Brake M/C Push Rod
Mickey Richaud
Anyone have one for the dual line system? Need one.
Thanks,
Mickey
Spridget64SC
More than likely there is one in the bucket/tub of dual M/C's in the barn. Give me some deminsional info. Size of the end that goes into the M/C (dia. of the 1/2 hemisphere shape and the depth) and the length from pivot pin hole to the M/C end. I can then look at what I've got.
Can look tonight if I get the info. Out of town for the Drivers School at Roebling Rd. for Th-Su. Back late and then can check Mon night.
HTH,
Mike Miller
Mickey Richaud
Mickey Richaud
Thanks, Mike. Since I don't have one handy, it's difficult to make any measurements. But as long as it fits the dual-line, non-servo cylinder for either the B or Midget, that's the one I need.
I'll take a look, and if I don't hear from anyone else before you get back, will let you know.
:cheers:
Mickey
Spridget64SC
Sure,
I'll do a quick check of what I can find tonight and see what they look like. I have lots of salvaged single and dual cylinders for various vehicles in a 5 gallon bucket down in the barn and most of the pushrods are separate.
Mike Miller
Mickey Richaud
Mickey Richaud
You might want to save all the dual-line push rods, as they seem to be pretty scarce!
PeterC
Mike and Mickey Pushrod is 3 - 1/2" long. 1/2" spread on the fork. 5/16" clevis pin hole located 5/16" from the fork end.
Peter
Spridget64SC
Mickey:
If you are still in need of one of these M/C pushrods, I found two over the weekend down in the barn. Never found my box/bucket full of M/C's. Must be hidden in the "Triumph" shed out back or under something in the barn. Found one pushrod in a loose M/C and another in a box of stuff acquired years ago from a Richmond,VA "unfinished- project" purchase.
Anyway, both have some rust blemishes on them around where the pushrod is exposed outside the rubber boot. Not too bad, but one is a little worse than the other. And, its welding to the fork end is not as well centered. Holes for the pivot pin look to be worn about the same.
$5 for the lesser quality one
$7.50 for the better one
S&H is additional. Let me know if you want one.
Thanks,
Mike Miller
(864)638-6316
Mickey Richaud
Mickey Richaud
Thanks, Mike - should have posted that I got one over the weekend.
Spridget64SC
No problem. It's been a busy couple of weeks on my end and I meant to go look for these sooner. Now I know where two are and can respond sooner if someone else needs one.
Mike
K TR2/3/3A Clutch and Brake Master Cylinder push rod stop bolts? Triumph 15
Mickey Richaud Brake M/C Push Rod MG 2
Bruce_B Push Rod for Brake Master Cylinder Spridgets 9
AUSMHLY brake pedal push rod adustment - YIKES ! Austin Healey 9
Patrick67BJ8 Brake Pedal Vary Hard to Push Down and Brakes feel like there's no Booster on my BJ8 Austin Healey 27
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
J MGB BRAKE VALVE ? MG 11
G Brake Light Switch Failure Austin Healey 24
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
J TR2/3/3A Brake Line Flares Triumph 8
Frameman 1949 Brake Bleeding Austin Healey 0
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
L T-Series Another brake prob. ? MG 12
S TR2/3/3A brass fitting from a steel brake line Triumph 2
Sopwith_Camel MGB pulsing brake pedal MG 10
bighealeysource Front Brake Adjusters Austin Healey 0
SherpaPilot TR6 Brake Fluid in Servo? Triumph 0
TAS525 TR2/3/3A Thoughts on Brake Pads Triumph 12
Gundog61 BN2 Brake Drums Austin Healey 5
KVH General TR Rear Brake Shoe Orientation Triumph 12
R TR6 Help: Brake Part Source or …. ? Triumph 1
mezy vauxhll brake pipes Other British Cars 0
KVH General Tech TR4A Brake Bleeding Triumph 5
R Brake Adjustment Spridgets 2
Walter74 Brake Servo Location Austin Healey 6
A 100-6 Brake Lights Austin Healey 2
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
prb51 Girling Brake Fluid Reservoir Cap Austin Healey 6
KVH General Tech Brake Fluid Triumph 5
Lin Brake/Clutch Fluid Austin Healey 11
AUSMHLY Castrol DOT4 Brake Fluid Austin Healey 6
bighealeysource Brake Master Cylinder Austin Healey 27
S TR2/3/3A Lockheed brake system Triumph 7
kodpkd Disc Brake Pad Installation Austin Healey 11
