Installing a Lucas 16 ACR alternator on Bugeye
twas_brillig
I did some searching on the Forum last night regards alternators for Spridgets, and then found that I've got a Lucas alternator from the later models in my parts bin. I've ordered a rebuilt one and Jeff will lengthen out the current rear engine support and we'll get it installed next week.
I'm feeling a bit of an idiot for not exploring the 'stock' approach, but I never saw this option referred to in my reading. The Lucas alternator puts out 34 amps at 6000 alternator rpm; the Sprite shop manual advises 19 amps for the original generator.
Any particular reason to not take the 'stock' approach (other than I'm assuming that the Mitsubishi et al produce more amps and can be sourced more cheaply)? Thanks, Doug
The quality in the rebuild of Lucas alternators seems more "hit and miss" than other brands. Just from my personal experience.
nomad
Trevor, I think the quality of all rebuilds lately has become "hit or miss". Used to have local rebuilders but now they come from across the pond somewhere. A friend got a Lucas rebuild by Delco not long ago and it seems fine and about the same cost as rebuilt Delco cost by the same company. Personally, I like the little "skeleton" alternators by the usual Japanese company's.
Kurt.
T
twas_brillig
We had a choice between a Woods and a Dixie (if memory and spelling serve) and randomly picked the Woods. I believe that the voltage regulator is built in, so we'll keep the black plastic BE item in place but not wired. The remaining item is to decide what to do for a tach - I've got a used electric around somewhere and will find it and check to see if it fits etc. etc. And report back here sometime this summer as to success (or un-success). Doug
Jim_Gruber
Speedhut for GPS Speedo and Matching Tachsolves the issue. Search forum for Speedhut and you can see the jewels they crafted for me, complete with AH Logo on dial faces. Pretty Cool.
JPSmit
Coming back to the original question Doug. No reason at all not to take the original approach - it will look right and if it works it works. As long as you don't power your lowrider air system or your 5000 watt stereo system from it you should be good to go.
T
twas_brillig
Just picked up my shiny 'new' alternator and dropped the old one off. The chaps at the parts counter transferred the wire plug retaining loop from the old plastic housing to the new one (and had to stick a drill bit in to open the hole up on the new one), plus also pulled the old Lucas tag off the core and we'll stick it on the new one. And Jeff cut the old rear generator mount off at the flange, welded in a piece to lengthen things out, and the alternator is now installed. Minor note: the parts guys did not have a compatible plug for the 3 prongs on the alternator so we'll have to cobble something together there.
But a question: why is the 3 corner Mercedes Benz star on the Lucas part number tag? Sure looks like it anyway. Doug
apbos
Doug
Doing the same thing. Just got a monting bracket and have a Smith's tacho to replace the stock mechanical one. Could you supply some pictures. How are you handling the regulator wiring?
Regards
Paul
T
twas_brillig
For those interested in rebuilding their Lucas ACR alternator, have a look at https://www.oldclassiccar.co.uk/forum/phpbb/phpBB2/viewtopic.php?t=4513
My understanding is that the alternator has an internal regulator so there is no need to connect to do anything in this regard - We'll just leave the existing device in place but I haven't thought about making it look like it is wired into the system. I'll have another look at the alternator tomorrow. Doug
T
twas_brillig
One other small item: the pulleys don't line up (alternator; water pump etc.). The alternator pulley is roughly 3/16" further back and we'll probably use washers to space the two mounts forward. Not sure, but guessing that the pulley has been pressed on further by the rebuilder than originally. Another minor note: the cooling fan blades on the rebuilt are after market and all asymmetric - the guys at the parts counter advised that their understanding was that the asymmetry eliminated some harmonics and sound. Doug
T
twas_brillig
We don't have the proper plug-in for the alternator; Jeff went on-line looking for Lucas alternator pigtail (or some such) and found what was needed, and then popped by a local auto-electric shop and picked up the plug-in. Doug
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
S Installing a Radiator Fan Austin Healey 9
G Installing New Rocker Shaft Assembly Austin Healey 3
W Need advice on installing new side curtain glass Spridgets 1
Bayless Help please installing bonnet release cable Spridgets 8
M TR6 Installing Retrosound? Triumph 4
S TR2/3/3A Installing the distributor pedestal. Triumph 3
K TR2/3/3A Question about installing the steering wheel control head? Triumph 1
A TR6 Installing differential and transmission Triumph 10
Z Installing Toe Board Panels Austin Healey 1
K TR2/3/3A Installing Brake Caliper pistons into the bore? Triumph 21
CJ Burton MGB-GT Installing Seat Covers for 1962 - 1967 MGB GT MG 0
A Early 1967 AH Sprite - installing steering column and new directional switch? Spridgets 0
B Installing cam bearings 1275, can I do it? Spridgets 1
bighealeysource Installing stainless steel brake hose on BN2 Austin Healey 5
steveg TR6 Installing stock trailing arm bushings on the car - is it possible? Triumph 2
steveg TR6 Installing adjustable trailing arm brackets Triumph 7
T Installing Garmin GPS in a BJ7 Austin Healey 19
F Installing AC in my 1960 Healey Austin Healey 14
S TR2/3/3A technique for installing a door Triumph 5
R TR2/3/3A Installing wiring harness in steering column Triumph 59
R TR2/3/3A Installing gas tank Triumph 6
C Installing rubber grommets in firewall? Austin Healey 6
S TR2/3/3A installing a fuse in the red tail lights Triumph 4
S TR2/3/3A installing the wiring harness Triumph 8
R Installing Sprite Luggage Rack Spridgets 9
Lukens TR2/3/3A Installing a throttle. Triumph 2
J Powertune booster for a bj8 , trouble installing Austin Healey 2
B TR2/3/3A Installing dzus fastners in bonnet Triumph 8
D Prepping Floors Before Installing Interior Restoration & Tools 6
drooartz Installing front hubs, tips? Spridgets 15
E TR4/4A Wiring the horn when installing a Moto -Lita steering wheel Triumph 4
K TR2/3/3A Installing Moss wheel spacers? Triumph 5
D BT7 tri-carb installing my crank Austin Healey 4
aero3113 Installing Front rotors to hubs Austin Healey 2
C Advice for installing a 3000 Grille??? Austin Healey 7
B MGB Installing new upper fulcrum bushings MG 5
B MGB Installing upper fulcrum bushings MG 0
S TR4/4A procedure for installing gauges etc Triumph 0
I Tips for installing intake manifold plugs in a stock Bugeye? Spridgets 6
55modified Help installing toggle dip switch on dash for lights. Austin Healey 23
TRMark TR4/4A Installing a new windscreen Triumph 9
55modified Rear anti-roll bar. Is it worth installing on a BN1? Austin Healey 22
KVH General Tech Installing the Pistons and Rings Triumph 7
T Need advice for installing a Winner's Circle Panhard rod on a BE Spridgets 4
6 General Tech Installing New Oil Pressure Gauge MG 5
6 Installing Oil Pressure Gauge Spridgets 2
T TR4/4A Installing wheel arch covers in a Tr4a Triumph 0
K TR2/3/3A Installing a Voltmeter on a TR3? Triumph 10
Tinkerman TR2/3/3A Installing small body stone guard Triumph 9
