push rod question
ichthos
Some how when I layed down the push rods to dry after I cleaned them, I lost one. Even though I layed them down in the order I removed them, I do not know which one I lost, so who knows which ones are out of order now. I do have an extra. My question is does it really matter what order I put them back in if I have what amounts to a new rocker assembly?
Thanks for your help.
Kevin
KVH
Straight. Try rolling them. They're probably fine.
I'd tear my house down and find a lost push rod before going on. That's just me. I'd need to know it didn't fall somewhere that could prove to be disastrous. When I lost my jet centering tool I was certain it had rolled into the combustion chamber. The mind plays games. If you let it. I'm still waiting for my engine to explode.
TR3driver
Great Pumpkin - R.I.P
IMO, no worries on getting the pushrods out of order, as long as you check the valve lash afterwards.
In addition to straightness, inspect the tube near where the ends are pressed into it, for any signs of damage (bulging or cracks); and also the wear surfaces of the ends for pitting or other extreme wear. Not likely you'll find a problem if the motor hasn't been raced, but it doesn't hurt to give them a look anyway.
T
Tinster
Kevin !! What are you doing dude ?!!
Losing important parts.
Remember what we always discuss when doing a project?
Parts Boards !!
Non-mechanic guys like you and me need Parts Boards so we
don't lose parts and so we know how the parts we remove fit
back together. No matter how small the project. A square
of cardboard with 12 holes punched in it was all you needed.
I'm in the middle of a small project and I'm using a Parts Board. Now go find yer missing push rod!
best regards,
dale
startech47
The largest area of concern, when redoing a valve train, is the wear pattern between the rocker arm and the valve stem. Since you are replacing the rocker arm assembly you have eliminated that concern. Make sure you replace the push rod with one of equal length. You will find this out when you adjust the valves. If you can establish the proper gap you are OK.
I
ichthos
I am pickng up my cylinder head tomorrow. It had to be built with new stock valves, springs, guides, and seats. I also ended up having to replace most of my rocker assembly with new parts when I rebuilt it. I guess what all of you are saying though is that since everything is pretty much new, it won't matter the order as long as the the push rods are straight with no visible damage to the ends, correct? I rolled them over on my table saw bed and I did not see any wobble.
Dale, as I cleaned each part I placed them on butcher paper underneath my car where I thought they were safe. I didn't number the rods at the time because I layed them carefully in order next to the rocker assembly, waiting for them to dry after I cleaned them. I had far less parts than the suspension rebuild and wasn't too worried about labeling them later. One thing I didn't mention is a chipmunk problem. This sounds like one of my student's excuses for now turning in their homework. I had a chipmunk in my garage going through everything. It started storing nuts inside the engine bay, and unrinated there also. I was pretty mad. I was in a hurry when I moved stuff out of the way to get to it. I moved the parts quickly, but thought I was ok. I am still looking for the pushrod. After three days of persistence, at least the chipmunk is no longer a problem.
T
Tinster
Kevin, there are tears in my eyes I'm laughing so hard!
Only a teacher could come with such a wild excuse!!
The "dog ate my homework" is drab compared to yours!
Good luck with your project. I'm really sorry the low
pressure cylinder has turned into such a nightmare for you.
I know money is tight.
A chipmonk peed on my parts!!! A great one!!
regards,
dale
R clutch push rod replacement question Spridgets 6
K TR2/3/3A Clutch and Brake Master Cylinder push rod stop bolts? Triumph 15
Joe Reed MGB Clutch Slave push rod...past its prime MG 2
GTP1960 TR2/3/3A Clutch slave cylinder / push rod alignment Triumph 10
F BT7 3000 - Push rod problem on clutch slave cylinder Austin Healey 7
tahoe healey Clutch master cyl. push rod Austin Healey 2
DornTRoriginal TR2/3/3A My Push Rod Situation Triumph 12
SMGoose Push rod return spring Triumph 7
T TR2/3/3A TR3b Master cylinder push rod clevis Triumph 2
S TR4/4A Leaking push rod tubes, TR4a Triumph 7
T Bugeye clutch MC push rod length Spridgets 6
Mickey Richaud Brake M/C Push Rod Spridgets 8
Mickey Richaud Brake M/C Push Rod MG 2
K M/C push rod adjustments Spridgets 4
T TR4/4A ? on TR4A clutch shaft - wear @ push-rod attachment Triumph 6
drooartz Clutch push rod Spridgets 13
A TR4/4A TR-4 cylinder head push rod tubes Triumph 2
B Spitfire Decipher this Spitfire engine and a push rod query Triumph 3
Bruce_B Push Rod for Brake Master Cylinder Spridgets 9
H push rod length help Austin Healey 1
pan Bent push rod Austin Healey 3
Russ Austin Push Rod looks a little short Triumph 14
V TR6 TR6 Push Rod Length Triumph 1
AUSMHLY brake pedal push rod adustment - YIKES ! Austin Healey 9
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
C MGA Change a pull starter to a push button system MG 6
PAUL161 T-Series Bent Push Rods MG 34
R J-H no longer needs a push! Other British Cars 6
K Restoring Horn Push Button Austin Healey 12
Joe Reed General MG Early Midget horn push on Personal wood rim steering wheel... MG 3
Patrick67BJ8 Brake Pedal Vary Hard to Push Down and Brakes feel like there's no Booster on my BJ8 Austin Healey 27
Got_All_4 TR2/3/3A Push switch for washer fluid pump Triumph 4
Lukens TR2/3/3A Anyone ever see a push/pull throttle mounted on the dash? Triumph 4
T timmers 67, push rods and lifters Austin Healey 4
Martinld123 Push button on top of new H6 carbs float bowl from Moss Austin Healey 3
KVH TR4/4A Rocker Shaft Lubrication, and Issue with Push Rods Triumph 1
S TR2/3/3A copper gasket sealer and push rods Triumph 10
J Healey 100 -- Broken rocker and bent push rods !!! Austin Healey 7
Perrymip TR2/3/3A Starter Solenoid Push Button Triumph 11
P Grounding of Horn Push-Bugeye Spridgets 4
Kleykamp TR2/3/3A hollow push rods ? Triumph 6
M stainless push button snaps for convt boot Austin Healey 2
F Replacing the horn push adjustable steering wheel Austin Healey 7
C Wiring new Mota Lita horn push into my MG Midget Spridgets 6
Donalvin removal of push-pull dash control buttons Triumph 5
BugeyeNJ58 Push or Pull - Electric Fan Spridgets 3
G Push'in Springtime Spridgets 3
6 elect. fan..push or pull Triumph 16
S TR2/3/3A tr3 unsoldered push in connectors Triumph 3
justin_mercier Source for a push/pull DPDT switch? Triumph 13
