clutch push rod replacement question
recordsj
1500 MG midget
The hole for the pin on the clutch master cylinder push rod is elongated a bit from use of the years. I wanted to replace it. I understand how to remove it, but by removing it will anything pop out of the master cylinder and/or allow air to get into the system during the the process of replacing the pushrod?
JPSmit
Off the top of me head - no problem, it is a friction fit
scoutll
You'll be fine as long as you gently pull the rod out of the rubber dust cover, just in case it's stuck a bit. Don't push the pedal while the rod is off.
JPSmit
recordsj said:
Have you done this procedure before, or is it your guess?
Yes, I rebuilt my MC twice before I realized it was too pitted and bought a new one. I just went and looked at my old one, and, it appears that you pry off the rubber cap, there is a circlip underneath, remove that, and the push rod should slide out. I also looked at my pushrod and while it too is oval, where the real wear was, was the clevis pin.
scoutll
You said that better 'n me JP.
R
recordsj
I did end up having a problem, the piston rod with the seal popped out when I removed the clutch push rod. Ended up then needing to bleed the clutch... needed the bleed the clutch anyways.
K TR2/3/3A Clutch and Brake Master Cylinder push rod stop bolts? Triumph 15
Joe Reed MGB Clutch Slave push rod...past its prime MG 2
GTP1960 TR2/3/3A Clutch slave cylinder / push rod alignment Triumph 10
F BT7 3000 - Push rod problem on clutch slave cylinder Austin Healey 7
tahoe healey Clutch master cyl. push rod Austin Healey 2
T Bugeye clutch MC push rod length Spridgets 6
T TR4/4A ? on TR4A clutch shaft - wear @ push-rod attachment Triumph 6
drooartz Clutch push rod Spridgets 13
Turbozinke TR2/3/3A Varying clutch engagement Triumph 6
DutchConnection Clutch finger problems on Powetune aftermarket clutch cover Spridgets 0
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
Govtslug TR6 Clutch Problem Triumph 21
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
AUSMHLY Clutch Pedal Freeplay Austin Healey 18
T General Tech Clutch trouble Triumph 12
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
AUSMHLY Clutch Stalls Engine Austin Healey 16
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
T Spitfire Clutch fork and hydraulic cylinders Triumph 3
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
Lin Brake/Clutch Fluid Austin Healey 11
R TR2/3/3A Clutch Petal Adjustment Triumph 2
KVH General Tech New Clutch Installation--TR4A Triumph 5
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
D Clutch Fork Pin Removal Austin Healey 4
Michael Oritt Clutch Linkage Austin Healey 19
M 1275 Race Clutch Racing 5
G MGB 1978 MGB clutch is out..! MG 39
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
B Spridget with a Tilton Race Clutch Racing 1
AUSMHLY Clutch Pilot Bush: NOS vs Aftermarket Austin Healey 8
T Clutch Pedal Engagement Point Austin Healey 1
TR6Canuck For Sale 72 TR6 clutch and transmission Triumph Classifieds 4
K TR2/3/3A Clutch slave "return spring"? Triumph 3
vintagemechanic Recommended clutch kits Jaguar 3
K TR2/3/3A Clutch Master Cylinders? Triumph 1
R TR2/3/3A Clutch Engagement Triumph 31
S TR2/3/3A Clutch pushes hard when engine is hot Triumph 4
T TR2/3/3A TR3A clutch problem Triumph 15
