My 67 TR4A brakes requires pumping 2-3 times to get pressure. After 20 minutes or so, the pedal goes to the floor again requiring pumping. The car has been restored with everything new, except for the brake lines which were cleaned and flushed. New speed bleeders, too. I bled all around twice with DOT 5 fluid until no air bubbles and clear fluid. After bleeding, the pedal has solid pressure for an hour or so. After that, the problem starts all over again. Any thoughts/suggestions will be appreciated.
Question: should the line from the master be bled as well... could it be air bound? Also, there is no backflow preventer installed... would this help with the problem?
Thanks,
Moe Morin
Thanks,
Moe Morin
