MGB Need turn signal help
Rut
Scratching my head on this one. Turn signals worked properly before my engine rebuild and now they flash rapidly. The hazard lights still flash at the normal rate, just the turn signals are rapid. The indicator lights on the dash along with all 4 lights flash are affected...any ideas?
Thanks, Rut
drooartz
You've checked grounds and connections? All bulbs are good?
Could easily have nothing to do with the engine-out you've done. Flasher unit could have gone south as well.
PAUL161
Did you install a new flasher? Sometimes a replacement flasher unit will do that as they are made for light duty and heavy duty, as in large trucks. Just sayin. PJ
Rut
Rut
I think I've narrowed it down to the work I did on the WW motor since the relay is next to it. The local auto parts stores have an Extra Loud relay that may just be the ticket!
Thanks, Rut
Rut
Rut
Went out to pull the relay and now the battery cutoff switch is acting wonky. I re routed my ground wire from the battery yesterday since I did a poor job on the original installation and might have over torqued the nut on the back of the switch. Looks like my relay project just expanded!
Thanks, Rut
Rut
Rut
Put in a new flasher relay and all is well. I also bought a new 300 amp cutoff switch to install later as well as some contact cleaner for a variety of electrical parts.
Life is good, Rut
max71
Member
:encouragement: Just saw this and was going to recommend what you just did. Clean all your grounds. They're pretty old and all electrics work better with good grounds. IE ALL you electrics including all your running lights and dash lights.
Rut
Rut
Arm straight out ~right turn. Arm bent at the elbow ~left turn.Problem solved
I do that whether the turn signals are working or not, but arm straight out is left turn and arm bent at elbow and facing up is right turn...LHD car! I want to get everybody's attention when I'm on the road.
Rut
59diamond
Oops. Bad memory about the arm signals. I remember when they came out with a mechanical arm thingey you could attach to your car so you didn't have to use your arm. that was long before electric signals
Platinum
Trafficator!!
Mickey Richaud
M Need help with horn/turn signal unit Triumph 18
Jim_Gruber Need Light Bulb Socket / Turn Signal / Behind Dash Spridgets 1
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
Gliderman8 TR6 Now I really know why I need new shocks Triumph 11
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
W Need advice on installing new side curtain glass Spridgets 1
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
T Storing nuts and bolts (so you can find what you need) Austin Healey 7
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
drooartz MGB OD question - need to warm up? MG 8
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
jackq Wanted Need a C Tach MG Classifieds 2
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
AngliaGT I Need to Resist - 1980 Ford Fiesta Other Cars 9
vette Need BugEye Generator Austin Healey 7
vette Need BugEye Generator Spridgets 4
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
J TR2/3/3A Need help with pivot and body bracket for hood Triumph 2
Madflyer For Sale Triumph GT 6 parting out need something Triumph Classifieds 10
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
tinman58 TR2/3/3A Need super charger!! Triumph 7
B Wanted I need a small section of a bugeye bonnet Spridgets Classified 5
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 23
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
John Turney Need a Better Demister? Austin Healey 5
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
69MGC MGC Need one MGB/C Splined Hub MG 1
69MGC Wanted Need one MGB/C Splined Hub MG Classifieds 4
Gliderman8 General TR Need clarification on Triumph Competition Preparation Manual TR250 TR5 TR6 Triumph 4
S TR6 Need wisdom on tr6 brake calipers Triumph 6
J MGB Need help identifying these parts MG 6
S TR2/3/3A Need New Battery for TR3A Triumph 9
B MGB-GT Need help with MGB GT rattle MG 0
AngliaGT MGB Need a GT [or Three]? MG 1
T Need an Anti-Tramp Bar? Austin Healey 6
K TR2/3/3A Help! No start! Need input from you guys. Triumph 9
