Crankshaft
My starter switch fails intermitantly. It seems that when failure occurs, I can turn the engine over with the button on the solenoid and the push switch works next try. First of all, does this indicate a problem with the solenoid or push switch on the dash? Secondly if the problem proves to be with the solenoid, is it serviceable or need to replace? The dash sw has continuity when depressed.
