
cjowett
Worth trying. I like to save money. I come from Yorkshire in the UK where we keep our wallets under lock and key! /ubbthreads/images/graemlins/england.gif
My wallet hasn't been seen nor heard from since 1995. /ubbthreads/images/graemlins/grin.gif
C
cjowett
AlanT,
As my Ignition light is still on I suspect I did not fully understand your response but if you have an image would you mind sending it to me by e mail?
My address is colinjowett@gmail.com if you wouldn't mind.
Thanks,
Colin.
AlanT
Colin,
The image has been sent to you. The extra piece with the yellow wire is a surge diode and not found in too many rebuilt units.
Alan T
C
cjowett
Well, I made the change and it runs perfectly with no ignition light on and the battery seems to be holding charge again. Thanks for your help, it's great knowing that there are others willing to help.
AlanT
Colin,
Make sure the light comes on with the engine off and the ignition on. Then if it goes out when the engine is running it almost has to be charging.
Alan T
S Overdrive Wiring Check Austin Healey 12
P TR2/3/3A TR3 turn signal and horn control wiring check Triumph 4
B Wiring Check Austin Healey 3
B Land Rover Series 3 Wiring Diagrams Rover / Land Rover 0
J TR2/3/3A Wiring Triumph 11
T 1971 Fuse Box and Wiring Triumph 7
tahoe healey Wiring Diagram for Fog Lights Austin Healey 12
P Wanted Wiring scraps Triumph Classifieds 14
olarson TR2/3/3A Horn Replacement Wiring Triumph 7
Sopwith_Camel horn relay wiring Jaguar 3
K TR2/3/3A Wiring a voltmeter gauge to replace the ammeter. Triumph 1
B Steering Column Wiring/Sealing Austin Healey 1
timsgolf Coil Wiring Austin Healey 20
T Spitfire 67 MK2 Wiring Triumph 12
Joel Lester TR2/3/3A TR3 Wiper motor wiring and testing Triumph 5
P XJ12 Wiring diagrams Jaguar 1
Scotsman Wiring Diagram for 1966 BJ8 Austin Healey 3
J TR6 TR6 Hayden Pusher Fan Wiring Triumph 2
B TR4/4A Basic Wiring Question Triumph 35
C For Sale Center wiring harness for a 1959 Sprite Spridgets Classified 0
I Lotus Elite wiring diagram Lotus 6
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
6 BJ8 Headlamp Wiring Austin Healey 1
S MGB mystery wiring plug MG 2
R TR6 Starter wiring question Triumph 6
R Spitfire Turn signal wiring Spitfire Triumph 5
B TR4/4A High Torque Starter Wiring Triumph 9
N For Sale Wiring harness 64-67 mk lll Spridgets Classified 0
J Wiring Harnesses Issues Spridgets 3
S Wiring Harness Replacement Spridgets 1
R Electric fuel pump wiring Spridgets 4
B TR4/4A Wiring Harness Triumph 6
R Wiring ??'s Spridgets 17
Healey Nut Rear Wiring Routing Austin Healey 2
7 General TR Wiring harnesses Triumph 5
Got_All_4 TR5/TR250 Wiring/Electrical Mystery Worked Perfect Then Not Triumph 5
MGTF1250Dave T-Series TF Windscreen Wiper wiring MG 4
M TR6 Fuse box wiring mystery Triumph 9
Healey Nut Wiring Harness Routing Austin Healey 5
J Wiring Harness Austin Healey 5
nichola TR6 Question on new wiring harness Triumph 6
R TR2/3/3A 1954 TR-2 O.D. Wiring Triumph 9
TomMull Dash wiring Plus 2 S Lotus 16
MadRiver BT7 Wiring Diagram Austin Healey 4
R TR2/3/3A Replace wiring harness in steering column Triumph 61
B Bugeye Electrical Wiring Diagram in Logic Format Spridgets 17
J TR6 73 TR6 Temp Gauge Wiring Question Triumph 6
Sopwith_Camel MGB wiring new Tacho MG 0
