Whitephrog
Having the coil mounted on top of the generator is causing a spatial conflict. Looks like I won't be able to use the hole in the 1275cc engine block for the temperature sensor. I'll need to use the hole in the radiator instead. What do I use to plug the hole in the engine block?
