Which Original Oil filter assembly for BN7
F Schreiber
I have an BN7 built late dec 1959.
How do I tell which original oil filter assy is supposed to be with my car. The service parts spares list shows three, 1B2897, AEC897, and AEC675
But it doesn't say which enging number they start and end with. The originality guide does not go into detail about it.
dezand
I believe there are only two options, Tecalemit (1B2897) or the Purolator (AEC897)
My BT7 was built in Nov 1959 and has the Purolator.
F
F Schreiber
Well, I wonder why the AEC 675 is listed in the Service Parts list, its the last one on the list, and the parts listing unclear to me any details about the three different one. I appreciate your feedback. It makes me worry about buying the AEC675 i see for sale and it looks real good. But I hate to write the wrong one.
The Originbiality guide for restorations talks about the 100-4 and 100-6 filters, but no details about what supposed to be on a 3000.
Michael Oritt
F
F Schreiber
well, I had looked at the BN7 parts book before your post, and after I looked at the Moss, and I see they all have the same Adapter elbow, which must be the AEC675, its the rest of the stuff is whats different, so I bet I would have to have at least the exterior correct, and none of the numbers they quote match the number in my book. So that helps me decide that maybe I better not get that one. I just want to so I have the correct one for the car.
I would need the Tecalemit early,. And I don't really know how much different they look on the outide, the (canister and bolt). But there are oil filter assys for sale on E bay all the time, I will have to look more closely for the right one. Thanks.
Michael Oritt
I did not know that the different innards required different cannisters and fixing bolts, etc. Perhaps someone can give you appropriate measurements to help with your quest.
And now I will give some unsolicited advice--get a spin on adaptor and filter! Changing the original is, as I am sure you know, a real PITA and it is actually possible to stack the O-rings, etc. incorrectly and wind up with no filtration. The best adaptors have the filter hanging upside down so that you can remove and install with little or no leakage and you can also fill the filter with oil and eliminate a slug of air hitting the oil pump. Unfortunately I don't know who sells that configuration adaptor and I have the usual type that projects the filter at a right angle to the block.
Rant finished....
F
F Schreiber
I have the spin on adapter on the car, sticks out like yours. (I supposed one could poor a bit of oil in that one to star with.) I just want to get the original so I have all the original stuff that came with the car, especally while I can get it. Eventually those things will disappear.
John Turney
I took off a Tecalement when I put on the spin on. It has "Tecalemit" cast on the filter head.
Healey Nut
I have three spares kicking around in parts boxes . I can look tomorrow if ones says tecalamit on it .
F
F Schreiber
10-4 Thanks. I hate to be fussy, but I am looking for one in real good shape that I can make look like new. And that is the correct one. If they have numbers on please let me knkow what they are so I can comepare to the spare parts manual.
Healey Nut
Is this what your looking for , will need a coat of paint thats all . You wont find a new one they are NLA .
F
F Schreiber
That looks real good. Best picture I have seen. I need to look and see. I can't read the numbers on it. Looking at moss catalog There is Tecalemit early and Tecalemit late.
I need the early. And I am not a whizz on this but the right angle piece that bolts to the car might have AEC675 on it, What are the other numbers on it, I think i see cat #.
Which one does it match in the moss catalog, early or late? Where the canister connects to the base is different arrangement between early and late.
Healey Nut
Like this ?
the only difference between late n early is the bolt thread BSF/UNF and guts which is internal .
Im fairly sure a concourse judge wont ask to open up the oil filter on the show field .
F
F Schreiber
Well I doubt whether I will ever have my car judged in that way. I just for personal satisfaction have the correct one. So is this one a late or early?? I did not see the numbers in the book at quick glance. It looks really good. I want it to be the early.
Healey Nut
I have no idea , it was in a job lot of parts I bought on flea bay . If its not “correct” then just buy new internals and make it “correct”
F
F Schreiber
I find where it says that's right one, and one that says it for later. I just sent a note to another person. Suggestions on who to ask?
