S2 E-Type Oil Filter [original not spin-on]
T
TRDejaVu
Hello All,
When I got this car last year, I purchased oil filters from one of the usual suspects. They sent me the Coopers FA4012D. It comes with two o-rings; thick and thin. Which one am I meant to use?
We think the engine is from an XJ6 if that matters.
Thanks
Keoke
Hi the one that fits the sealing groove correctly.--Fwiw-Keoke
MikeP
I always used the thicker one on my series 1. It fills the groove side to side and almost to the top so that there's enought to compress against the cannister and it won't have room to move out from under it.
T
TRDejaVu
When I got the car it had a small filter leak and I seem to recall during the initial oil change that I took a thin one out. It still had a small, but manageable, seep afterwards. Recently that got worse and neither o-ring seems quite right (thin one looks too thin, thick one has a slightly smaller ID) hence the question.
I have a couple of new filters and the o-rings are the same with them.
M Photos Needed of Series III E-Type Engine Oil Filter Clearance at Exhaust Manifold Jaguar 1
J 1098cc distributor type and oil filter questions Spridgets 10
HEALEYJAG e-type series two oil filter Jaguar 6
BOBBYR OIL FILTER TYPE ? Austin Healey 2
HEALEYJAG e-type spin on oil filter adapter Jaguar 5
M TR6 Gear Oil Type and how to add 1973 TR6 Triumph 9
M TR4/4A A type Overdrive Oil Leak Fix Triumph 3
hondo402000 OD Oil for A type, Revisited Triumph 21
rkep01 Burman type oil pumps Spridgets 1
MY66AH What type of oil? Spridgets 21
B Engine Oil Type and Weight? Austin Healey 8
4 '03 X-Type 2.5L Oil Pan Gasket R+R ? Jaguar 2
T Series 2 E-Type Diff Oil Leak... Jaguar 5
nissanite E-Type V12 very low oil pressure - new rebuild Jaguar 11
PAUL161 Transmission oil Type MG 3
bighealeysource Steering box oil - type ? Austin Healey 3
T Oil Change, type of oil Jaguar 2
lbc_newbie Gear oil type for 210 4 speed tranny.... Spridgets 3
M new engine rebuild, new type oil seal and LEAKS ?? Triumph 15
I TR6 What type of oil for TR6 rear shocks? Triumph 2
BOBBYR ENGINE OIL TYPE ? Austin Healey 7
Atrus Rear axle - oil type & quantity? Spridgets 3
Tullamore 5.3 E-Type Oil Sender Jaguar 3
R Spitfire spitfire transmission and j type O/D oil question Triumph 29
F MGB Pinion Oil Seal Replacement - MGB Tube Type Axel MG 8
N What type of oil for homemake waxoyl Triumph 9
Webb Still Burning Oil? What Type of Oil to Use? Triumph 20
PAUL161 Tony, Doc, Question on shock oil type MG 11
J E type oil flow chart Jaguar 15
H MK2 lover, but... what about an E type? Jaguar 5
D TR2/3/3A layout for lap type seat belt Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
71TR6 TR6 Type-J Overdrive identification Triumph 4
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
Editor_Reid V-12 E-Type Body Number Location Jaguar 3
M For Sale 2017 Jaguar F-TYPE Premium 2-Door Convertible for Sale mlbirk@aol.com Jaguar Classifieds 0
K TR2/3/3A The Amco chrome tube type grille ....... Triumph 9
T TR2/3/3A A type overdrive hard engagement Triumph 36
S TR2/3/3A Wedge type and Dzus type side- curtains Triumph 1
R TR6 J-Type overdrive will not disengage when warm Triumph 8
6 E-Type brake light pressure switch location Jaguar 5
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
M Front caliper rebuild 1970 Series 2 E-Type Jaguar 0
M General Tech J Type OD Stuck in OD - Fixed Triumph 2
ROARRR Is there any problem swopping in a 3.0 in place of the 2.5 L engine in my Jag X Type? Jaguar 0
M General TR Source for J Type O/D Solenoid Circlip Triumph 0
M Wanted Wanted: Inoperative J Type OD Solenoid! Triumph Classifieds 2
V vintage glue type for veneer? Sunbeam (Rootes) 13
