Need help locating an accurate wiring diagram
Justin Bowen
Member
Hi fellas..
I'm trying to find an accurate wiring diagram for a 73 Midget. I'm looking specifically for dash/gauge wiring colors. Can someone point me in the right direction to find one online or tell me where I can buy one?
Bugeye58
Justin, when you get the Bentley version of the shop manual, that all Spridget owners should have, there are all the wiring diagrams in it. I'm looking at mine right now, and there are two possibilities for a '73, depending on the vehicle number.
I don't know if anyone has put one out online, but it's worth a Google search.
If you have a specific question, let me know, and have the vehicle number handy, so I know which diagram to look at, and we'll try and sort it out.
Jeff
Calvin
Justin,
I have the color codes which you may find useful, in a document which I'm sending to you separate from this reply. I can also scan the diagrams for you and put them in PDF format if that would be helpful, but I need your GAN number to send the correct diagram.
Have fun!
Calvin
J
Justin Bowen
Member
Thanks for the color codes, Calvin.
The vehicle number is GAN5UD134815G. If either of you can provide the wiring diagram(s) that would be great.
I appreciate your help.
Justin
EDIT: I believe I've found a diagram on this site that will work for me. But I'd welcome any additional diagrams you may have.
[ 02-28-2004: Message edited by: Justin Bowen ]</p>
RGK Need help locating parts MG 0
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
J TR2/3/3A Need help with pivot and body bracket for hood Triumph 2
J MGB Need help identifying these parts MG 6
B MGB-GT Need help with MGB GT rattle MG 0
K TR2/3/3A Help! No start! Need input from you guys. Triumph 9
T Wedge TR7 engine, need help identifying part. Triumph 5
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
Bayless Login problem need help FORUM Navigation Questions 7
N Electrical Issues Need Help Austin Healey 8
vette Renewing Subscription, need help. FORUM Navigation Questions 1
F Help need reinstating my heater - BT7 Austin Healey 7
55modified Need photoshop help for side vent options on my BN1 Austin Healey 6
N TR6 Need a little wiring help with a 74 Tr6 Triumph 6
5 Need help to id Midget year Spridgets 2
J TR2/3/3A Need Help with 62 TR3A Triumph 6
C TR6 Need help with a 1969 triumph tr6 Triumph 21
55modified need help with custom air deflector for BN1 Austin Healey 12
S TR4/4A Help. I need the glove box latch part Triumph 3
K TR4/4A Need help with clutch issue... Triumph 2
L TR6 need help on long dead TR6 Triumph 16
Jim_Gruber Need help to figure out an easy solution for this one. Spridgets 13
GBRandy MGB 1971 MGB return to the road - need some help. MG 10
G Need Help: Oil leak/crankcase pressure Spridgets 18
B TR4/4A Need Help Finding Triumph 3
S Wedge Need help with TR8 no spark Triumph 7
P TR2/3/3A Need Help Identifying These Seats Triumph 6
M MGB MGB Special Tuning 4 Cyl Carbs - Need Help w ID and Replacement Needles MG 1
M TR2/3/3A Need Help With Carb ID On My TR3B Triumph 8
Zimmycobra TR4/4A Need timing help - please! Triumph 15
D 68 Sprite value - need help Austin Healey 9
A Need help wiring my tach Spridgets 11
MKIII_Joey BJ8..need help.. Austin Healey 17
G Need some help identifying some E-Type parts please -- Jaguar 4
J MGB Need help identifying pistons for 18V motor! MG 0
B TR2/3/3A Need help with tr3 project Triumph 9
V General TR Need help with installing glass and new seal into my surrey top. Triumph 2
2wrench TR6 Need help finding gear shift lever spring retainer, please -- HVDA install Latest. Triumph 9
Steve P. Need help with oil filters Spridgets 1
RickPA Need help installing steering idler oil seal Austin Healey 6
M TR4/4A Need help with TR4A brakes Triumph 10
Willie_P TR4/4A Alloy Valve cover: STUD SPECIFICATION - need help!!! Triumph 5
Rut MGB Need turn signal help MG 15