F
F Schreiber
One on the registry guys says there are almost none out there with the wrong threads. I don't see these #'s in the the books on forum I just found out about. Evidenty they don't show the Tecalemit #. So I am interested in buying this. I need to figure out how to PM you so I can buy this from you.
af3683 TR2/3/3A Original Purolator Oil Filter Canister Triumph 6
Tinkerman TR2/3/3A Major oil leak from original oil filter system 1960 TR3A post 600000 series Triumph 3
T S2 E-Type Oil Filter [original not spin-on] Jaguar 3
NutmegCT TR2/3/3A original oil filter, TR3A Triumph 6
bobh Easy way to remove the original oil filter and can Triumph 13
D TR4/4A Trans replacement front oil seal not same size as original Triumph 2
brgrmyster GT6 Original AC oil filler cap 67-68 GT6 [also TR4A]? Triumph 1
S TR2/3/3A Tr3 original rear oil seal Triumph 9
S TR2/3/3A WTB a tr2 original grill Triumph 0
S Wanted tr2 original grill Triumph Classifieds 10
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Editor_Reid TR2/3/3A Original Knock-Off Hammer Triumph 14
P General TR What color is original for engine parts? Triumph 7
EWD For Sale ‘74 TR6 original wheel trim rings Triumph Classifieds 3
EWD For Sale ‘74 TR6 original radio Triumph Classifieds 0
EWD For Sale ‘74 TR6 original starter Triumph Classifieds 0
EWD For Sale ‘74 TR6 original steering wheel Triumph Classifieds 0
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
Popeye For Sale Original TR4A windshield - with crack Triumph Classifieds 1
CJRams For Sale 1974 Rolls Royce Silver Shadow - low mileage, all original Other British Classifieds 0
PAUL161 T-Series Original transmission sold MG 2
T For Sale TR3A Original Radiator Triumph Classifieds 3
N MGB Not original to my 70 MGB? MG 18
C For Sale BJ8 original dash Austin Healey Classifieds 3
PAUL161 T-Series Original 1955 MGTF Photos MG 6
A For Sale '74 TR6 original seat frames Triumph Classifieds 0
W Wanted Servo for BN4 has to be original 1957 or before any condition considered. Austin Healey Classifieds 11
K TR2/3/3A Is a 25 AGC fuse equivalent to an original 30 amp fuse? Triumph 10
J Wanted Original BJ 7 speedo Austin Healey Classifieds 0
R For Sale TR6 RADIATOR ORIGINAL STANPART Triumph Classifieds 0
R For Sale TR6 TONNEAU COVER ( FACTORY ORIGINAL ) Triumph Classifieds 4
R Wanted Looking for an original AH 3000 Mk1 Drivers Manual 1102B. Austin Healey Classifieds 1
LAW75 Concours: Original Gas Hose Austin Healey 12
57 Healey For Sale Original top (hood) frame for BT7 Austin Healey Classifieds 8
R For Sale Original AC Ace/Cobra seats. Early 60's, hand made Leveroll by A.W. Chapman, London Other British Classifieds 12
T TR2/3/3A Wanted - Picture of TR3A original firewall layout Triumph 5
Rob Glasgow Finally Found It (Original License Plate Number) Austin Healey 3
Rob Glasgow Found Original Owner Austin Healey 2
Hamish Racing 1963 original racing film British cars doing their thing Racing 0
B Bugeye Original Engine Compartment Sheet Metal. Act Fast! Spridgets Classified 0
S TR2/3/3A restore my original air filters Triumph 5
T Original Door Pocket Spridgets 14
G Original clamps for Petrolex hose Austin Healey 9
J For Sale Triumph TR 2/3 original brake/clutch master cylinder Triumph Classifieds 2
NutmegCT For Sale My 1953 MG-TD - Original, one owner 1953 to 2017 MG Classifieds 13
I TR6 Thickness of original TR6 dash Triumph 2
DerekJ Original steering wheels Austin Healey 1
S TR2/3/3A copied an old original interior piece and carpet pad Triumph 6
K For Sale Original Grease gun and jack....complete your TR3 collection. Triumph Classifieds 0
Z For Sale 1955 MG TD Original car, numbers matching, restored to immaculate condition MG Classifieds 10
