Wiring Diagram for Fog Lights
tahoe healey
One for each head lamp and one for the fog lights. I've had this set up for the last 15-18 years using a second 3 position switch replacing the dash light switch. Position1 = off, position 2 =dash lights, Position 3 = dash lights and fog lights.
Unfortunately, I had a power failure somewhere and tore everything apart before I realized it was a blown axillary, in line fuse. I am trying to restore the system. It was a neat setup with fog lights off with high beams on.
I lost the original notes (senior moment). Norman Nock walked me through it originally. Dave had no ideas on this system and suggested some alternatives, but I loved the previous set-up.
gonzo
TH, I believe you shared your three-relay headlight low high beam and driving /fog lights schematic on this form those many years ago. I followed it to set up my relays. However, I operate the driving lights on a separate toggle. I check my notes and post them.
tahoe healey
I DID have a diagram, but it disappeared. I got a great one from a friend that I am about to use. I have a working system now that I engineered without the relays. (I added a pilot light to light me know when the fogs are on.) I prefer the relays.
NutmegCT
Bringing back some past lighting posts and diagrams:
Might be helpful.
Tom M.
tahoe healey
This is a great diagram that John Turney (of this forum) sent me. It made more sense and the job is done.
BigGreen
Thanks.
bob hughes
I have a layout somewhere with 2 relays, spots and fogs (all fitted with LEDs ) and with warning lights, wired through the Dipswitch with an over ride on the fogs, so they can be used seperatly. Note to self - I must find it.
:cheers:
Bob
tahoe healey
I did include a small "pilot" light to indicate when the fogs are on that is not included in John's diagram. The switch and light are on the drop-down gauge holder photo I posted earlier on the amp/volt thread.
John Turney
Thanks for testing the wiring, TH. Now I know it works.
Some toggle switches have a LED light in the tip of the handle that lights when the switch is on.
Scotsman Wiring Diagram for 1966 BJ8 Austin Healey 3
I Lotus Elite wiring diagram Lotus 6
MadRiver BT7 Wiring Diagram Austin Healey 4
B Bugeye Electrical Wiring Diagram in Logic Format Spridgets 17
B Bugeye Sprite Wiring Diagram Spridgets 4
R TR2/3/3A Color Wiring Diagram-1954 TR-2 Triumph 1
B BJ8 Wiring Diagram in "Ladder Logic" Austin Healey 39
D TR2/3/3A Alternator wiring diagram Triumph 7
T BN7 wiring diagram in color Austin Healey 7
Patrick67BJ8 Voltmeter Wiring Diagram Wanter Austin Healey 25
S MGA MGA Wiring diagram MG 1
K TR2/3/3A More wiring confusion re: diagram? Triumph 5
K TR2/3/3A Inverted wiring diagram compounded by dsylexia? Triumph 2
bugedd Wiring Diagram Spridgets 8
GTP1960 TR2/3/3A Interpreting fuel pump safety switch wiring diagram Triumph 3
T TR6 wiring diagram Triumph 11
D Bugeye Wiring Diagram - First Draft Spridgets 10
C Austin FX3D wiring diagram needed, New member here Other British Cars 3
Jim_Gruber BE Wiring Diagram Spridgets 8
MikeAH100M BN1 Color Laminated Wiring Diagram Austin Healey 1
MikeAH100M BN2 Wiring Diagram Austin Healey 3
richberman MSD 6AL-2 wiring diagram anyone Austin Healey 3
Boink Color Wiring Diagram for Mk1 Spridgets 8
DNK PI wiring Diagram Triumph 11
L TR2/3/3A Help with TR3A wiring diagram Triumph 3
Tinkerman MGB 1980 MGB wiring diagram help MG 6
vping T-Series TD Wiring Diagram MG 11
tweety color wiring diagram, where to get one? Spridgets 18
andrea WIRING DIAGRAM " 2 " Austin Healey 2
andrea WIRING DIAGRAM for imprved BN4 100/6 and early BN7 Austin Healey 3
P Color Wiring Diagram Triumph 7
D BJ7 Wiring Diagram Austin Healey 7
AUSMHLY BJ8 phase one color wiring diagram Austin Healey 12
Jim_Gruber '68 Sprite Wiring Diagram Needed Spridgets 3
K Spitfire Wiring Diagram 64 Spit Triumph 23
Ohiobugeye Wiring Diagram Question Spridgets 5
andrea Colors coded Wiring Diagram for 100/6 BN4 1956-58 Austin Healey 2
Shealey wiring question, anyone have a diagram? Spridgets 12
B 1979 Midget Wiring Diagram, Harness, etc. Spridgets 6
YankeeTR Big Wiring Diagram For The Shop...Worth It? Triumph 12
ducatista TR4/4A I need a TR4A wiring diagram Triumph 5
kyreb1862 MGB 77 MGB Wiring Diagram MG 2
D wiring diagram Spridgets 10
Woodie wiring diagram Spridgets 8
Editor_Reid MGB-GT MGB-GT Wiring Diagram MG 2
Banjo wiring diagram Triumph 8
S Spitfire 74 Spitfire 1500 color wiring diagram Triumph 4
W wiring diagram Triumph 1
J Need help locating an accurate wiring diagram MG 5
T Wiring diagram? Triumph 4
