Well after 3 long years of restoring my 1955 BN-1 I am getting to a shorter list. I replaced the wiring harness with a new one as the previous owner replaced the orginal harness with a home made one (all the same color blue wire for everything!).
My question is, in the front of the car near the torsion bar, where the main harness attaches to the wires coming down from the trafficator connect to the main harness has a green wire w/ yellow tracer, a Green wire w/ a blue tracer and a green wire (a total of 3) plus the horn wire (brown w/ a black tracer) which I have hooked up and works fine. Which is correct by the wiring diagram.
Here is the problem, the wires coming down from the trafficator are Green w/ a red tracer, green w/ a white tracer and a green w/ a brown tracer. A brown w/ a black tracer (horns) which as I stated works fine. This is not as the wiring diagram shows. I can trial and error, but I don't want to fry something and have to replace it, if I don't have to.
The harness from the trafficator looks original as it is has a cloth covering. I looked at other Healey model wiring diagrams and nothing has that combination.
Has anybody ran across this or has the answer as to the correct match up. If not, if I trial and error can I short something out?
Thank you in advance for all your help.
Tod
Tod
