After spending a little more time looking at what I dragged home, I've got some more questions.
The 1098cc engine in my Bugeye has a Lucas distributor without a vacuum advance. The advance is not removed; there is no provision for one. Moss shows a vacuum advance for all the sprite engines; what kind of problems can I expect if I retain this distributor?
The housing that holds the oil filter to the block is broken off and the oil pipe bent in two. I imagine this happened some time when this engine was sitting on the floor for the last 25 years. When I moved the engine home the housing just fell clean off. Moss shows the housings as NLA. Should I just use the Moss spin on adapter or try to find a housing and pipe?
I understand the flywheels for the 948 and 1098 are different. How do I tell what I have, and does it matter? The goal is to find a rib case gearbox and use with the 1098 engine. The engine plate is identified as the correct, thick, one. No leads yet on a trans locally.
Thanks, Jim
Thanks, Jim
