Installing the distributor pedestal. I have read in the Haynes Manual how the end float of distributor drive shaft hidden in the pedestal is important and is achieved by using shims if necessary. Reading in Haynes books on page 52, they want a temporary washer that is 0.5 to help establish a temporary gap and adding shims if needed between the block and pedestal to maintain the gap for the shaft.
Is that 0.5 they want a typo because that is a ½ inch? I would think they wanted to say .05 which would be 1/20 of an inch and to me that sounds about right for a float distance. I have never set the distributor float on the engines I have rebuilt this way. I put them together with no shims because that is how the engine was running before I did the rebuild. I use the gaskets in a gasket kit to stop oil leaking between the block and pedestal and they probably hold the pedestal up the. 007 the book talk about for an end result and float and call it good.
I was hoping a member who is better at math than me could help out and see if my math is correct.
steve
steve
