Original BN6 / BN7 Battery Switch Wiring Question
Duane_Rhynard
I am in the process of installing a new wiring harness on my BN6.
Where does the coil cutoff wire exit the harness on an original? Any pictures would be great!
Thanks,
Duane
'58 BN6
Keoke
IT is the only Black/White wire in the Boot area harness.
Duane_Rhynard
Keoke, thanks for the response!
My issue is on my BN6 2-seater is the cutoff wire on my new harness exits in the trunk by the drivers side tail light. I believe it should exit the harness just before the harness goes through the bulkhead into the trunk area. In other words it should exit the harness between the fuel pump wire and the sending unit wire. My old harness (Moss Circa 1980 - Not original) had the wire between the fuel pump wire and the sending unit wire.
I'm looking for confirmation.....
Keoke
MY experience with that wire says it exits inside the trunk area which provides access to the switch????
Duane_Rhynard
Keoke,
On my BN6 the cutoff switch connections are not in the trunk area, they are near the differential carrier in the same "cavity" as the fuel pump, and located on the switch installed on the inside wall of the trunk. It just seems strange to me that the wire would run out into the trunk area and then back again into the "cavity" again to be connected.
Thanks,
Duane
Keoke
OK MY Bad can't shake BJ8 goodies:congratulatory:
Duane_Rhynard
Finally resolved thanks to Roger Moment!
attachment.php
steveg
This switch has to be one of the most troublesome parts on a Healey! At California Healey Week, we had three cars out of 60 which were temporarily disabled by these switches giving out - until they could be troubleshot by master mechanic Russ Thompson.
Probably many more problems created than thefts prevented by these contraptions.
On my BN6 (L942), there's a welded/captive nut on the same bulkhead panel that the switch is mounted through.
That's where the ground was connected to the chassis on mine when I took it apart__before I deleted the switch...
Deleted member 19315
Not to hijack but what exactly is the issue with these switches? Is is a quality thing. I'm used to having a battery cut off on my cars and never had a problem with them but they have always been a race car type part since the cars are Hillclimb and sprint spec (which my newish 100/6is becoming) Or is it just that a few unfortunate problems have morphed into something else.
Andy
Duane_Rhynard
Andy,
Just like any electrical item that carries high current, these switches do not have an infinite life. Most of the time it's either the spring or the contacts that have worn over the years to a point where the switch fails. The original ones are are easily rebuilt and then should last another 30 years!
Duane
'58 BN6
Andy
Keoke
I agree with:
Duane
'58 BN6
Thanks for that information, My 100/6 has a new lucas switch in the standard fit position in the boot so I'll leave it fitted, I intend putting a motorsport sport type cut off switch in the bulkhead behind the driver seat in the main feed to the starter . I can then easily use a remote pull to stop handle for scrutineering. Are there any issues with doing this on my positive earth car? ( I'm a good spanner jockey but less adept with electrickery !!) I'll do an alternator conversion and negative earth sometime in the next year or so but an not ready for that yet.
Andy
Thanks for that , I will leave the standard earth cut off switch together with the coill isolator in position the fit a motorsport isolator in the starter feed with a pull cable to work.
andrea
I agree with Steve - I have rebuild my oldest switch
https://picasaweb.google.com/112770...ATIONAUSTINHEALEY10061958#5239506712836077122
Not satisfed, I have buy one new for my 100/6- on one of my first road tests at one corner the eletrical power dissapared, lucly
returned few second ago, learned the lesson-I have omitted the switch, the bug never occour.....
I now have one standard battery cut, direct--NO TROUBLES
https://picasaweb.google.com/112770819864514987162/SCHEMAImproved1006#6075902420290137938
S TR2/3/3A WTB a tr2 original grill Triumph 0
S Wanted tr2 original grill Triumph Classifieds 10
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Editor_Reid TR2/3/3A Original Knock-Off Hammer Triumph 14
P General TR What color is original for engine parts? Triumph 7
EWD For Sale ‘74 TR6 original wheel trim rings Triumph Classifieds 3
EWD For Sale ‘74 TR6 original radio Triumph Classifieds 0
EWD For Sale ‘74 TR6 original starter Triumph Classifieds 0
EWD For Sale ‘74 TR6 original steering wheel Triumph Classifieds 0
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
Popeye For Sale Original TR4A windshield - with crack Triumph Classifieds 1
CJRams For Sale 1974 Rolls Royce Silver Shadow - low mileage, all original Other British Classifieds 0
PAUL161 T-Series Original transmission sold MG 2
T For Sale TR3A Original Radiator Triumph Classifieds 3
N MGB Not original to my 70 MGB? MG 18
C For Sale BJ8 original dash Austin Healey Classifieds 3
PAUL161 T-Series Original 1955 MGTF Photos MG 6
A For Sale '74 TR6 original seat frames Triumph Classifieds 0
W Wanted Servo for BN4 has to be original 1957 or before any condition considered. Austin Healey Classifieds 11
K TR2/3/3A Is a 25 AGC fuse equivalent to an original 30 amp fuse? Triumph 10
J Wanted Original BJ 7 speedo Austin Healey Classifieds 0
R For Sale TR6 RADIATOR ORIGINAL STANPART Triumph Classifieds 0
R For Sale TR6 TONNEAU COVER ( FACTORY ORIGINAL ) Triumph Classifieds 4
R Wanted Looking for an original AH 3000 Mk1 Drivers Manual 1102B. Austin Healey Classifieds 1
LAW75 Concours: Original Gas Hose Austin Healey 12
57 Healey For Sale Original top (hood) frame for BT7 Austin Healey Classifieds 8
R For Sale Original AC Ace/Cobra seats. Early 60's, hand made Leveroll by A.W. Chapman, London Other British Classifieds 12
T TR2/3/3A Wanted - Picture of TR3A original firewall layout Triumph 5
Rob Glasgow Finally Found It (Original License Plate Number) Austin Healey 3
Rob Glasgow Found Original Owner Austin Healey 2
Hamish Racing 1963 original racing film British cars doing their thing Racing 0
B Bugeye Original Engine Compartment Sheet Metal. Act Fast! Spridgets Classified 0
S TR2/3/3A restore my original air filters Triumph 5
T Original Door Pocket Spridgets 14
G Original clamps for Petrolex hose Austin Healey 9
J For Sale Triumph TR 2/3 original brake/clutch master cylinder Triumph Classifieds 2
NutmegCT For Sale My 1953 MG-TD - Original, one owner 1953 to 2017 MG Classifieds 13
I TR6 Thickness of original TR6 dash Triumph 2
DerekJ Original steering wheels Austin Healey 1
S TR2/3/3A copied an old original interior piece and carpet pad Triumph 6
K For Sale Original Grease gun and jack....complete your TR3 collection. Triumph Classifieds 0
Z For Sale 1955 MG TD Original car, numbers matching, restored to immaculate condition MG Classifieds 10
S Wanted Original Style Positive Ground Radio Austin Healey Classifieds 0
G For Sale Morgan Folding Windshield Posts, Original 1960s-70s “Small Quadrant” Style, $600 Other British Classifieds 0
Cutrog1 How do I respond to all responses and add progress report on original article? FORUM Navigation Questions 3
F Which Original Oil filter assembly for BN7 Austin Healey 19
B TR4/4A Original gearbox bearings Triumph 14
H TR4/4A Original TR4a grill versus aftermarket Triumph 0
S TR6 Very nice original one-owner TR6 for sale in South Carolina Triumph 0
H TR2/3/3A Original Dunlop 5.50X15 Bias Ply Tire Data Triumph 4
