jdelayknee
Hi Forum friends
I am replacing the wood dash, and middle plinth (love that word! it's the so-called crash device under the dash with holes to mount choke, heater switch etc) on my 73 TR6. (I am original owner) When disassembling I wrapped wires associated with various components to assist in re-assembly.
I am in the process of assembly now. I have wiring diagram from Bently and the colorized one from Auto wire. Both of these diagrams show a sold green wire for power in. Mine is purple/orange! I don't see this color on the wiring diagrams for anything.
I have done very little wiring over the years and never had work done by others that would have need for wiring changes.
I bought the car brand new and it had factory installed air conditioning. That did not work well in southern Florida at the time so I ripped it out. It was DIY 40+ years ago so my memory is suspect but I recall just disconnecting the wires from under dash and capping them. I never had need to touch the heater switch.
My original owners manual show the AC in place so that is why I say it was factory installed instead of dealer but I am not certain on that point.
2 questions:
1. Does anyone know of a wiring diagram for 73 TR6 with AC?
2. I will probably need to do some tracing now and I have heard it is best to disconnect battery and use a battery charger for power source (set at trickle charge amp setting) Anyone with details or better advice? I don't want to risk any dead shorts using the battery. I figure on hooking up the power source and checking for 12 volts on the purple/green wire.
Thanks for any help you can offer.
Jerry
2 questions:
Jerry
