The fuel pump is a new Hardi Electronic Fuel Pump. On the label it says, "Dual Polarity AZX1332G." The box also has the numbers 1112-1 marked on it.
I want to connect this to my Positive ground system in the BN4. The instruction sheet in the box only has a diagram for connecting the pump to a Negative ground system. The pump has two electrical terminals, one with yellow paint on it and one without paint on it. The instructions indicate that the yellow is for the Positive connection and that the other terminal is to go to Ground.
Now I am wondering whether this actually is a dual polarity pump. Any ideas on how to connect this to the Positive ground system? Yellow terminal to positive or negative? I do not want to fry the pump or some other part of the electrical system.
