TR6 '76 tr6 horn push
wangdango
still working on the TR6, seems there is some pieces missing for the horn push. There is no long spring thing between the button and the housing, also no sort of "ring" where the horn push button would hit. What is supposed to be there? The VBritish catalog says there are two different length (the long cycl things between the push button and the housing...). Any help would be great..
thanks again,
ed
dklawson
I assume the TR6 would be the same as other Triumphs. There should be a slip ring on the top of the column behind the steering wheel hub. That should have a purple (or purple/black?) wire going off to the horn relay. It will be "hot". The hub goes next, attaching to the steering column. The spring loaded pencil goes through the hub, its bottom side rubbing on the slip ring, its top side pressing against the fixed metal tab on the horn push button. The wire clip on the side of the horn pushbutton will contact bare metal on the hub itself. The steering column is the ground path via a wire inside the steering column flex joint and a ground wire attached to the steering rack. When you press the horn pushbutton, you complete the ground path for the horn relay.
Sixpack TR6 Horn Mystery Triumph 3
P TR6 TR6 Horn Relay Problems Triumph 8
T TR6 TR6 Horn Triumph 20
W TR6 tr6 horn aftermarket Triumph 1
W TR6 tr6 horn button Triumph 2
W TR6 TR6 Horn only works when key is off Triumph 27
T TR5/TR250 TR6 Horn Relay Triumph 1
W TR6 tr6 horn wiring Triumph 1
C TR6 TR6 horn repair Triumph 1
sundown TR6 tr6 horn Triumph 4
W TR6 horn blows tr6 Triumph 4
I TR6 TR6 horn help please Triumph 13
I TR6 TR6 horn help please Triumph 2
mabbott TR6 TR6 horn relay? Triumph 1
C TR6 69-TR6 horn problem Triumph 4
B TR6 TR6 horn button intsall Triumph 11
C TR6 TR6 Dash replacement, now only the horn works Triumph 6
I TR6 TR6 phantom horn Triumph 2
T TR6 TR6 horn button Triumph 34
2wrench TR6 Help with horn removal '74 TR6 Triumph 6
mrv8q TR6 TR6 horn button rebuild Triumph 4
S TR6 1975 TR6 no horn Triumph 5
Brosky TR6 Horn problem with TR6 Triumph 12
B TR6 Horn Assembly Question 74 TR6 Triumph 2
BierRunner TR6 TR6 Trunk Lock Striker Triumph 1
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
