TR6 tr6 horn wiring
Wike
Ready to install the 2 horns that came in a box when I purchased the car. Do the purple/yellow wires as well as the black(grnd) wires get connected to the different spades on the horns themselves? 74-tr6. Also, I replaced the steering wheel with a wood/leather one, adapter so on and so forth. This new wheel has (2) spades on the horn push part...one has a black wire attached which is just stripped and the adapter has a black wire with a push on spade connector. Any ideas?
alanjohnturner
You got the right idea for the horn wires.
One wire from the wheel joins to the wire that goes down the loom to the horn-relay
The other got to be grounded via the spring contact and the brass disc.
If this is not enough info you will need to post some pics.
Al.
P TR6 Horn issue 1974 TR6 Triumph 5
Sixpack TR6 Horn Mystery Triumph 3
P TR6 TR6 Horn Relay Problems Triumph 8
T TR6 TR6 Horn Triumph 20
W TR6 tr6 horn aftermarket Triumph 1
W TR6 tr6 horn button Triumph 2
W TR6 TR6 Horn only works when key is off Triumph 27
T TR5/TR250 TR6 Horn Relay Triumph 1
C TR6 TR6 horn repair Triumph 1
sundown TR6 tr6 horn Triumph 4
W TR6 horn blows tr6 Triumph 4
I TR6 TR6 horn help please Triumph 13
I TR6 TR6 horn help please Triumph 2
mabbott TR6 TR6 horn relay? Triumph 1
C TR6 69-TR6 horn problem Triumph 4
wangdango TR6 '76 tr6 horn push Triumph 1
B TR6 TR6 horn button intsall Triumph 11
C TR6 TR6 Dash replacement, now only the horn works Triumph 6
I TR6 TR6 phantom horn Triumph 2
T TR6 TR6 horn button Triumph 34
2wrench TR6 Help with horn removal '74 TR6 Triumph 6
mrv8q TR6 TR6 horn button rebuild Triumph 4
S TR6 1975 TR6 no horn Triumph 5
Brosky TR6 Horn problem with TR6 Triumph 12
B TR6 Horn Assembly Question 74 TR6 Triumph 2
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
