removal of push-pull dash control buttons
Donalvin
I am currently in the dismantling phase of restoring my '62 TR4. Have a simple question regarding removal of the heater and vent control buttons. I don't see how to remove them. Removed the threaded rings that secure them to the dash support but the knobs must come off to facilitate removal. I see small holes in the knobs but don't see how to release the knob from the slider. Don't want to break anything. Can anyone help?
Donalvin
t_lay
I used a pick to push in the small hole - that releases the knob from the switch. IIRC, knobs attached to the cables may work a little different and the cable stays with the knob - it's been a couple of months since I pulled the dash out.
MGTF1250Dave
Aloha,
Those small holes, usually oriented on the bottom of the knob, provide access to a pin mounted on the end of a piece of spring steel on the shaft. A small pick or stiff wire inserted in the hole will push up the pin so you can remove the knob from shaft. Over time these knobs can stick on the shaft so if you have difficulty removing the knob, a bit of lubricant through the hole and down the shaft will help free it up. Good luck.
KVH
And when you push a needle, pin, small rod, nail punch, pin remover, or whatever, don't be surprised if you still get hung up.
I've had to depress the little button, wiggle and pull, and sometimes horse them off.
Start gentle and it might feel it's way off. Many will just slide right off with no fanfare.
Good luck.
Lou Metelko
I have always used an opened up small paper clip. Good part about using a paper clip is you don't have to remember where you put it since there are always a bunch of them in the bottom of a desk drawer.
Lou Metelko
Auburn, Indiana
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
BoyRacer Door Skin Removal Austin Healey 6
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
C MGB Rubber Bumper cover removal MG 5
kodpkd Antenna Removal Austin Healey 9
B General MG Crankshaft Nut Removal MG 4
BN6_2197 Gearbox/Overdrive Removal Austin Healey 25
W BN1 Steering Box Removal Austin Healey 11
S TR2/3/3A engine removal Triumph 12
S TR2/3/3A Steering wheel removal. Triumph 4
D Clutch Fork Pin Removal Austin Healey 4
A 78 MG MIDGET EMMISIONS REMOVAL Spridgets 1
C MGA Dash removal MG 0
Darrell_Walker TR4/4A Speedo Drive removal (non-OD) Triumph 8
AUSMHLY Spigot Bush, Pilot Bushing Removal Austin Healey 4
R TR2/3/3A Steering wheel hub removal Triumph 11
MadRiver TR5/TR250 Water pump housing removal advice Triumph 0
V 1969 Sunbeam Alpine coupe glovebox lock removal Sunbeam (Rootes) 0
newmexTR3 TR2/3/3A TR3 outer wishbone bushing removal Triumph 5
D Heater knob removal Spridgets 6
S 1275 oil pan removal Spridgets 30
K TR2/3/3A The grease gun brake caliper piston removal trick..... Triumph 6
E austin van heater removal Other British Cars 0
C TR2/3/3A TR2 Axle/wheel bearing removal Triumph 2
nevets Water Pump Removal Austin Healey 6
M TR2/3/3A Crankshaft Sludge Plug Removal Triumph 6
F Interior Door Handle Removal Austin Healey 2
Z Front Springs Removal Austin Healey 3
R Oil Filter Removal Austin Healey 1
C MGA R/H tail lamp removal on a 1962 MG 5
K TR2/3/3A Removal of tie rod end? Triumph 7
J Ignition Key Cylinder Removal Austin Healey 3
J Planetary Gear Removal Austin Healey 3
Walter74 Adjustable steering wheel removal Austin Healey 4
E MGB 1965 mgb fuel pump removal MG 2
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
T BJ8 Drain Channel Removal Austin Healey 2
D TR2/3/3A Facia removal steps Triumph 3
M TR2/3/3A Brake Line Removal From the Left Frame Rail Triumph 14
S TR2/3/3A Generator Pulley Bolt Removal Triumph 12
T Spin-On Oil Filter Removal [BJ7] Austin Healey 12
pkmh Front Spring Removal For BJ8 Austin Healey 8
M Spitfire Triumph spit flange/hub removal Triumph 13
L TR2/3/3A Engine removal questions Triumph 8
7 paintless dent removal tools? Restoration & Tools 8
dbenichou289 TR2/3/3A headlight switch removal Triumph 10
UltimateQuestion GT6 GT6 Mk3 rear wing removal Triumph 3
Got_All_4 TR6 Differential ID year & output shaft removal Triumph 11
