Pertronix Ignitor - old potential reliability issue is still there
twas_brillig
I e-mailed Pertronix yesterday asking if their Ignitor was still at risk for failure if it was left powered up without the engine running (we have one on a VW powered Meyers Manx clone buggy, and had it fail this way a few years ago. Pertronix was good enough to repair it, with no charge). They replied today that it still has the same old potential issue, but suggested their Ignitor II , but for negative ground only (and I appreciated that recommendation too!):
"Sorry we haven't changed the design. The Ignitor would still have the same rules. Sorry.
If you were not running a positive ground we could talk about the Ignitor II version but it doesn't work in a positive ground.
Your Pertronix Team,
Marvin Grebow Jr.
Technical Dept."
Deleted member 21878
But the igniter II is not to be used with solid cores wires they say.
donbmw
Trouble shooting a electrical problem. I have had 2 go bad. I was disconnecting the Petronix any time the power was for more than a couple minutes.
CaptRandy
Back in the 60's we learned that the points will fry if the ignition is left on so I guess I remember that and never leave it on for an extended period of time.
RAC68
Hi All,
After a period of non-use, I turn the ignition on without starting the car to have the fuel pump push fuel and build pressure. After the clicks stop, I then attempt to start my Healey. Although I have never thought this process could have the unintended consequence of burning my points (when they were installed) or my present Crane Electronic Ignition, it was a process I used for at least the past 40 years without issue.
As mentioned, my present electronic ignition is a Crane which was a forced warranty replacement for a failed Alison EI (Crane purchased Alison) and now I am wondering if it had a design flaw similar to that of the Pertronix. Since the installation of my Crane in the latter part of 1999, I have continued to start my Healey after a period of inactivity (weeks) using the same procedure and have found the EI both efficient, consistent and reliable (on issues).
Although I have this starting procedure for my Healey, I use a Pertronix on my 79 TR7 and do not use this starting approach. The Triumph is equipped with a modern rotational electric fuel pump that moves fuel and
builds pressure
quickly to easily satisfy carburation needs for a quick choked start-up. Based upon the cause of Pertronix failures, I have been lucky to have chosen the unit for the car as I did and not installed IEs in the reverse.
Just my thoughts,
Ray(64BJ8P1)
John Turney
Ray,
I have the same starting procedure and Crane system that you do. Not had a problem, except when the high voltage started arcing to the optical pickup bracket in the distributor. Trimmed teh bracket and all is ok.
Keoke
Well: Do not leave the switch on for very long
This "OLD" problem is not really a reliability or design failure mode ,it exists because there is no way to put a Heat Sink in the module large enough to displace the heat caused by the constant current flow through the Transistor when you leave the device connected while you are trouble shooting other electrical problems.
Trouble shooting a faulty Pertronix requires a very good scope and they do not generally respond to conventional static electrical testing methods.
P.S. That Steve fella just about right--LOL
RAC68
Original in-error statement:
That is why the Pertronix 2 and Crane do not have this problem as they have a large externally mounted heat sink and electronics.
Corrected statement:
That is why the Crane does not have this problem as it has a large externally mounted heat sink and electronics.
Sorry for my error in my initial statement. I misidentified the Pertronix HP Digital component in the picture as being part of the Pertronix 2 and wrongly associated it as being a similar setup as the Crane.
Ray(64BJ8P1)
Keoke
That is why the Pertronix 2 and Crane do not have this problem as both have a large externally mounted heat sink and electronics.
l ifin this be true:
Well ifin this be true why can't they make a Pertronix 2 for negative ground, heat sinks do not affect grounding systems.?
Ill stop by next time I am up that way . :smile-new:
OH! maybe they are contemplating a power inverter to extend their line
T Pertronix Ignitor - old potential reliability issue is still there Spridgets 0
T Pertronix Ignitor: reliability & suitability Austin Healey 10
T Pertronix Ignitor: reliability & suitability Spridgets 19
Lutz Kramer Ignition timing with Pertronix Ignitor and strobe light Austin Healey 67
max71 MGB Anyone have experience with the Pertronix Ignitor III? MG 11
Michael Oritt Pertronix Ignitor failure mode Austin Healey 8
MGTF1250Dave Pertronix Ignitor Electronic Ignition Installation Triumph 26
MTribe setting static timing with pertronix ignitor Triumph 0
RickB Pertronix Ignitor & Flamethrower kit? Opinions? Spridgets 19
B Pertronix Ignitor Bad? Triumph 7
bluemiata90 Pertronix ignitor, which one to use Triumph 6
Thor Problems fitting Pertronix Ignitor II into 45D CEI Spridgets 6
S Pertronix Ignitor Austin Healey 4
B Pertronix ignitor in Jensen healey Other British Cars 1
D Lucas Sport coil / Pertronix ignitor MG 9
T Pertronix distributor install into Austin Healey 100/6 Austin Healey 12
wangdango '67 XKE Mallory dulal point to Pertronix Jaguar 0
B TR6 Pertronix ignition Triumph 11
P Pertronix distributor on an early BJ7 Austin Healey 8
R It wasn't the Pertronix Austin Healey 25
R Suspected Pertronix failure Austin Healey 32
Marvin Gruber TR5/TR250 Pertronix vs Crane electronic ign Triumph 1
KVH TR4/4A Report on Pertronix Triumph 6
richie TR4/4A Missing since rebuild with Pertronix Triumph 9
dklawson General MG Which Pertronix? 45D with Red Points. MG 4
3798j TR4/4A Pertronix III 25d Install Triumph 1
S Points versus Pertronix Spridgets 22
A Spitfire 45DE4 Distributor Pertronix Installation Triumph 2
H TR4/4A Pertronix Ignition Triumph 4
S TR2/3/3A Timing with Pertronix Triumph 12
AUSMHLY Pertronix or points Austin Healey 49
B BN2 Pertronix Question Austin Healey 2
rjc157 Pertronix dist Austin Healey 2
B Pertronix Distributor Wiring? Austin Healey 3
mgbmedic car keeps running after pertronix install MG 11
Scotsman Pertronix Flame Thrower Electronic Distributor Triumph 7
DRKizer Pertronix Flame-Thrower "HP" dizzy for Brit cars Racing 6
B Ignition wires to use with Pertronix distibutor Austin Healey 9
regularman Pertronix Spridgets 28
mountainman pertronix electronic ignition hepl please Triumph 10
T How do you set the timing on a Pertronix distribu Triumph 13
M TR2/3/3A Pertronix coil for TR3 Triumph 7
britndablood Anyone need a pertronix backup pickup for $40 Austin Healey 1
6 Timing Bugeye with Pertronix Spridgets 2
D Spitfire spitfire pertronix installation question Triumph 25
Go_Dogs_Go Convert Pertronix Pos Ground to Neg Ground? Spridgets 10
drooartz Pertronix back to points MG 28
Jim_Newman Pertronix + MSD ignition problem Austin Healey 6
memphis Pertronix & Mallory Dual Point [Positive] Austin Healey 11
T How bench test Pertronix unit Triumph 3
